  1. Oct 27, 2018 at 4:32 PM
    obhuan
    obhuan Well-Known Member
    Tacoma, WA
    09 DCSB TRD OR
    Brought home a tree and gave the truck a thorough wash.
  2. Oct 27, 2018 at 6:02 PM
    76CLE76
    76CLE76 Active Member
    Charles
    Divide, CO
    2011 White Tacoma Off Road and Towing packages
    Aluma coil-overs with 3” lift Toytec 1" body lift Toyota Cat-Back exhaust JBA Standard High Caster Upper A-Arms Spydertrax 1.25" spacers Yokohama Geolander M/T G003, 285/55r16 on stock rims N-Fab Nerf Step Bars
    So, in the end, do they rub at all?
    I have a 2011 TRD OR w/ 3" Toytech Lift and 1" body lift. Currently running 265/75/16 KO2s and wanting to go to 255/85/16 S/T Maxxs. But when I went and measured the current clearance with the worn KO2s (pretty close to replacement time) I found that the front of the front tires at one point in the turn have only 1" clearance.
    The KO2s are 31.7" diameter and the S/T Maxxs are 32.8" diameter. That's a 1.1" inch difference meaning the The S/T Maxxs would need 0.55" more clearance that the KO2s.
    It seemed OK as I still had 1" of clearance with the KO2s. But they are worn not new. So I did some fuzzy math considering the tires had lost about 10/32" (0.31") of tread depth. The fuzzy math says that 1" clearance with the worn KO2s is 0.7" with new KO2s. Which would indicate about 0.2" clearance for the S/T Maxxs. Less than what your picture with the quarter shows but the wheel is only slightly turned.
    But the difference is I'm doing fuzzy math and you have them on your truck!
    Are they rubbing? You said you wouldn't recommend this. Can you elaborate?
    Thanks in advance for answering!
  3. Oct 27, 2018 at 6:31 PM
    Mike714
    Mike714 Well-Known Member
    Cypress, CA
    2013 DCSB Prerunner Super White
    • Got the spark knock TSB taken care of.
    • Replaced my battery and battery terminals.
    • Debadged my truck, only to find out that my passenger door was resprayed at some point (in a slightly non-matching white). Gotta find out how much it will be to resprayed my door. :(
    Rick_Taco likes this.
  4. Oct 27, 2018 at 7:21 PM
    Willyummk
    Willyummk Well-Known Member
    Will
    HA TO CA
    2011 DCSB TRD Sport
    Changed my plugs today at 80k, pervious owner said he changed them but now I'm not too sure...
  5. Oct 27, 2018 at 7:24 PM
    Willyummk
    Will
    HA TO CA
    2011 DCSB TRD Sport
    Looks good man, where did you get the fogs from?
    TomTwo likes this.
  6. Oct 27, 2018 at 7:27 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Pulled my alternator out while I wait for the replacement to get here next week. Fedex needs to drive faster.
    Rick_Taco and TomTwo like this.
  7. Oct 27, 2018 at 7:41 PM
    grlnbear04
    grlnbear04 Well-Known Member
    2015 Tacoma TRD Sport Blue Robbon Metallic
    What plugs did you go with?
  8. Oct 27, 2018 at 7:50 PM
    Dylan_ElDoradoCo
    Dylan_ElDoradoCo Well-Known Member
    Dylan
    Pollock Pines, Commiefornia.
    2nd Gen Super White DCLB
    Carid.com, but I would look elsewhere if you want ones that fit like oem.
    TomTwo and Willyummk[QUOTED] like this.
  9. Oct 27, 2018 at 9:08 PM
    tango zulu
    tango zulu Well-Known Member
    Yukon
    2007 crew cab 4x4
    3 inch lift, 1.5 inch front wheel spacers
    My 2008 taco runs a 3 inch toytech, and ARB bumper. It has zero rubbing issues with BFG KO2-285/70/17 on stock rims and 1.5 inch spacers. Tires are 32.7 inches tall. I did remove the front and rear mud flaps.
  10. Oct 27, 2018 at 9:31 PM
    obhuan
    Tacoma, WA
    09 DCSB TRD OR
    Works great, especially if you have a fancy pressure washer that heats the water. I spray the underbody after every wheeling trip. It's worth owning one!
    SR-71A, TomTwo and gabbo2112 like this.
  11. Oct 27, 2018 at 10:01 PM
    olecoot
    olecoot Well-Known Member
    Dennis
    Northeast Fl.
    2021 TRD OFFROAD 4X4
    3 + 1 Pro Comp 285 Falkin Wildpeaks Bed Cap
    The way you see them here they are considered a firearm. Once mounted to a pole of 18" or longer they are then classified as a tool.
    Stryker420 likes this.
  12. Oct 27, 2018 at 10:07 PM
    olecoot
    Dennis
    Northeast Fl.
    That hurts to look at. I can only imagine.
  13. Oct 27, 2018 at 10:09 PM
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Installed my Foxwing awning from this past GB
    F3BA7DBB-D444-4FE9-8D07-DDC439323BF9.jpg 04C047DB-8C2B-4760-927D-E3F5BC334110.jpg C6F43357-60AE-4C3C-A51E-804A28CEC622.jpg 91F58D52-B087-4D3E-9A8E-7272137EA7FA.jpg
  14. Oct 27, 2018 at 11:36 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Just because she’s covered in pinstripes, scratches and a few dents doesn’t mean I can’t wash and maintain her properly.
    AMMO skin applied to all paint and glass
    Gyeon Trim applied to all faded black plastic.
  15. Oct 28, 2018 at 5:17 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Considering there all ngks they were changed at some point. If they were originals they would be ngk and denso.
    Scooter WCT likes this.
  16. Oct 28, 2018 at 5:19 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Plastic fender wells don't need to be undercoated they are plastic it doesn't rust
  17. Oct 28, 2018 at 5:37 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Definitely looks like there are 3 denso's in there. Top right and bottom left two are denso's the other 3 are NGK's. I would bet the previous owner didnt replace them at all.
    SupraMan and Scooter WCT like this.
  18. Oct 28, 2018 at 5:42 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I have 255/80/17's on mine the 17" equivalent to the 255/85/16's with a 2.5" lift and absolutely no rubbing with on road or off. They're on stock first gen tundra wheels so back spacing can make a difference if you have aftermarket wheels. I have spoken with many that have run the size you want on stock suspension with no rubbing.
    Stock suspension I had minimal rubbing:
    2.5" lift no rubbing anytime:
  19. Oct 28, 2018 at 5:59 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Just got a deer.
    siundon, Rick_Taco, Grumpy and 2 others like this.
  20. Oct 28, 2018 at 6:07 AM
    grlnbear04
    Oh wow!!!! That sucks....
