  1. Sep 2, 2018 at 10:38 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Looks good! How'd you pop them off?
  2. Sep 2, 2018 at 10:44 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Pretty easy!
    - DISCONNECT THE BATTERY!!!
    - Remove the airbag (T30 TORX, 1 per side) Remove the 2 plastic covers and you’ll see them there.
    - disconnect the plugs from the airbag ( take 2 small flat heads and stick it on each side and lift it slowly for each plug...be gentle)
    - You will see 2 screws per control holding it to the steering wheel. Be gentle when prying the controls from the wheel.
    - you will then flip it over and you’ll see for 4 screws, remove them and the bezel will pop off.
    Rick_Taco, Grumpy and TomTwo like this.
  3. Sep 2, 2018 at 11:28 AM
    EKTaco
    EKTaco Active Member
    Emerson
    New Braunfels, TX
    2011 Silver TRD OR DCSB Prerunner
    Avid Offroad front bar, BAMF behind-the-grill bar, 2 6" black oak single row light bars, Weathertechs, tailgate hose clamp mod, tailgate washer mod.....and many more to come!
    Been a long couple days of rust control on the small spots of the frame (Rustoluem Rust Reformer) and Amsoil HD metal protector spray on anything metal on the undercarriage (not the exhaust pipe- Last thing I need is the neighbors thinking the truck is on fire). Though the truck has mostly lived in FL and TX, it found its way up to VA. Been watching cars go by that have lived here longer than me and have been seeing quite a bit of rust up here by my standards anyways. Figured I'd get a jump on it early.
    Also swapped out fluid in the rear diff. I was digging through the receipts in the glove box where previous owner kept record of all work done (great way to keep them...). Truck is just shy of 78k miles. Nope! Never done. The fluid coming out was really nasty. Thankfully no worrisome metal shavings on the magnet. Took if for a drive after the switch and everything felt good.
  4. Sep 2, 2018 at 12:09 PM
    Boylemaker88
    Boylemaker88 Active Member
    Thomas
    Rockledge FL
    2013 Tacoma
    upload_2018-9-2_15-8-18.jpgThought I was going to detail the truck today then a random monsoon decide to interrupt that.... thanks FL!!
  5. Sep 2, 2018 at 12:11 PM
    Bonnie’s Squeeze
    Bonnie’s Squeeze Well-Known Member
    Ross
    Bluffton, SC
    2015 Tacoma TRD Sport DCSB
    Volant CAI, TRD Exhaust, Throttle Body Expansion with vortex, too many others to mention.
    Info on the oversized oil filter please.
    Rick_Taco likes this.
  6. Sep 2, 2018 at 12:22 PM
    Bonnie’s Squeeze
    Ross
    Bluffton, SC
    More info on the Vinyl wrap please. Thinking of that on my Silver.
  7. Sep 2, 2018 at 12:29 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Washed and waxed after a Montana run. And finally did the rear differential breather relocation after having the parts for years :rolleyes:.
  8. Sep 2, 2018 at 12:31 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    What's the details on that camper shell? I really like it!
  9. Sep 2, 2018 at 12:51 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Added some horsepower today.... (painted engine cover ;) )
    Ross09, Valpo, olecoot and 6 others like this.
  10. Sep 2, 2018 at 12:56 PM
    henrilepuf
    henrilepuf Well-Known Member
    henri
    Northwestern Paraguay
    tacoma 2014 4x4 DCLB
    Nothing done to my Taco today.
    But something I 'd like to fix.
    When filling the tank, the nozzle shuts the fuel off, and tank is not full.
    I had this issue on my 2008, and periodically I had to remove and clean this box (see pic); after removing all dust and dirt from it, all became normal again.
    Now, my 2014 Tacoma doesn't have this box.
    I saw on another thread I have to check the ONBOARD VAPOR RECOVERY VALVE, and the DRAIN HOSE CHARCOAL CANISTER.
    I would appreciate any diagram to locate what I have to check.
    Did another TW member fix this issue ?
    Grumpy and 13txtaco like this.
  11. Sep 2, 2018 at 12:57 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Just a basic Leer 100r. I've had it the life of the pickup, great shell.
    MolonLabeTaco[QUOTED] likes this.
  12. Sep 2, 2018 at 1:01 PM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Well this is great.
    I go to install my Cali Raised 52" curved light bar. First of all, the cable that goes from the light bar down the side of the A-pillar is too short. The connector would be outside of the hood, exposing it to rain, etc. But even if it was long enough, the connectors between the light bar and the wiring harness don't match. The pins on male connector are too big to fit into the female connector.
    And the light bar cover? That thing is worthless. Nothing but two strips of black plexiglass with little tiny magnets embedded in them that are supposed to stick to corresponding magnets that you have to superglue onto to light bar. Well guess what? They won't stay in place. The plexiglass will flex a little bit, but the magnets aren't strong enough to hold the cover on a curved bar. I should also note that even if the magnets were able to hold the cover on the bar, it was a half-inch too short on either end.
    So now I'm stuck with a light bar ruined from all the magnets that have been glued it, and won't connect to its own wiring harness, and two completely useless/worthless pieces of plexiglass that I paid $50 for.
    I will NEVER buy from them again. :mad::mad::mad:
  13. Sep 2, 2018 at 1:49 PM
    Boylemaker88
    Thomas
    Rockledge FL
    2013 Tacoma
    Made room for a new garage buddy finally = wife’s car..... Toyota>Hyundai
    gabbo2112, Kuntrykid and ChadsPride like this.
  14. Sep 2, 2018 at 2:18 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I need to look into this. I took my stock skid plate off before installing the TRD skid.
  15. Sep 2, 2018 at 2:35 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Damn, that sucks. I'd definitely look into returning it, since it sounds like it's obviously defective.
    Worse case there's always cutting and extending the harness, and the connectors can be replaced with matching ones. The plexiglas can be made to work by taping it on and heating it with a heatgun to make it take the curve of the bar. However, VA inspection law has changed, and it doesn't need to be covered anymore.
  16. Sep 2, 2018 at 2:36 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I stacked mine like the picture to it gives you a little side protection.:thumbsup:
  17. Sep 2, 2018 at 2:49 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
  18. Sep 2, 2018 at 3:03 PM
    20somethingwidataco
    Will
    Washington State
    My amber "fog" lights I bought from them got condensation in them in about a month. They took care of me and replaced it for free (as they should). The clears are holding up just fine now. Funny thing is, my 50 dollar 32" light bar has been through worse and no condensation. My point, they have great costumer service
  19. Sep 2, 2018 at 3:31 PM
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
    cleaned up after the AOAA trip
    Installed the Powertank
  20. Sep 2, 2018 at 3:42 PM
    R242
    R242 I have a tortoise
    Rick
    Indianapolis, IN
    2024 SR 4x4 6 spd
    Nice pinstripe work:thumbsup:
