  1. Dec 13, 2018 at 4:24 PM
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    Thats dope
    topaza[QUOTED] likes this.
  2. Dec 13, 2018 at 4:27 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Details please.
  3. Dec 13, 2018 at 4:34 PM
    the_bluetaco
    the_bluetaco Well-Known Member
    Artem
    California
    2014 TRD Off Road DCSB
    Method Racing Wheels-Double Standards 16x8 Falken Wildpeak AT3W -285/75R16 FRONT: Bilstein 6112, TOTAL CHAOS FABRICATION UCAs REAR: Bilstein 5160, OME DAKAR leaf spring set
    Installed these about 3 months ago and have them set for maximum lift. They feel a little on the hard side since I want the maximum lift but still feel great. Its my daily driver and I'm just as comfortable as I was on the stock springs. :thumbsup:
    ruffridha9 likes this.
  4. Dec 13, 2018 at 4:56 PM
    siundon
    siundon Well-Known Member
    don
    Gulfport ms
    2014 tacoma silver tss
    skide plate, back flip, avs window visor
    whats the brand name and type of your spare I like it
  5. Dec 13, 2018 at 5:02 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    The un matching spare is a Vision turbine 16x8 0 offset. My wheels are FN five stars, 16x8 -25! The vision turbine is for sale. :)
  6. Dec 13, 2018 at 5:03 PM
    BlakeyD
    BlakeyD Well-Known Member
    Blake
    CA
    2012 Tacoma TRD Off Road "Tyra"
    When you say max lift are you referring to notch 4 or 5? My plan is to run them at notch 3. Are you also running 5160s in the rear and what's your spring set up? Thanks
  7. Dec 13, 2018 at 5:22 PM
    nevadawolfe
    nevadawolfe Well-Known Member
    Heather
    Northern Nevada
    2019 MBM DCSB SR “The Boss”
    MESO mod count: 2 Mickey Thompson Sidebiter II’s - 16x8 mattgecko under hood light kit - cool white
    Okay so I could use some of your opinions on this just for consideration... I got to take a look at the truck today. The subfloor is what’s bent, just by the rear driver’s side underseat storage. They had it all torn down and marked, so here’s what it looks like. Shop owner and the service writer both are saying it’s a nice enough build that I should consider keeping it and repairing. Knowing this, and knowing that mechanically the truck is still perfectly fine and only has 46k miles, would you total it or try to repair? 086FB093-8FFE-4F9B-9C37-3CF153A08E22.jpg
  8. Dec 13, 2018 at 5:31 PM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    With that low miles. I would fix it. But i have fixed and drove worse. Most of the vehicles i have owned were from salvage auctions. Do they recomended a new cab or cutting out the whole panel n rewelding a new one in.
    jafrisi likes this.
  9. Dec 13, 2018 at 5:33 PM
    nevadawolfe
    Heather
    Northern Nevada
    They recommended the cut and weld route, since a new cab cost would definitely throw things into totaling territory, and also because it’s a relatively small area that’s affected this badly.
    They also mentioned that welding and reinforcing might actually help to make some of this stronger than it was stock, but I’m not too sure if that’s really something I need to worry about.
  10. Dec 13, 2018 at 5:43 PM
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    Yes if the welds are done corectly it will be stronger. Do you know the shop that is doing the work? I wouldnt worry to much if the shop thinks it wont keep you safe they wont recomend doing it. What is the estimated repair cost. Mine was 9k. But i when to school with the shop owner, repaied alot of his vehicles and built an engine or 2 for him.
    nevadawolfe[QUOTED] likes this.
  11. Dec 13, 2018 at 6:14 PM
    TACO YEET
    TACO YEET Well-Known Member
    Jake
    New York, New York
    2019 TRD PRO VOODOO BLUE
    Hit by his headlights? Blinded? Nice clarification! Class A English.
  12. Dec 13, 2018 at 6:28 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Your name is literally TACO YEET. Your arguement is invalid.
    TomTwo, Matajramon, Naumoff42 and 6 others like this.
  13. Dec 13, 2018 at 6:37 PM
    TACO YEET
    Jake
    New York, New York
    Wid? With? Right back at you.
  14. Dec 13, 2018 at 6:44 PM
    20somethingwidataco
    Will
    Washington State
    True. Cant compete with a pro bro
    JakeSeig likes this.
  15. Dec 13, 2018 at 7:09 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Got My ADS coilovers in at long last after many hours of being a perfectionist. The adjustment collars are a bit corroded so I’m going to take them somewhere local to see if someone can help me get them adjusted.
    With the new springs on, the bumper went on as well. I’m pleased with how the truck looks and rides now. Still a few more projects to go. :welder:
    FB92C76F-5EF3-4D3C-8714-E00A05FA3D3A.jpg BDC8EC5C-1955-4FBC-819A-41235F4229C4.jpg 8E8BEE6A-3018-4384-8ABB-11D455964D6F.jpg 5AB40C93-B85F-41B7-B113-99DF9DD2519E.jpg 9577448B-CCBC-4349-9A57-7F2958B43A09.jpg ECC256C2-F3D2-4C0E-838D-180C181D07D5.jpg
    TomTwo, kalaukoa, DAHOGGS44 and 22 others like this.
  16. Dec 13, 2018 at 7:11 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I need a write up!
  17. Dec 13, 2018 at 7:25 PM
    TACO YEET
    Jake
    New York, New York
    I am just messing around with you. No hard feelings.
  18. Dec 13, 2018 at 8:34 PM
    ruffridha9
    ruffridha9 Well-Known Member
    West Coast
    2012 Tacoma base
    stock ish
    You’ll love them-
    I’ve have them for almost three weeks and I’m a fan.
    What setting you goonna set them to?
    gabbo2112 likes this.
  19. Dec 13, 2018 at 8:43 PM
    ruffridha9
    West Coast
    2012 Tacoma base
    stock ish
    Do it
  20. Dec 14, 2018 at 5:24 AM
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    bro those lower hoops are killer! good idea never seen that before looks good man :thumbsup:
    Supra4x4[QUOTED] likes this.
