  1. Jul 16, 2018 at 12:36 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    It's still progress on your tacoma man. Cool! Welcome to TW!
    gabbo2112 and ChadsPride like this.
  2. Jul 16, 2018 at 1:32 PM
    TacoHunter59
    TacoHunter59 Well-Known Member
    Nathan
    Arizona
    2015 DCSB TRD Offroad 4x4
    Ummm....stuff and more stuff
    I had the dealer finally say there is a fix for that damn issue. According to my dealer it was just released in the last month for my tacoma. They are claiming that if the temperature is above 100 it can cause the issue. The fix is a fan that sits in front of the radiator on the passanger side. So far no issues but not sure that fix is really going to be the solution.
    I mean....how can a compressor sitting in the AZ sun be cooled enough in the first 2 minutes of starting the truck to keep it cool enough. But so far so good so, time will only tell.
  3. Jul 16, 2018 at 1:55 PM
    henrilepuf
    henrilepuf Well-Known Member
    henri
    Northwestern Paraguay
    tacoma 2014 4x4 DCLB
    Emptied the oil catch can after 5,000 miles.
    Surprised !
    More than 100 cc of oil !
    gabbo2112 likes this.
  4. Jul 16, 2018 at 2:06 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Your motor thanks you.
    GARSHA91 and henrilepuf[QUOTED] like this.
  5. Jul 16, 2018 at 2:20 PM
    bwawuz02
    bwawuz02 Well-Known Member
    wheeliest likes this.
  6. Jul 16, 2018 at 3:03 PM
    la0d0g
    running for the hills
    For crawling not hauling
    @EatSleepTacos lol
  7. Jul 16, 2018 at 3:05 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I immediately think of you literally any time a diff drop is mentioned :rofl:
    FWIW my views have changed. I don’t have one. Pretty negligible difference, so I’ll take that $30 and buy chickfila instead.
  8. Jul 16, 2018 at 3:06 PM
    la0d0g
    CFA :hungry:
  9. Jul 16, 2018 at 3:08 PM
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
  10. Jul 16, 2018 at 3:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  11. Jul 16, 2018 at 3:43 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Been fiddling with some grill lighting (quazi Raptor like). Certainly not done, by any means. Just coming up with some mounting options and initial test fitting. I fashioned some mounts out of black plastic. Still brainstorming though.
    Powered them up with a 9v battery. So, they're a bit brighter than this with 12 volts running through them.
  12. Jul 16, 2018 at 4:20 PM
    HawaiianSON
    HawaiianSON Blood makes the grass grow, OORAH!
    Nasty
    San Diego by way of HILO, HI
    2015 white DCLB
    Kustom54lighting /bruteofrce/brushed BRONZE
    M10 x 1.25TP x 50mm(2”L)
    ChadsPride likes this.
  13. Jul 16, 2018 at 4:20 PM
    SpeedShift01
    SpeedShift01 Active Member
    2013 TRD Off Road Tacoma
    Muffler delete, 3inch Rough Country Lift Kit, 33 inch Tires, Tekonsha Break controller, Uni Filter mod, K&N intake, E3 Spark Plugs, Front Bump Stop Upgrade, Cali Raised Hood Pod lights, Power Stop slotted and drilled front rotors and carbon ceramic pads.
    i just followed Tacomaholic's new video on youtube and changed my secondary breather (the UNI Filter mod). Anyone here with a 2nd gen tacoma needs to check this system and then do this "mod", none of us want damaged engines (if the secondary breather filter has gone bad)
  14. Jul 16, 2018 at 4:22 PM
    bwawuz02
    Just sayin' one member gives a clearly documented reason not to have them (along with others who share that sentiment) whilst you just say it's not good to have a lift and not have one with zero supporting evidence... trust but verify, care to verify your statement?
  15. Jul 16, 2018 at 4:49 PM
    HawaiianSON
    Nasty
    2015 white DCLB
    The bolts are M10 x 1.25TP x 50mm(2”L). From what I’ve been reading on here and the website that sells these kits, it’s only the back you can raise since the are vertically shimmed. The fronts mount horizontally and all you would be doing is shimming it outward instead of upwards. The back actually makes a big diff, it levels out the chair instead of sitting in a 5gal bucket like someone mentioned on here.
  16. Jul 16, 2018 at 4:54 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    My uhmwpe shims are 3/8" thick I am going to stack them going to try and raise the front a little at least. Thanks for letting me know now I can go pick some bolts up and complete this mod:thumbsup:
    CMD-KY likes this.
  17. Jul 16, 2018 at 5:34 PM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Got my home-made Prinsu knock-off rack installed on my camper cap (shell, topper, whatever you call it where you live). I have a Gen-You-Wine Prinsu on the way for the cab, but they said they won't even be shipping until July 30.
    Also installed a tailgate damper, but I'm not sure if I like it or not. When I close the tailgate, the factory support cable gets buggered up with the damper. I have to manually place the cable is just the right position or the gate won't close. (Notice how the cable is a little bit kinked from being folded and pinched.)
  18. Jul 16, 2018 at 5:45 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Typical problem with the ez down. Continued use will ruin the cable. I have not heard of a solution yet.
  19. Jul 16, 2018 at 5:53 PM
    Lefkos
    Lefkos Well-Known Member
    Winston
    Las Vegas
    PreRunner
    Fixed some scratches that were on my bumper and finally aligned my truck lol
  20. Jul 16, 2018 at 6:39 PM
    HawaiianSON
    Nasty
    2015 white DCLB
    @boogie3478 The inch does make a diff, you ride higher and can see better over the hood. I actually feel like I'm sitting upright in a chair and not with my ass slumped down. I do notice my lower back feels better after driving around for a while. 20 miles back and forth to work is pretty comfortable now. Probably one of the better mods I have done and did on company time with company parts on a Saturday! I love overtime!!:D
    BajaAsh, kgarrett11, Musubi3 and 4 others like this.
