  1. Jun 28, 2018 at 9:07 PM
    Allstar780
    Allstar780 Well-Known Member
    Colin
    Alberta, Canada
    15 TRD Trail Teams Sport
    3" Lift, 32" Goodyear Duratrac, XD Series Hoss Rims
    Nice bumper
  2. Jun 28, 2018 at 9:30 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    If I had a 2nd Gen I’d give you a demo:cool:.
    You can see @4x4Taco09 post above he has the same setup(albeit all white). But I use the same LED panels in my 3rd gen builds and I will tell you they are bright. With a complete replacement, you are not limited by how many LEDs can fit on a “bulb” style. And with the LEDs recessed in the new panel it helps reduce glare looking into the truck from the side. :)
  3. Jun 29, 2018 at 12:24 AM
    olecoot
    olecoot Well-Known Member
    Dennis
    Northeast Fl.
    2021 TRD OFFROAD 4X4
    3 + 1 Pro Comp 285 Falkin Wildpeaks Bed Cap
    Yea I know its 3:00 a.m. been playing in the shop. Ok, got the rack on , everything went great except I have a wave sticking up in weather stripping.Pinched up to tight between 2 of the mounting pads. Now I need some visual as how to have the front cross bar for the light bar. Whats a good middle of the road 40" light bar? Don't want to go crazy on something I probably won't be using much. Thanks
  4. Jun 29, 2018 at 4:34 AM
    CMD-KY
    CMD-KY Well-Known Member
    South Central Kentucky
    2104 Tacoma AC SR5 4wd
    No, it was intended as a joke, I should have labeled it as such.
    la0d0g likes this.
  5. Jun 29, 2018 at 6:09 AM
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Changed out my cabin filter. Whoever put it in last used the wrong sized filter and also installed it upside down. The dealer was supposed to have changed it the last time I was there. Pretty sure that didn't happen. :rolleyes:
  6. Jun 29, 2018 at 6:48 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Damn sealerships. Glad it wasn't a more crucial point in your truck.
    gabbo2112 likes this.
  7. Jun 29, 2018 at 7:52 AM
    olecoot
    Dennis
    Northeast Fl.
    I took a small piece of black pipe nipple (LOWES) 1/2" I think. Ran 3/4 drill bit inside and sharpened the end down to an edge and that was my punch for weather stripping mount thru holes. Works good , hit hard enough to cut thru rubber and mark back with cut marks, then take some side cutters and cut the meat strip running in the bottom.
  8. Jun 29, 2018 at 8:28 AM
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    Basket added!
    #haulallthethings
  9. Jun 29, 2018 at 8:35 AM
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    did the basket cut down or increase the wind noise?
  10. Jun 29, 2018 at 9:05 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Just got inline for a frame!
    Dammit I tried and lost.
    Yay I guess,,, starting to stress about the swap already.
  11. Jun 29, 2018 at 9:16 AM
    Twizted
    Twizted 1GR FE
    Rob
    America
    Wind noise is pretty much gone now. I came from aero-bars before, but needed longer (78"), so had to go with square bar. The nose was pretty bad until last night after adding the basket. I was prepared to wrap paracord around the front bar, but don't plan on it now.
    seedy_tea[QUOTED] likes this.
  12. Jun 29, 2018 at 9:38 AM
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    cool thanks. i have superstrut bars, and even with paracord the wind noise was still bad. I think cuz it's not a solid bar (slotted on top, open on the bottom). I ended up putting rack pads up there and that worked, but might go basket in the future. IMG_20180618_190122.jpg
    Kuntrykid likes this.
  13. Jun 29, 2018 at 9:46 AM
    SoCalTbird
    SoCalTbird Well-Known Member
    South OC
    06 PreRunner DCSB 05 AC 4X4
    what bars are those that attach to the cab roof?
  14. Jun 29, 2018 at 9:58 AM
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    ARB fit kit. I picked them up from here: https://www.desertrat.com/i-23331007-arb-4x4-accessories-3723010-roof-rack-mounting-kit.html
    they mount to the factory holes. the cross bars are ~32" apart using the foremost and rearmost mounting slot. all in all, solid rack system for ~$200.
    more pics here (these are not my pics, found them on here a while back): https://www.tacomaworld.com/threads/arb-roof-rack-fit-kit-3723010.509577/)
    mtmudrunner and Fluffymonkey like this.
  15. Jun 29, 2018 at 10:19 AM
    Twizted
    Twizted 1GR FE
    Rob
    America
    Your howling is probably mostly caused by the slots in the bars. If the bottom is open, that'll whistle like a hooker practicing her o-face...
    outxider and SoCalTbird like this.
  16. Jun 29, 2018 at 10:20 AM
    SoCalTbird
    South OC
  17. Jun 29, 2018 at 10:25 AM
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    ya thats what i figured. well, not exactly the way you put it... but ya.
  18. Jun 29, 2018 at 10:27 AM
    Twizted
    Twizted 1GR FE
    Rob
    America
    I recently picked up these bars off of CL for $150 (including the feet).
    I believe you can still get the bars only for $100 brand new, but that's for the 78", if you wanted shorter, I'm sure they'd be less.
    seedy_tea likes this.
  19. Jun 29, 2018 at 10:45 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Installed the Cali Raised faux grille with color matched bezel.
    Installed this morning. With all the Tacomas around my island, I haven't seen a Blue Ribbon with this grille setup yet. Trying to be at least subtly different.
    Side by side
    Ta-da!
    Lighting's a little off, but color match is perfect.
    Local dealer wanted $400 for the color match portion. Bought it from a Florida dealer, shipped, for waaay cheaper.
    sseaman, Rick_Taco, siundon and 13 others like this.
  20. Jun 29, 2018 at 10:58 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    25ADAEBE-114C-464E-9404-7E02A718B7BD.jpg Nothing what I did but how many miles I get between fill ups. I fill up every Friday because I hate stopping during my work week, lol. Mind you I’m stock other than fj cruiser wheels, trd catback and AFE ProDry air filter.
