  1. Feb 14, 2019 at 10:04 PM
    Meximan61
    Meximan61 Well-Known Member
    Fernando
    Salt Lake City, UT
    2005 Tacoma OR
    Just finished install on my rear view camera. Came out pretty good
  2. Feb 15, 2019 at 12:56 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Jesus..... My topper has been on the truck for presumably 6 years...... I think I might need these....
    Slashaar and whatstcp like this.
  3. Feb 15, 2019 at 12:57 AM
    20somethingwidataco
    Will
    Washington State
    Just feel like I need to write down my To-Do list, not sure why, just how my brain works I guess.....
    ECGS bushing swap
    SEAT COVERS!!!!
    Install my sliders.
    Fix heat shield rattle, and other weird noise I discovered when I give it gas around 35....
    ^ May be related ^
    Spray the under regions to remove dirt and crap from recent snow storm,
    Fix door rattle,
    Side shooter ditch lights?
    Projectors
    Finish Canopy Camper set up and actually camp in it.
    Detail my baby (need warmer weather)
    Inspect frame (Every 5k miles, with oil change)
    Slashaar and Rick_Taco like this.
  4. Feb 15, 2019 at 3:56 AM
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    I should note that I routinely overload the rack on my topper...and often travel off-road that way. Lumber...sooo much framing and Engineered Wood Siding, ladders, canoes and kayaks, as many bikes as will fit (I have 6 trays), all often in combination with a rocket-box full of camping gear or skis or something.
  5. Feb 15, 2019 at 5:38 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Once the bedside goes, its all a matter of time. Keep an eye on it, as the bed stiffeners don't solve the problem. I thought it did, and all of a sudden my tailgate wouldn't open properly, and my tail light was popping out (with wheeling, not just road driving)
    This picture shows how the bed stiffer kept some stuff in place, but the bedside still separated.
  6. Feb 15, 2019 at 5:46 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I have some recent new strange rattly sound but in every gear at certain torque/rpm....scary thoughts are valvetrain, timing chain tensioner. others are bad gas maybe. Working thru easy causes first. Doesn't do it when sitting revving or idling, only when driving with more load on motor. MPG unaffected, pwr unaffected, have searched for rocks in splash pans, exhaust leaks, loose anything under truck......nothing. Odd thing is it seems to have started after oil change so even changed out first batch of 5/20w syn blend for diff batch of 5/20w full syn. Wasn't the oil. Maybe defective oem filter? Haven't swapped that yet. I do fill new filter when doing changes so the motor doesn't have to wait on filter to fill. It isn't overfilled with oil...right on F. Will keep an ear on it and keep driving.....has about 187k miles on it.
  7. Feb 15, 2019 at 5:58 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    I have those in my cart on Amazon right now. I spent some time trying to find the spec sheet on them with no luck. How are they compared to stock?
    I am also looking at the Hella YL, Hella Optilux XY and Osram fog breakers. Osram is the only Spec sheet I can find.
    Love the new bumper, makes the Taco look better IMO. Sleeker slimmer design than the ARB. :)
    I am considering this as well. I am thinking about buying one of the stand alone harnesses that @crashnburn80 developed and then doing the laminex on top. I just need to stop being a tight wad and pull the trigger on something. Buy once, cry once.
    la0d0g[QUOTED] likes this.
  8. Feb 15, 2019 at 6:35 AM
    Dan H
    Dan H Wife thinks I'm having an affair with my Tacoma
    Daniel
    Glendale AZ
    2006 indigo ink PreRunner DCSB- 2012 Venza AWD
    ProComp Pro Runner shocks n struts Painted engine cover Fog anytime mod Cherrybomb muffler Bestop 3/16 tailgate plate and top cap Where do I begin with all the camo
    I had a bad door rattle twice. Both times it was the tweeter came loose. Tighten the screws and good to go.
  9. Feb 15, 2019 at 6:43 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    wow that is real bad misalignment so much for using those bed stiffeners didn't do jack shit
    whatstcp likes this.
  10. Feb 15, 2019 at 6:47 AM
    BillsSR5
    bill
    2014 SR5
    what can you do about using TPMS sensors with those 3rd GEN rims? or not
  11. Feb 15, 2019 at 7:27 AM
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    Added factor55 hitchlink and shackle
    Admired my dash after FINALLY correcting the wiring on my switch panel to dim with the dash
    #tacticleTaco #nightOps
  12. Feb 15, 2019 at 7:36 AM
    CableTec
    CableTec Legend in my own mind
    J-ville and P-ville, FL
    2007 V6 PreRunner SR5 TRD
    See sig.....
    Powdercoated and ready for install!
  13. Feb 15, 2019 at 7:40 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    They helped
    Before
    After
    But over time of bouncing offroad split the bed. Also, I had a contractor cap, rtt, and a toolbox in the side of the cap. So there is a bit of weight.
    Stiffeners help, but they aren’t bullet proof.
    The fix could have been a new bedside. But flatbeds work too.
    GAtaco, gabbo2112, Slashaar and 9 others like this.
  14. Feb 15, 2019 at 7:44 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    They are 55 watt just like the stock. So they put out about the same light....just a very yellow color.
    Rick_Taco[QUOTED] likes this.
  15. Feb 15, 2019 at 7:56 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Also I'll add that I don't love the glare issue, but I wanted the amber light for the same reasons, and the bulbs are $20, as opposed to $320 for the KC LEDs with the reflectors...
  16. Feb 15, 2019 at 8:03 AM
    Rick_Taco
    Rick
    Indiana
    Oh I hear you 100%. I can make $320 go a lot farther in other places, like putting it towards some sort of a suspension lift before I buy new tires this year.
    DarthPow[QUOTED] likes this.
  17. Feb 15, 2019 at 8:04 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You see my new yellow fogs? They run over spec yellow interference H9s while producing less glare with stronger cut offs than stock. You can run this without a harness. Pattern is much brighter but also more forward projecting.
  18. Feb 15, 2019 at 8:12 AM
    Rick_Taco
    Rick
    Indiana
    Oh you know I did! hahaha
    Anxiously awaiting your feed back after your mountain pass snow storm trip that's upcoming.
    crashnburn80[QUOTED] likes this.
  19. Feb 15, 2019 at 8:16 AM
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    What bulbs are those
  20. Feb 15, 2019 at 8:50 AM
    i_holmes
    i_holmes Member
    Ian
    San Diego
    2007 Black Tacoma SR5
    If you haven't yet, you should try the truck in the South Park Target parking lot. Used to live over there and loved their tacos!
    Rick_Taco likes this.
