  1. Mar 25, 2012 at 7:30 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Rode around, cleaned it up a little, took pics
  2. Mar 25, 2012 at 8:15 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    The wet okoles do have an elastic band, but if you take the inside lid off and tuck the elastic under it and then reinstal it, which is kinda a pain, you get something like this:
    Still slightly visible when it is open, but better then it would be without. Nice work on your cover though.
  3. Mar 25, 2012 at 8:35 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    NICE! if that's what it looks when you tuck it, I would just cut the band, and tack it to the cover with the DAP cement.
    The center console cover has 5 small counter sunk screws on the outside (that panel when you open it), then 4 more screws holding the lid to the bracket that swings. The "popper" has only 2 screws holding it to the lid and is one whole piece, so you don't have to worry about a spring flying out or anything like that, just keep track of your screws and where they go.
    "Nice work on your cover though."
    thanks, that was the third try. did it twice, and strangely the first attempt was the closest until I messed up one corner, after that I got DAP on the fabric outside and it just went downhill from there lol. Thankfully the door panels and other panels will be easier. :D:cool:
  4. Mar 25, 2012 at 8:55 PM
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    I thought about making it permanent like that but decided not to. The arm rests were easy, but definitely use contact cement. 3m super 77 doesn't hold.
  5. Mar 25, 2012 at 9:54 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Or this stuff i get at our local flooring and tile store called wolf grip. Stuff is awsome! Its a spray adhesive but is way stronger then the 3m 77 stuff.
  6. Mar 25, 2012 at 9:59 PM
    NetDep
    NetDep Well-Known Member
    Tim
    Southern Utah
    2011 Toyota Tacoma Off Road MGM
    This reflects the black badging,rmoving LEER and LEER logo from back of canopy, de-decaling, replacement of factory driving lights with PIAA 510's and you can't see the rock lights (Tantum Vision-X) but I will get some @ night...
    I think she is coming along nicely....
  7. Mar 25, 2012 at 10:15 PM
    07TacoRidah
    3m 90 works best, used to use it back when I was in college to paste my work to mat board. Even used it when I redid some speaker fabric in my old blazer. DAP is cool but you only get one chance really, plus you can't put too much on or it will seep through the fabric. With the 3m 90 you have a couple of tries, but it's still the same as the DAP, can't put too much or it will also seep through the fabric.
  8. Mar 26, 2012 at 2:10 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    BUMPER IS PRIMED
    SUB Box is completed and installed!
    Dual Batteries wired up and working
    Front end removed and ready for install!!
    Preview of things to come!
  9. Mar 26, 2012 at 6:22 AM
    Tacolover443
    Tacolover443 Well-Known Member
    Kyle
    Haverford, PA
    07 TRD OR DCSB BSP
    Satoshi, color match grill, 2 Hella 500ff's, rear TSB, yellow "Taco", OEM all-weather floor mats, OEM TRD seat covers, Ultra-Gauge, bed linered rear bumper, Plasti-dipped rims, DuraTrac's,
    :eek: you are busy over there! Looks like it will turn out great!
  10. Mar 26, 2012 at 6:35 AM
    Ryan07
    Ryan07 Well-Known Member
    New Brunswick
    07 TRD DC,LB Sport 4x4
    Icon Ext. Coilovers, LR UCA's, Icon AAL, Nitro 9000 Shocks, 7"Kragen HID's/Billet Grille, Extang Solid Fold Tonneau Cover, Bed Lights, Diff Breather Mod, D-Rings Mod, LED Interior Lighting/Plate Lights, LED 4X4 Switch, Viper Starter, AVH-P4200DVD, PAC Interface, OEM Backup Camera/Pop&lock, Wet Okole Seat Covers, Weathertech Mats, Husky Mud Flaps, 8000lbs Champion Winch/Winch Cradle and Quick Connect Kit, 4,500lbs Champion Winch/Front Hidden Winch Mount, OEM Painted Rims, Spidertrax 1.25, 265/70R17 BFG KO's
    K&N cleaning.
  11. Mar 26, 2012 at 6:57 AM
    TacoDawgs
    TacoDawgs Well-Known Member
    2008 Radiant Red DCSB TRD OR 4x4
    Front 5100s at 1.75. Rear TSB. LoRider tonneau cover. OEM bed mat. OEM bug deflector. Illuminated 4x4 switch. In cab AC outlets. 400W anytime. EGR in channel window visors. Black badges. Rear weathertech liners.
    Awesome. Thanks for the link and again it looks great.
  12. Mar 26, 2012 at 9:28 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    That sucks- I still have one vehicle with a K&N. I like the dry AFE drop in so far in my Tacoma, it looks like it is constructed just like a K&N but with a different element material. But, no more cleaners and oils...:D
  13. Mar 26, 2012 at 9:28 AM
    dmicgrif
    dmicgrif Well-Known Member
    mike
    kihei, maui
    2005, 4x4, 4 door, LB, black all over
    yeah the nosie would come when i would go from 10 mph and faster. pretty loud when i would hit 60 mph. but i couldnt hear anything if i just spun it by hand. but make sure you have a press and a good set of pullers. that will help out so much.
  14. Mar 26, 2012 at 9:49 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Yea it's been a busy couple of days nonstop work since Thursday.
  15. Mar 26, 2012 at 11:07 AM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Did the DIY Washable Cabin Filter today. Bought the filter from lowes for like $20. turned out really well and I am stoked I wont have to purchase a new cabin filter for a while now :) just take it out, wash it, and let it dry! Here is the link for the thread I followed on doing it...
  16. Mar 26, 2012 at 11:35 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Introduced it to a deer running across the road like a bat out of hell.
    Doesn't look too bad until you open the hood and realize both headlights need to be replaced (maybe I can glue the brackets back together), the braces are fucked up, and the driver's quarter panel got bumped enough to rub the bottom edge of the door when I open it.
    Now I need a steel bumper ASAP. Truck needs to pass inspection in a month or so, and there's no way in hell I'm putting my $1,000 deductible into replacing that factory plastic bullshit.
  17. Mar 26, 2012 at 1:13 PM
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    Few weeks ago I installed my new clear headlights.
    Then a week later, these piece of shit cheap headlights fell apart...blinker lenses "fell" out!!!!
    So with the help and advice from TOYOTA TECH31 I took headlights back out, shook them until the blinker lens was at the headlight hole and used tin snips to cut the bastards up. Shook pieces out and tossed them. Then I painted the ends of the blinker wire plug white because these will be exposed now. Then put em back in the truck.
    Not a big fan of the exposed blinker light but i had no other choice really. I wasn't going to bake them!!! The blinker bulbs are chrome and blink white so I don't mind them exposed I suppose.
  18. Mar 26, 2012 at 1:55 PM
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Why were you so against baking them?
  19. Mar 26, 2012 at 2:10 PM
    Oregon TRD
    Ross
    2005 Mall Krawler
    1. I don't have alot of time because I got a new baby at home. So when I work on my truck.....it's when I'm at work and got down time...LOL
    2. These are from EBAY....not sure if I put the bastards in there if they aren't gonna come out in a puddle!! :eek:
    The more and more I go out and look at it......I actually like them without that lens , so i'm cool with it.:cool:
  20. Mar 26, 2012 at 2:16 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    This weekend, I finally finished welding the legs and plates to the 4x innovations sliders then sanded and primed them. I've had them since December lol...I've been too busy lately.
    My welds are getting better.
    I will probably weld them on to the truck this weekend.
