  1. Jun 26, 2018 at 11:33 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    While its not "plug and play" per say but the process is relatively the same if you're go with H1 retrofit setup. Open the headlamps up, mount the projector and check for clearance behind the bowl. Aim and test components before you reseal the lens back on. If you're not planning on painting anything, it could all done in a couple hours.
    Kuntrykid likes this.
  2. Jun 27, 2018 at 12:08 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Thanks. 5100s with 885s and a single AAL
    chiefcrunchy likes this.
  3. Jun 27, 2018 at 3:38 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    I must be driving wrong keep hearing peeps getting 400 miles on a tank. This us the best one I've had20180626_173528.jpg
    19 gallons 317 miles.
  4. Jun 27, 2018 at 3:40 AM
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    But than again 8 miles each way to work on fun roads.
  5. Jun 27, 2018 at 3:55 AM
    Rd62
    Rd62 Well-Known Member
    2014 DCLB TRD Sport
  6. Jun 27, 2018 at 3:56 AM
    Rd62
    2014 DCLB TRD Sport
    It's a 2014
  7. Jun 27, 2018 at 4:45 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Just checked it this morning, and good to go! My bolts are on the "inside" of the center pc. Noice!!!!!!!!
    Twizted[QUOTED] likes this.
  8. Jun 27, 2018 at 5:13 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    I left mine off.
  9. Jun 27, 2018 at 5:38 AM
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
  10. Jun 27, 2018 at 6:17 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Mine does
    Kuntrykid[QUOTED] likes this.
  11. Jun 27, 2018 at 6:27 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I would trade my 400 miles a tank for that drive into work.
  12. Jun 27, 2018 at 8:16 AM
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    Did u do Uca, if not how's your alignment?
  13. Jun 27, 2018 at 8:33 AM
    incredibillhulk
    incredibillhulk Don't Panic
    Bill
    North Carolina
    2013 DCSB MGM
    In the works.
    Added a Fumoto valve last weekend. If you look closely, you'll see that in my haste to get it put on, I didn't notice that I left my old crush washer stuck to the pan by accident which resulted in my draining ALL the oil back out so that I could unscrew the Fumoto and remove the old drain plug's crush washer. SMH.
    Slashaar, jpereira2, Twizted and 2 others like this.
  14. Jun 27, 2018 at 8:40 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I didn't. When I get the alignment done the shop said it was good. My old tires tell a different story. I'm going to get it re done at a reputable truck place soon.
  15. Jun 27, 2018 at 8:40 AM
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    Nice nipple! :thumbsup:
    Scooter WCT, gabbo2112 and ChadsPride like this.
  16. Jun 27, 2018 at 8:43 AM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    Mine never did?...
  17. Jun 27, 2018 at 8:53 AM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    How the fuck do you get 400 miles a tank? 220 is it for me, to the light, at 17 gallons. I've tried new plugs, cleaned the maf and TB. Insanity
  18. Jun 27, 2018 at 8:53 AM
    christian06
    Cali
    Thx for the the info
    diabetiktaco[QUOTED] likes this.
  19. Jun 27, 2018 at 8:58 AM
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    Did you need to lift?
  20. Jun 27, 2018 at 9:02 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Made some color matched plugs for my fender holes.
    Bought red body clips, sanded them down, filled with bondo, sanded, primed, sanded, painted and cleared.
    The black part is a neoprene washer behind it.
    E5DFDD82-FC5E-4D53-8A2B-7811A0B22E48.jpg 87E5ACB1-DFDF-46B5-9D8A-4DA1203E81FF.jpg
