  1. Feb 23, 2019 at 1:27 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Pulled the third brake lamp to see if I'll be able to install a low profile shark fin for my SAT radio. Nope, too tight in there.
    I pulled some more of the interior to see where I can run wires for the stuff I want to add (lights, cruise, inverter). With the parts out I was able to see what my truck is wired for.
    Nothing, my truck is wired for nothing, except for a small harness for towing (which I wont be using). I found a terminal at the ECM that when grounded, makes the CRUISE light illuminate.
    I might be doing cruise when I add steering wheel controls for my stereo (need to buy a clock spring first).
    I also broke my truck :confused:
    When I went to drive my truck home, I noticed that the shift lock didn't work and the PRNDL lights didn't work either. Turn signals also didn't work. The 10A IGN1 fuse was blown. I have no idea what I could've done to blow the fuse.
    (grounding the terminal at the ECM didn't blow the fuse, it's the correct terminal for cruise according to the EWD I have)
    TOMB, Rick_Taco and Cativelense like this.
  2. Feb 23, 2019 at 1:35 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    They come and off with them I haven't ever noticed if they dim with them I'll go check
    TomTwo likes this.
  3. Feb 23, 2019 at 1:41 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    No they do not dim with them they ony cut on and off with them
    TomTwo likes this.
  4. Feb 23, 2019 at 1:52 PM
    Shearboy2005
    Shearboy2005 It can't stay tight if it's a liquid.
    Ky
    2015 TRD SPORT, 06 PreRunner
    Appreciate it. Hoping to get them to dim. Maybe just overthinking this...or maybe to many adult beverages :anonymous:
    TomTwo and Casper66 like this.
  5. Feb 23, 2019 at 2:00 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    They will be dimmable if you connect them to the right wire. Using a splicer. I connected all of mine to the AC control knobs variable ground. Can't recall which wire but there's plenty of info out there.
    Casper66[QUOTED] likes this.
  6. Feb 23, 2019 at 2:04 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Thanks for the info! I never dim my lights so I haven't worried about it but it's nice to know I can
  7. Feb 23, 2019 at 2:05 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  8. Feb 23, 2019 at 2:09 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Green/white is dimmer ground on the ac controls plug.
    Casper66 likes this.
  9. Feb 23, 2019 at 2:12 PM
    Shearboy2005
    Ky
    So I only need to connect switch to the green white wire?
  10. Feb 23, 2019 at 2:28 PM
    KaptainH
    Kris
    Gainesville, GA
    Yes!
  11. Feb 23, 2019 at 2:29 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Switches have 4 wires:
    Power to supply the switch
    Switch wire to the accessory or relay
    Power to supply the general illumination led(green wire from ac controls)
    Dimmer ground(green/white wire from ac controls)
    The led that comes on when the switch is on gets powered by the switch but both that led and the general illumination led share the same ground and so are both dimmable.
  12. Feb 23, 2019 at 2:33 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    The reason for using the green wire from the ac controls for illumination + is so that the general illumination led comes on with the headlights like the rest of the lights on the dimmer circuit you could use any 12v source but they’d be on whenever it was hot.
  13. Feb 23, 2019 at 2:42 PM
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    Fresh out the wash.
  14. Feb 23, 2019 at 2:47 PM
    Shearboy2005
    Ky
  15. Feb 23, 2019 at 2:52 PM
    shugashane562
    shugashane562 Well-Known Member
    Shane
    Long Beach, CA
    99’ Tacoma Single Cab 5speed
    214BF158-4CB3-4F23-B165-A044062C8D77.jpg 3A9CE450-D52F-4867-BC2E-67F3C9630620.jpg
    Nanoskin, mothers spray way, voodoo 3-1 polish, very happy with the results
    Rick_Taco likes this.
  16. Feb 23, 2019 at 2:56 PM
    ChillyTaco12
    ChillyTaco12 Active Member
    Phil
    '12 TRD O/R Pyrite Mica
    Weather was finally nice enough for me to put the new Softopper on, and did the Uni filter mod while I was out
  17. Feb 23, 2019 at 3:02 PM
    AboysTacoma
    AboysTacoma Well-Known Member
    Michael
    2014 Magnetic Gray Metallic
    Popped in my grill today!
  18. Feb 23, 2019 at 3:08 PM
    hulksquatch
    hulksquatch Member
    2011 tacoma tx pro
    toyo at2, custom rear springs, 5100's, lots of sweet sweet gasoline
    Drove by a stuck Subaru in a 10" snow drift .
    SR-71A, 99kx250, WPNZ and 9 others like this.
  19. Feb 23, 2019 at 3:16 PM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    83C18263-9756-45FC-B84C-3ABDD3055241.jpg Did some garage cleaning today, and put my baby in it. Washing and detailing tomorrow.
    VMMM, Rick_Taco and 13txtaco like this.
  20. Feb 23, 2019 at 3:17 PM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    No you just used to loud vehicles. Peeps keep asking about a noise in the back of the cab. Im like what noise. Its not as noisy as my 93.
