  1. Sep 1, 2018 at 5:22 AM
    JCKDUP
    JCKDUP Member
    Nathan
    2015 Tacoma Double Cab 4WD
    Leveled XspX step bars 20" tis 285/55/20 terra G2 Bull Bar
    Before and after pictures of the controversial raptor grill. Haven’t made a decision myself on preference. Haven’t hooked up led yet. Many people ask if the grill insert will fit in factory shroud and that’s a NO. Totally different mounting style. I had the shroud color matched to my mgm. Any comments ?
  2. Sep 1, 2018 at 6:26 AM
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    Wash your gashole you filthy MF! ROTFL
    o0oSHADOWo0o and TomTwo like this.
  3. Sep 1, 2018 at 6:26 AM
    kydreamers
    kydreamers Well-Known Member
    David
    Franklin, Kentucky
    2005 Black Sand Pearl Toyota Tacoma Double Cab TRD
    I had to remove old peeling window tint the other day from our Chevy Equinox (wife's vehicle). I found a great video on youtube that I thought might help others wanting to remove their tint..hope it helps..
    https://youtu.be/XTmgN18KEx8
    Jsloan128 likes this.
  4. Sep 1, 2018 at 6:27 AM
    olecoot
    olecoot Well-Known Member
    Dennis
    Northeast Fl.
    2021 TRD OFFROAD 4X4
    3 + 1 Pro Comp 285 Falkin Wildpeaks Bed Cap
    No, lazy I guess, I just stick a hose in it when it gets to acting like it needs it jerk the hose out and shut the door. Its gas hole ya know.
    Stryker420 likes this.
  5. Sep 1, 2018 at 6:27 AM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    Is tint easy to install yourself?
  6. Sep 1, 2018 at 6:28 AM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    400w anytime mod with outlet behind the console
    Should keep laptops powered up in mobile office during x-country trip
  7. Sep 1, 2018 at 6:35 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Thank ya my fellow PA brother.
    Kuntrykid[QUOTED] likes this.
  8. Sep 1, 2018 at 7:52 AM
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Got my T case drain plug in the mail. Stock has no magnet so I upgraded to gold plug. Royal Purple going in T case and front diff.
  9. Sep 1, 2018 at 8:07 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    No dice on the tensioner bearing. Chirp is still there at idle, went away if you put it in gear. Im at a loss, it will go to the shop in the next few weeks I guess.
    Rick_Taco likes this.
  10. Sep 1, 2018 at 9:20 AM
    shabbs
    shabbs Well-Known Member
    Mark
    Toronto, Canada
    2014 Tacoma 4x4 V6 DCLB TRD Sport
    Skid plate - added 2014/10/23, Bed extender - added 2014/10/25, Tonneau Cover - added 2014/10/31, OEM Bed Mat - added 2014/11/12, AM/FM/CB AntennaX - added 2014/11/16, Smittybilt 27046B Beaver Step for 2" Hitch - added 2015/01/22, Trimax SXT3 Premium 5/8" Key Receiver Lock - added 2015/01/22, 2 x Grip 30' x 4" Heavy Duty Tow Straps - added 2015/01/23
    Today was min-mod day! Did the following mods:
    - UNI filter mod
    - TRD Aluminum Oil Cap replacement
    - A/C Controls Knob replacement
    Small tweaks.
    EDIT: Pics of the mods:
    39756299_697313773967613_133972507701228_d2e0b95e4df664bdda8a54200986c9d7ea0de78b.jpg
    40173147_948455198695428_212832139800582_90206644101db135d7d0e05e36a59ead23ff1443.jpg
    39504782_485186035225990_526162414351784_8a906dfb99e20e64dec4a3ab3cc842bba3b58b16.jpg
  11. Sep 1, 2018 at 9:53 AM
    olecoot
    Dennis
    Northeast Fl.
    Try taking a small rod of some sort watch out for the fan, and touch it to each piece spinning while the other end is on your ear like using half of a stethoscope to listen. Water pump bushing maybe?
  12. Sep 1, 2018 at 9:53 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    After a 20 minute test run the noise went away. So :notsure:
  13. Sep 1, 2018 at 10:10 AM
    91Enforcer
    91Enforcer Well-Known Member
    Western CO
    2008 Access Cab TRD Off Road
    Went and got everything I need to do an oil change including the oversized filter everyone here seems to recommend. On the way home it dawned on me that I should install a fumoto valve while I'm at it. Long story short, oil change is on hold till fumoto shows up.
  14. Sep 1, 2018 at 10:39 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Finished installing All Weather Flooring in my 2014 DC
  15. Sep 1, 2018 at 10:56 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    That's normal behavior for bearings. They shift in place and noise may go away temporarily; but noise will return. The other bearings to look at include water pump, power steering, alternator and AC compressor.
  16. Sep 1, 2018 at 10:58 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Im reading a lot about a throwout bearing issue. Next time we hear it I may poke my head under the truck.
    Chuy[QUOTED] likes this.
  17. Sep 1, 2018 at 11:18 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Rotated tires . Better than going to the dealer and waiting 2 hours while they screw something up.
    Plus i get satisfaction of maintaining my Tacoma.
    TOMB
    Rick_Taco, BadDNA, Kuntrykid and 2 others like this.
  18. Sep 1, 2018 at 11:18 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Is that (in the pic) to the right & in the background actual houses?
  19. Sep 1, 2018 at 11:23 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    It's refreshing to see someone:
    a) use the word stalagmite
    b) use it properly
  20. Sep 1, 2018 at 11:28 AM
    Chuy
    Lakeside, CA
    Silver Taco
    Installed an UltraGauge last weekend. The selling point over the ScanGaugeII were the confirgurable audible alarms. As much as I try to always take a peek at my gauges as I drive, I find myself going long intervals without looking. The audible alarms give some peace of mind if coolant starts to go high, or voltage drops, etc...
    trailrazer, Rick_Taco, Denk and 2 others like this.
