  1. Oct 30, 2018 at 1:22 PM
    Woolybugger
    Woolybugger Well-Known Member
    Aaron
    2005 blk acess cab trd 4x4
    King coilovers
    I was surprised at how much trimming I am having to do to fit 285 75 16 tires however I cant crank my preload anymore without the shock bodies unthreading on my kings and don't have a large enough spring compressor.
    I know there is another inch of lift in there.
  2. Oct 30, 2018 at 1:32 PM
    JFick
    JFick Sawzall Enthusiast
    Los Angeles
    ‘19 TRDOR 6MT, ‘11 BMW M3 DCT
    Softopper 255/85r16 Yokohama MTs Camburg UCAs King extended travel coilovers King extended travel rear shocks Firestone airbags OME medium duty leafs
    It’s easy until FedEx loses your box full of brake parts, and then tells you they will never find it, nor cover it’s loss. :annoyed:
  3. Oct 30, 2018 at 1:38 PM
    Woolybugger
    Aaron
    King coilovers
    I ship anything of significant value to my parents house because someone is always home after losing a $1300 turbocharger through FedEx and getting nowhere trying to rectify the situation.
    Dylan_ElDoradoCo likes this.
  4. Oct 30, 2018 at 1:47 PM
    Taylor@KC HiLiTES
    Taylor@KC HiLiTES Well-Known Member Vendor
    Taylor
    Arizona
    2010 DCSB TRD OR 4x4
    See build thread
    I'm glad you got them installed and fired up! I'll be in 4 Peaks area on Sat for a trail cleanup, go check out the thread to see if you can make it too!
    https://www.tacomaworld.com/threads/9th-annual-four-peaks-trail-cleanup-nov-3rd-2018.574701/
    orezona[QUOTED] likes this.
  5. Oct 30, 2018 at 2:39 PM
    Mike714
    Mike714 Well-Known Member
    Cypress, CA
    2013 DCSB Prerunner Super White
    Corrado's are great. Had a G60 myself back in the day. Is he on VWVortex?
    That_red_taco likes this.
  6. Oct 30, 2018 at 2:53 PM
    Tamytacoma
    Tamytacoma Well-Known Member
    NEVADA
    2013 Black TRD Sport 4X4
    Daytime shots of my faux pro grill from ebay.
    6D9D0450-A280-4065-849A-114024E0518D.jpg 67ED0576-94E6-4EAD-B5C7-A7D942A24EBD.jpg
    I am keeping my mesh grill for long trips (they’re better bug screen) than the faux pro grill I think.
  7. Oct 30, 2018 at 2:54 PM
    Mike714
    Cypress, CA
    That looks great. Love the lettering. :thumbsup:
    olecoot likes this.
  8. Oct 30, 2018 at 2:59 PM
    Tamytacoma
    NEVADA
    Thank you Sir. Some painters tape on the letter edges and red rattle can paint, and some clear coat. I got impatient with the group buy and I found a US seller on ebay. Shipping was fast, grill and lettering was shipped on the same package.
    Rick_Taco likes this.
  9. Oct 30, 2018 at 4:50 PM
    Dylan_ElDoradoCo
    Dylan_ElDoradoCo Well-Known Member
    Dylan
    Pollock Pines, Commiefornia.
    2nd Gen Super White DCLB
    You should probably ask him about tires, 90% of the time its the tires. Its called chopping common in M/T tires
    Ted Yoder likes this.
  10. Oct 30, 2018 at 5:25 PM
    Buildbigboats
    Buildbigboats Member
    Got a new frame under my '05 DCLB in March along with all the other goodies that come with that job...new brake lines, new leaf springs, etc. I had dealer install Bilsteins and SS brake hoses all around I supplied as well as new bushings they provided. Looks great under there so...today I sprayed the heck out of everything with LPS3 in preparation for another Chicago winter. After checking out FF and some other products I went with LPS3 ($60 gallon to my door...used about 3 qts... bush and spray bottle worked fine). I'll see how it does. Calling for a relatively mild winter. See about that too
  11. Oct 30, 2018 at 5:31 PM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    Installed 2” AAL’s today.
    Just got tired of the weak TSB spring 1.5” drop in the back.
    Now I have an excuse for some 5100’s up front with a slight lift.
    SR-71A likes this.
  12. Oct 30, 2018 at 5:32 PM
    Ted Yoder
    Ted Yoder Well that didn't work
    06 DCLB
    In Progress
    Just saw this. Had a similar issue and I had just upgraded to a stop tech kit so I knew it wasnt the brakes. Pulled a tire off and had it checked for balance and it was fine...inspection of the treads showed uneven wear between every other siping. Rotated all 5 tires...shakes went away...new tires are on the way as well.
  13. Oct 30, 2018 at 5:36 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Not much clearancing to do with that size tire. They work really well. If you have stock suspension you may have to do a little but if lifted (other than maybe removing the mudflaps) probably nothing
  14. Oct 30, 2018 at 5:39 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    That's what I have is the 255/80/17's on first gen Tundra wheels. Good combo
  15. Oct 31, 2018 at 4:05 AM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
  16. Oct 31, 2018 at 4:46 AM
    Tractor Dave
    Tractor Dave Well-Known Member
    South Jersey
    2015 Special Addition Off Road SR5 Black
    2.5 Lift,Special Order Truck
    Clay bared the paint buffed it out , now ready for hunting season and whatever the woods throws at me!
    Tamytacoma, Valpo, olecoot and 2 others like this.
  17. Oct 31, 2018 at 4:49 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    No drill? Will they work with a dc also?
  18. Oct 31, 2018 at 4:56 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Replaced PCV valve. The new one is a little larger than the old one. Old one was 19mm and I don’t have a 20mm socket. A 7/8” socket worked pretty well though.
    Old one is original and has 130,000 on it. Still rattles but looks like hell. Def past time to replace it.
  19. Oct 31, 2018 at 4:57 AM
    TruKnight
    Tru
    Arkansas
    read build thread
    no drill! they make them for dc also, not sure on the exact model number tho. even some for regular cabs.
  20. Oct 31, 2018 at 5:32 AM
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    I have a pair similar to these no drill Rhino towers off my DC. Im selling with a Yakima load warrior basket if you are interested in[​IMG] these.
    Casper66[QUOTED] likes this.
