  1. Jul 30, 2018 at 4:47 PM
    Bonnie’s Squeeze
    Bonnie’s Squeeze Well-Known Member
    Ross
    Bluffton, SC
    2015 Tacoma TRD Sport DCSB
    Volant CAI, TRD Exhaust, Throttle Body Expansion with vortex, too many others to mention.
    What is the purpose of the cup under the oil filter when it is changed?
    ChadsPride likes this.
  2. Jul 30, 2018 at 5:06 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Cleaned the battery posts , replaced the battery tender cable at the same time.
    TOMB
    Rick_Taco and Cativelense like this.
  3. Jul 30, 2018 at 5:08 PM
    Rd62
    Rd62 Well-Known Member
    2014 DCLB TRD Sport
    The cup catches any spill draining from the filter into it's basin when it's removed.
  4. Jul 30, 2018 at 5:11 PM
    Rd62
    2014 DCLB TRD Sport
    Changed my front diff oil tonight. Front, rear, and transfer case now done. Don't know if or when they were done before I purchased the truck. I've got a baseline now. Rear was really clean. Front was the dirtiest. It was a bitch to get to compared to the other two so I wouldn't be surprised if the previous owner may have skipped it for that reason!
  5. Jul 30, 2018 at 5:33 PM
    "Taco"Tuesday
    "Taco"Tuesday Well-Known Member
    Shane
    Alexandria, VA
    2009 Tacoma TRD Sport DCSB 4X4 (Silver)
    Bilstein 5100s All 4 corners, 885 coils, wheelers 3 AAL with overload spring left in. 17inch p ProComp Rockwells with 265s
    Sitting level with JBA UCA and ome 885 bilstein 5100 and a 1/2 inch spacers ... aal in the rear with 3 degree shims
  6. Jul 30, 2018 at 5:37 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Baked the trans and engine in high temp hill climbs, did the extreme pin stripe mod (previously only had light pin stripe mod), dented the OEM diff skid on a rock, gouged the forged TRD rock warrior wheels on other rocks, scratched the windshield, tested the sliders by taking a good blow that would have otherwise been to the cab after slipping off a wet tree in a flash thunderstorm downpour (wasn’t in the forecast), but made it to an amazing ridge top campsite 30+ miles into the mountains with a 180 degree view for an epic camping trip.
    Edit: further inspection, punctured the Diff skid and bent the oil pan skid.
  7. Jul 30, 2018 at 5:50 PM
    Fox2011PM
    Fox2011PM "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    Gotta pay to play, right? All battle scars are worth the fight. The payoff was killer I bet
  8. Jul 30, 2018 at 5:56 PM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    Looks good. Have a link for the textured body panel tape you used? Thanks
    Sig45[QUOTED] likes this.
  9. Jul 30, 2018 at 6:02 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I don't, sorry. I actually found it at a local hardware store after unsuccessful visits to three auto parts stores. Go figure.
    Bagman[QUOTED] likes this.
  10. Jul 30, 2018 at 6:09 PM
    Bagman
    Area 51
    No worries. Did a search and found several brands but liked the look of what you used.
    Sig45 likes this.
  11. Jul 30, 2018 at 6:15 PM
    Sig45
    Mark
    Maine
    That's precisely why I grabbed it. It has a rougher appearing (but doesn't feel rough/gritty like that non-skid tape) texture than what I had seen online and was shopping for.
    And I opened it up at the store to feel it and threw away the packaging at the register once I realized it would work.
  12. Jul 30, 2018 at 6:23 PM
    SilverJack
    SilverJack no one
    Nicely done and very clean. :thumbsup:
    danielsthomas57 and ChadsPride like this.
  13. Jul 30, 2018 at 6:43 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Some people attach a hose and run it to a drain pan.
    My approach is described below
    Rick_Taco, gabbo2112 and ACEkraut like this.
  14. Jul 30, 2018 at 6:59 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Changed my oil today. I just clipped a Nitrile glove to the nipple with a clothespin.
  15. Jul 30, 2018 at 7:11 PM
    ChadsPride
    Smart!
  16. Jul 30, 2018 at 7:25 PM
    twotone77
    twotone77 Well-Known Member
    Brandon
    Rockford, Illinois
    07 TRD sport DCLB
    I tried using clay bar on the entire truck, then wax after. Very intense process but it looks wonderful. Only complain and concern is it almost appears up close that the clay put weird streak Mark's into the paint that's whiter than the rest, like it wore through the clear coat? I have no idea, first time doing it, I had yellow little rust spots everywhere (or rail dust some people call it). Picture quality is bad cuz it's on a phone.20180730_200330.jpg
    fökai671, sseaman, Rick_Taco and 7 others like this.
  17. Jul 30, 2018 at 7:26 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Installed my ACEkraut no drill plate bracket today. Fit and finish are excellent! Now to get some plugs to dress up the old mounting holes!
    05Taco4x4, olecoot, AFPhi404 and 8 others like this.
  18. Jul 30, 2018 at 7:54 PM
    ColoTacoPrerunner06
    ColoTacoPrerunner06 Truck of my dreams
    Speedway Blue 06 Prerunner built like I like it.
    5.5 lift front 4 rear on 33s with an endless amount more work to do
    Today I swapped the front brakes on my 08 DC prerunner with lifted spindles and found that the upper caliper bolt on the driver side had been stripped out from over tightening. Lucky for me this is not my first rodeo and I found a bolt that was a smidge bigger and got it to recut treads. I will double check it in a few days but it did torque down. I also took off semi metallic junk pads and badly warped and grooved rotors and replaced them with powerstop slotted and drilled rotors with top end ceramic pads.
  19. Jul 30, 2018 at 8:25 PM
    Bigpat_ca
    Bigpat_ca Well-Known Member
    Sacramento, CA
    2014 Spruce Mica TRD off road DCSB
    Have a URL?
  20. Jul 30, 2018 at 8:27 PM
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    What spindles did u go with
