  1. Jul 25, 2018 at 10:35 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Did some trial flexing with my new setup and then some light wheeling because “box canyon” is apparently closed? Locked gates blocking it off. . Sliced up my driver tire thanks to the pinch seam behind it that needs to be hammered flat (but it was already ground down and filed).
    Then, realized my retrofitted projector shroud fell off (it was only JB welded before) I never bought the proper shroud mounting rings and I went too fast on the trail without airing down IMO, so there were more vibrations than normal. Will fix it soon.
  2. Jul 25, 2018 at 10:38 PM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    Then I detailed it. #obsessedgarage
    LamzTaco, Ls Swifty, BajaAsh and 21 others like this.
  3. Jul 25, 2018 at 11:21 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Doesn't air enter from the drivers side? Maybe zip tie some old t-shirt over it unless there's a post on removing that plastic cowling.
  4. Jul 25, 2018 at 11:55 PM
    97WaterPumpGasket
    97WaterPumpGasket Gettin' them groceries
    Portland, OR
    14 TRDS DCLB
    SnugTop Baja wheels, rings removed 265/75-16 Toyo Open Country A/T OME 3" Lift w/Dakkars Warn bumper and winch and bunch of misc small stuff.
    The space seems relatively open to me. Not necessarily drivers side. Maybe the main intake is over there, but it's pulling air (and debris) from the entire cowl space.
    I coincidentally need to remove the cowl plastic to fix the lower windshield trim strip. Bet someone here has already documented that though. If I see an easy way to screen-off the necessary space with silicone and some screen material I'll search/share.
    bagleboy[QUOTED] likes this.
  5. Jul 26, 2018 at 12:32 AM
    Sideways1
    Sideways1 Old Dirt Rider
    Dan
    Portland Oregon
    2015 TRD Sport 4x4 DCLB Pyrite Mica
    ADS 2.5 with Extended travel/ADS 2.5 Piggyback rear. Dakars. Pelfreybilt Aluminum front bumper,Skid and Brute Force Fab HC rear bumper. 5 x SCS Stealth 6's in Matte Bronze wrapped in Nitto Ridge Grapplers. Wet Okole front and rear seat covers. Wilco Bed Rail Tire Carrier. Light Racing Upper Control Arms. Marshall Fabrications sliders with kick out. Mobtown Tailgate Reinforcement Skin. hyper15125 retrofits. And many many odds and ends.
    Good to see another from Portland... I know what your talking about with the trees. I have a reusable cabin filter that I clean every month.
    Be Safe
    Dan
  6. Jul 26, 2018 at 12:37 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    You're right, it wouldnt do any good to filter one area and have the crap enter through another. I just hope you don't have to pull the wipers to get it off.
  7. Jul 26, 2018 at 12:39 AM
    BVita
    BVita Mall Cruiser
    Dialed In! #ogapproved
  8. Jul 26, 2018 at 2:41 AM
    LastShot457
    LastShot457 Well-Known Member
    Aaron
    Ohio
    2012 Magnetic Gun Metallic V6 TRD 4x4
    Window Tint (35% front, 15% Rear), K&N Short Ram Intake, Bushwacker Fender Flares, Fab Four Vengeance Front Bumper, 20" BlackOak Light Bar
    Pushed her a little hard the other day. She wasn't slammed, but she was flexing a bit. Here is a before picture in comparison. And she needs a much needed detail/bath!
  9. Jul 26, 2018 at 4:01 AM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Definitely better stopping than stock. I had put these on my last truck too which is why I went with them again. :)
    medic2230[QUOTED] likes this.
  10. Jul 26, 2018 at 4:05 AM
    Captainskidmark
    Northern Illinois
    Should you ever decide to go with UCAs, take a look at the Camburgs as they have greasable ball joints....
    2WD[QUOTED] likes this.
  11. Jul 26, 2018 at 5:29 AM
    SilverJack
    SilverJack no one
    Regular JB Weld or SteelStik? I use SteelStik to repair plumbing and I've never seen it let go. That stuff pretty much sticks to anything.
  12. Jul 26, 2018 at 6:18 AM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    JB weld
  13. Jul 26, 2018 at 6:25 AM
    CMD-KY
    CMD-KY Well-Known Member
    South Central Kentucky
    2104 Tacoma AC SR5 4wd
    I got one of these. I live in a rural tree laden area. I have never regretted it.
    https://www.autoanything.com/air-filters/kn-cabin-air-filters
    medic2230 and Kuntrykid like this.
  14. Jul 26, 2018 at 6:28 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
  15. Jul 26, 2018 at 6:28 AM
    SilverJack
    SilverJack no one
    Try the SteelStik. I've repaired appliances with that stuff, and it hasn't let me down yet.
  16. Jul 26, 2018 at 6:33 AM
    CMD-KY
    AND your fan will put out an additional 10CFM, your A/C temp will drop by a butt verified 15 degrees.
    Mitch76[QUOTED] likes this.
  17. Jul 26, 2018 at 6:44 AM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
  18. Jul 26, 2018 at 6:53 AM
    CMW_TRD_Sport
    CMW_TRD_Sport Well-Known Member
    Chad
    2014 Tacoma TRD SPORT
    Was 2 seconds late taking this picture!
    Oz Loya, BassAckwards, Grumpy and 7 others like this.
  19. Jul 26, 2018 at 7:11 AM
    Mitch76
    Mitch
    San Angelo, TX
    Is that a 110?
  20. Jul 26, 2018 at 7:12 AM
    GARSHA91
    Chicago
    No sir it is 145
    Twizted likes this.
