  1. Jul 4, 2018 at 9:37 AM
    motionridr8
    motionridr8 Well-Known Member
    Drew
    Greenville, SC
    2012 Tacoma 4x4 DCSB
    5100's/886's/JBA UCAs, ICON RXT Rears, US Offroad Winch Front Bumper, BAMF Rear Bumper, 235/85r16 Skinnies
    The fading/cracking powder coat and finish is apparently “normal wear/aging” and they did send another pod to try and resolve the different color “amber”, but sending another single pod still left me with a mismatch in color. Overall, their service was fine, but again, you get what you pay for.
    I have a set of Rigid 4” E2s up front, a set of Dually diffuse pods in my rear bumper, and soon to be Rigid Amber fogs. They’ve stood the test of time and the elements. I’m sold on their quality.
    crashnburn80 likes this.
  2. Jul 4, 2018 at 9:53 AM
    Boylemaker88
    Boylemaker88 Active Member
    Thomas
    Rockledge FL
    2013 Tacoma
    Washed her yesterday so she can get rained on today!! upload_2018-7-4_12-53-25.jpg
  3. Jul 4, 2018 at 9:57 AM
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    How do you have the larger light bar mounted? I've been meaning to put one in
  4. Jul 4, 2018 at 10:31 AM
    Boylemaker88
    Thomas
    Rockledge FL
    2013 Tacoma
    I ran a piece of 2” wide flat aluminum stock from one side of the bumper mounting bracket to the other, pretty easy to do, just have to disassemble the front grille assembly to get down in there. Then used self tapping screws to mount the light bar to the aluminum channel.
    Kuntrykid likes this.
  5. Jul 4, 2018 at 10:49 AM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Upgraded transmission cooler to a B&M 70264. Modified the included brackets to utilize the factory rubber bushing mounts/hardware.
  6. Jul 4, 2018 at 10:53 AM
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    2013 Tacoma 4x4 2017 4Runner TRD Pro
    SCS BR6/ Bilstein 6112/5160/ BajaDesigns Squadron Sport Fog Lights/ BajaDesigns Squadron Pro Ditch Lights/ BajaDesigns S1 Flush Mount Reverse Light/ 32" Light Bar/ Rago Fab Ditch Light Brackets/ CaliRaised Lower Bumper Light Bar Brackets/ BPF Tow hook/ BPF TRD Skid Plate/ Bora 3/4in Wheel Spacers/ Icon 3 Leaf AAL/ BAMF HD Shackles/ TRD Pro Grill/ OEM Roof Rack/ OEM Bed Mat/ Nitto Trail Grapplers/ Every Bulb LED
  7. Jul 4, 2018 at 10:59 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Valpo.
    Working on a Moto Guzzi Convert.
    This bike is special as it is a prototype pre production.
    The story goes something like this.
    The bike came to the states so the police could try them out and the factory could get real on road testing.
    Depending who you talk to or read there were 25 +- in the trial.
    The serial, Number on the engine is 8 and the transmission is 1.
    Verified by MVD ,since there isn't a Mfg plate th St of Ct. Issued a AKA number.
    Currently the bike is running a 5speed trans from a Guzzi 850 T and the owner wants it made back to the
    Convert type transmission.
    All the original parts are there so I'm resealing and replacing a bearing on the hydraulic system.
    Then changing out the 5 speed ang reinstalling the Torque converter, universal driveshaft ,rear differential (the Convert has different gearing to work with the hydro system).
    The work so far is advance work inventory cleaning etc.
    Being a prototype the castings are rough,think 80 grit sandpaper, my Convert is a production version and my castings are smother, think 400 grit.
    Some of the parts don t even have part numbers being g a prototype but the parts can be sourced from the later versions.
    The torque converter on the left is the prototype, the one on the left is what the production models use20180627_121241.jpg
    If you look to the left of the full plug 1" you will see the serial number 1. It's there look close
    Thanks
    TOMB
    Valpo, gabbo2112 and Doogz like this.
  8. Jul 4, 2018 at 11:06 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Happy 4th of July you drunk sons a bitches! Enjoy the night and all the freedoms this great country has to offer! :cheers: :headbang: :oldglory:
  9. Jul 4, 2018 at 11:09 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Checked my oil and cleaned my MAF today.
    Kuntrykid, lo2hi and 05Taco4x4 like this.
  10. Jul 4, 2018 at 11:12 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Love my V7
  11. Jul 4, 2018 at 12:24 PM
    Tnronin
    Tnronin Two things in this world smell like fish!
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    Reattached the steering wheel air bag where a Dumbass that installed an aftermarket radio, and took the controls off didn't reattach the left side, nor tighten the right side. Fixed the parking lights (both bulbs burned out), repaired the compass/temp, attempted to replace the temp/AC/vent light cluster. (If you can share a source for those bulbs that would be awesome!) I gotta order those bulbs. Bought a load bar for the bed from harbor freight, jacked some milk crates from a buddy's grocery store (he's the Mgr and said I could take).
    Next to fish out the usb for the ddx-372bt to update and customize update.
  12. Jul 4, 2018 at 12:37 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    What is it?
    Grumpy, WhiskeyTaco and YanE30M3 like this.
  13. Jul 4, 2018 at 12:38 PM
    TOMB
    Tom
    Newington Ct. 06111
    IMG_1126.jpg 1972-moto-guzzi-eldorado-we.jpg PIC CX100.jpg 05 Taco 4x4
    Honda CB400F
    Moto Guzzi Eldorado 1973
    Moto Guzzi CX100 LeMans
    Here is a list of Moto Guzzi,s that I have owned over the years,
    The mileages are correct and were put on by me.
    Try the site below if you haven't tried it yet.
    I go by TOMB on that web site
    http://wildguzzi.com/forum/index.php
    If you need any Guzzi info I probally provide you with contacts or links.
    Start a conversation on this website for personal contact info .
    V7 is a great bike .
    I owned a earlier V7 called a V7 Sport -1973 model
    1972 AMBASSADOR 169000 MILES
    1978 G5 170000 MILES
    1973 V7 SPORT 25000 MILES
    1973 ELDO 300000+ MILES
    1980 CX100 50 MILES
    1796 CONVERT-56000 MILES AND BUILDING
    1976 HONDA CB400F 27 MILES AND BUILDING SOLD
    MGNOC # 2723
  14. Jul 4, 2018 at 12:40 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    It’s a handle/grip for the door.
    LittleLady808[QUOTED] likes this.
  15. Jul 4, 2018 at 12:56 PM
    ACEkraut
    Aaron
    Durham, Maine
    Aha.
  16. Jul 4, 2018 at 12:58 PM
    05Taco4x4
    2TR-FE Enthusiast
    Nice! I've been on there :thumbsup: I had a leaking brake reservoir, found the previous generation seal worked.
    gabbo2112 likes this.
  17. Jul 4, 2018 at 1:01 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Umm.... Is that transmission case cracked? To the left and below the bolt above the 1" plug. In the curved recess, to the right of the threaded hole on the far left.
  18. Jul 4, 2018 at 1:06 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I see lots of peeled paint but no cracks.
  19. Jul 4, 2018 at 2:52 PM
    ACEkraut
    Aaron
    Durham, Maine
  20. Jul 4, 2018 at 2:57 PM
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    Why is this necessary?
    CMD-KY likes this.
