  1. Jul 5, 2018 at 10:55 AM
    Geoff
    Geoff Well-Known Member
    Adirondack Mountains
    2023 TRD OR
    I have the Leer XQ (#4). I like the look of the windows, but they only open a crack and don't allow any airflow into the back.
  2. Jul 5, 2018 at 11:05 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    While bed stiffeners are relatively basic, there are key design reasons I chose Total Chaos over others. Writeup to follow.
    Kuntrykid and MattCowsmasher like this.
  3. Jul 5, 2018 at 11:11 AM
    Airmain
    Airmain Well-Known Member
    Jes
    Middle of Georgia
    06 TRD Off road
    Technically not today but last weekend I replaced upper/lower balljoints, inner/outer tierods, and wheel bearings both sides
    azshooter40 likes this.
  4. Jul 5, 2018 at 11:26 AM
    Yota31
    Yota31 Well-Known Member
    Shannon
    Lifted 2006 Trd Sport Tacoma
    Led Tailights, OEM roofrack, 3 inch lift, Halo light bar and Black Wheels
    Anyone know what this is? I bought my truck about 10 months ago and I found this under my rear seat. Thought might go to the truck. I thought I might ask before I throw it away. One side pulls out but pulls it self back in. Any ideas?
  5. Jul 5, 2018 at 11:28 AM
    dome
    dome Well-Known Member
    Joel
    California
    2015 TRD OR DCSB 4x4
    Glove box's "soft open" mechanism. Allows the glove box drop slowly instead of just all at once. Goes on the right of the glove box iirc.
  6. Jul 5, 2018 at 11:29 AM
    JMiko
    JMiko Well-Known Member
    2015 Tacoma Access Cab
    It's for your glove box. It mounts on the right side.
  7. Jul 5, 2018 at 11:43 AM
    Yota31
    Shannon
    Okay I will check it out
  8. Jul 5, 2018 at 12:06 PM
    Yota31
    Shannon
    Thanks guys. You 2 were right. My glove box didn't have one on it. Works so smooth now. Also checked my cabin air filter for the first time. I probably need to get a new one. I cleaned as much as I could here's what it looked like20180705_133201.jpg 20180705_133206.jpg
    Kuntrykid and kgarrett11 like this.
  9. Jul 5, 2018 at 12:08 PM
    Trey5150
    Trey5150 Well-Known Member
    2015 Black Taco DCSB TRD
    Leveling kit, Flowmaster exhaust, Warrior Front Bumper, Warrior Roof Rack, Ram Mount A-Pillar, Weather Tech mats, Pro grill, Rigid ditch lights, Rigid backup lights, Spod
    I would replace that!
  10. Jul 5, 2018 at 12:10 PM
    Yota31
    Shannon
    Haha yeah.
  11. Jul 5, 2018 at 12:29 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Nothing like form over function.
    Casper66 likes this.
  12. Jul 5, 2018 at 12:34 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Not today, but about a week ago, got the blower installed. Still ironing out a few tuning issues. Hope to have em solved in the next week or so
    BajaAsh, MY50cal, grdgz97 and 13 others like this.
  13. Jul 5, 2018 at 12:45 PM
    CMD-KY
    CMD-KY Well-Known Member
    South Central Kentucky
    2104 Tacoma AC SR5 4wd
    Nah, you can get a couple more years out of that. Replacement is just a plot by "stealerships" to cheat you.
  14. Jul 5, 2018 at 12:49 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  15. Jul 5, 2018 at 1:02 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    No fan on the cooler itself. It is in the same location as the stock cooler, there is plenty of airflow there from the stock fan and airflow from driving. Seems to be working well for my application. I'd rather keep it simple with a bigger cooler than one with a fan. Whitelightning boosted put one on his, even bigger than this one, check that out too.
  16. Jul 5, 2018 at 1:19 PM
    natesmitte500
    natesmitte500 Well-Known Member
    Nathaniel
    Henry County, GA
    Silver 2015 Tacoma
    Dual 185W spot lights, ultra motor sports wheels, 255/75/17 BFG Mud Terrain, patch board (aka roof liner)
    Today I did some pro rattle canning! Redid the covers on my spot lights and did the dash cluster trim!5BDFE2C3-9CF8-4EF7-B895-C784834A3562.jpg 0BA9F6BD-9E47-4FE3-8628-778D1384BE8E.jpg
  17. Jul 5, 2018 at 1:24 PM
    TacomaStrength
    TacomaStrength Well-Known Member
    Removed the badges, installed "The Gasshole", and gave her a bath.
  18. Jul 5, 2018 at 1:27 PM
    field76
    field76 Well-Known Member
    Bozeman
    2012 PM TRD OR DCAB
    Debadged, audio upgrade, silex organizers, AVS in channel window vents, 5100s on all corners with Wheelers 3 leaf HD AAL
    Replaced the front brake pads, installed a Hayden Rapid Cool 678, then had a tranny flush at the dealer
  19. Jul 5, 2018 at 1:28 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    :woot::woot::woot:
  20. Jul 5, 2018 at 1:47 PM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
    what percentage tinting you went with?
