  1. Oct 27, 2018 at 7:51 AM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Ah I meant under those on the beaten pinch weld
    Edit:
    I think I’ll hit it with regular rustoleum paint first, then use the rubberized stuff
  2. Oct 27, 2018 at 8:29 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    All 2nd gen can do super charger on the 4.0L V6
    Big jump in safety features started with ‘09 (along with a-trac, abs based feature that keeps your truck moving forward in slippery conditions)
    TRD OR has coveted but sometimes seldom used rear locker
    05-06 had head gasket issues.
    They will all rust.
    They will all sag at the rear (soft leaf springs)
    ‘12+ had face lift
    ‘13+ (I think) have an annoying secondary air pump but people seem to know a work around their issues (just google it, you’ll see tons of videos on this)
    The newer you get the nicer the infotainment system.
    I’ve owned an ‘09 for several years now, can’t go wrong with it. I do admit that the newer models are always going to be a little nicer.
    Good luck.
    2370, Rick_Taco, Grumpy and 3 others like this.
  3. Oct 27, 2018 at 8:43 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    After 8 years and 130,000 miles, figured it was time for a sexy new radiator cap.
    I had recently changed the coolant and installed new rad hoses and thermostat as well. I’m saving the old cap as a spare, still seems to be in good shape.
    Stryker420, R242 and henryp like this.
  4. Oct 27, 2018 at 9:45 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    From my research today the rubber under coating will only come off with heat gun and scraping, then using oven cleaner/aircraft stripper to get the residue. :annoyed:
    This is going to be a long painful job. then I have to repaint all the metal with rustoleum, THEN i can fluid film it.
    Stryker420 likes this.
  5. Oct 27, 2018 at 10:21 AM
    EKTaco
    EKTaco Active Member
    Emerson
    New Braunfels, TX
    2011 Silver TRD OR DCSB Prerunner
    Avid Offroad front bar, BAMF behind-the-grill bar, 2 6" black oak single row light bars, Weathertechs, tailgate hose clamp mod, tailgate washer mod.....and many more to come!
    First time swapping out the spark plugs. Easy job following the sticky. It is one of those things where you'll definitely get faster the more you do it. Truck seems to idle nicer as the original plugs were still in it and I'm at 80k mileage.
    Rick_Taco, Willyummk and gabbo2112 like this.
  6. Oct 27, 2018 at 10:41 AM
    jafrisi
    jafrisi Well-Known Member
    Tucson, AZ
    14 Superwhite DCSB TRD OR
    Toytec bilstein 5100 lift w AAL. 2.5 front and 1.5 rear. KMC turbine wheels 4.5 bs, BFG KM3s 285/75/16
    Not affected much? That's too much for me and it's not just you driving around alone on the streets. Your, slightly less safe vehicle is sharing the road with others. That fraction of a second lost due to less luminescence may make the difference.
  7. Oct 27, 2018 at 11:16 AM
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    My advice, just leave it. Fluid film over top of it and in a year or two crawl under and scrape off whatever you can and spray another layer of fluid film on. It's not like the rubber itself is harming the frame. It's just that when left on long term it cracks and collects moisture underneath.
    tbr3345 likes this.
  8. Oct 27, 2018 at 11:17 AM
    gottaco?
    gottaco? Member
    jamie
    Ohio
    2005 v6 dbl cab 6 speed 4x4 tacoma
    I upgraded all my interior and exterior to led including headlights. changed the a/c knobs and put Husky front and rear floor mats in.
  9. Oct 27, 2018 at 11:20 AM
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    will the fluid film get into those cracks and fill them? will the fluid film also help dry out the rubber spray?
  10. Oct 27, 2018 at 11:29 AM
    Naumoff42
    Ohio
    2015 TRD Offroad
    The fluid film should seep into any exposed area that it can. It stays as a liquid and never dries out. I can't say whether it will aid in the removal of the rubberized liner though. It's supposed to be safe on rubber gasket material but I've heard people say that it caused door seals to swell so how it reacts to the bedliner would be a toss up.
    Stryker420 and SR-71A like this.
  11. Oct 27, 2018 at 11:47 AM
    Lefkos
    Lefkos Well-Known Member
    Winston
    Las Vegas
    PreRunner
    Trunk or treat mod
  12. Oct 27, 2018 at 11:53 AM
    jafrisi
    Tucson, AZ
    Bummer. Hope everyone is ok.
    gabbo2112 and john2948[QUOTED] like this.
  13. Oct 27, 2018 at 1:49 PM
    Wakecoach
    Wakecoach Kiwi in FL
    Kurt
    2015 White TRD Sport 4x4 2001 Subaru Legacy Wagon Bilstein Touring Edition
    King ext, res/adj...3leaf Aal. ECGS bushing. Bullaculla relocate bracket. Pelfrey bilt skids. TC UCA. K+N, Weathertech Mats, TRD side steps, BROV Tacoma Attic, Prinsu Cabrac, TRD OR Tow Hook
    Put on some Rokblokz (2nd hand TW) and made a set of load panels for the Prinsu to mount the traction boards and gas can.
    Rick_Taco, SR-71A and gabbo2112 like this.
  14. Oct 27, 2018 at 2:00 PM
    Baloo!
    Baloo! Member
    Denton, TX
    2006DCSB TRD Sport
    Finished stabilizer/sway bar relocate after the suspension work a few weeks ago and greased the drive shaft zerks.
  15. Oct 27, 2018 at 2:20 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Cleaned my MAF sensor, then took my son to Target’s Paw Patrol Halloween event. I felt like Target could have done better.
    Rick_Taco likes this.
  16. Oct 27, 2018 at 2:27 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I hate to see this, hope everyone is ok. Truck looks like it can be fixed.
    gabbo2112 likes this.
  17. Oct 27, 2018 at 2:38 PM
    JakeSeig
    JakeSeig Well-Known Member
    Jake
    Georgia
    2006 TRD PreRunner
    Bilstein 5100's, 885, Deaver 1.5" AAL, 285/70r17
    Took it hunting!
  18. Oct 27, 2018 at 3:28 PM
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    Washed and waxed the beast, cleaned some spot on the rear seat from youngest grandson spilling something..Will probably do it one more time before the rain starts saw some water spot on the roof that need to be dealt with. Also notice the Plasitic Dip on right rear Bead lock is coming off, same with left front. So think I will peal it all off and run bronze for the winter and see how I like it. The PO had dipped them at some time in the 27K he owned now at 36K they are showing signs of needing to be redone. Would love to know the owner history of this truck had it for 8 year and 27 K mile Turk was spotless and had the bead locks put on and then dipped them black. Wonder why he got rid of it.
  19. Oct 27, 2018 at 3:48 PM
    King Bouyah
    King Bouyah Well-Known Member
    Ogden, UT
    05 RC Base 5-lug
    Came with MGM topper. Added FJammer stereo. LED Bed lights on AOB Flux Capacitor Switch. Added AOB Spy Mode switch for TBD lighting, stay tuned.
    Passed my frame inspection today. On the one hand, no new frame for me. On the other hand, glad to know my 13year old vehicle is in decent shape.
    Stryker420, tacdriver, TomTwo and 2 others like this.
  20. Oct 27, 2018 at 4:18 PM
    Dylan_ElDoradoCo
    Dylan_ElDoradoCo Well-Known Member
    Dylan
    Pollock Pines, Commiefornia.
    2nd Gen Super White DCLB
    New headlights and fog lights, fog lights as you can see werent even close to matching up so I had to shave some plastic away until everything lined up 20181025_172427.jpg 20181026_173403.jpg 20181026_174337.jpg
    BajaAsh, Rick_Taco, Jonny22r and 4 others like this.
