  1. Mar 22, 2019 at 6:16 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I'll get a review/install vid out for their dash set soon too.
  2. Mar 22, 2019 at 6:32 AM
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
    Curious as to how this works? were you having charging issues/lo voltage b4 etc...
  3. Mar 22, 2019 at 6:38 AM
    wmg
    bill
    2009 FJ
    I have had one for a year or so....it does most of what the claims are...to be honest the only time I use it is off road.....in my opinion in that respect it is great..in the ecno mode I can get small throttle response stretched out over a large portion of pedal movement which gives great crawl control.......
  4. Mar 22, 2019 at 7:43 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    No it was working as designed for the stock wet cell battery but I switched to a AGM because of winch and off-roading so needed higher charge voltage.
    The diode instead of the fuse makes the truck think there’s a voltage drop and raise output
    05Taco4x4 likes this.
  5. Mar 22, 2019 at 8:54 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  6. Mar 22, 2019 at 10:06 AM
    danielsthomas57
    danielsthomas57 Well-Known Member
    Thomas
    Virginia
    2013 Super White TRD Sport DCLB
    5100s, OME 887 and 1/4" pacer, 285/75/17s
    I dropped off my shift knob and center console cover Wednesday and got it back today. I very pleased with the wrap and the storm trooper theme continues! Can’t wait to get the custom 3D printed inserts to bring everything together. 2090640B-C059-47DA-86D8-07467174A192.jpg
    mccombsworld, 13txtaco, DocD and 12 others like this.
  7. Mar 22, 2019 at 10:41 AM
    Brewnmn
    Brewnmn Well-Known Member
    2014 4X4 Reg Cab
    Did a simple phone mount.
  8. Mar 22, 2019 at 11:37 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    I installed the Autovox M1 rear view camera and monitor. The unit was just under $50 with free shipping. I purchased it mainly so I could keep an eye on my trailer while hauling my motorcycles. Instead of wiring it into the reverse lights I wired it to a toggle switch (that I've had forever) and installed it and the monitor in the cubby just below the HVAC switches. The monitor was about the same width where it fit in between the cigarette lighter and aux power humps, so it not going to move around. My son asked why I mounted the camera off center. My reply was, because the access hole to lower the spare tire is in the center.
    BTW - in order to get a clean install I took out the passenger seat and center console.
    Another thing to mention, I have LED spot lights mounted for additional backup lights. The spots are the wired to a toggle switch next to the side mirrors control. I first tapped into the power wire for the spots thinking a could just use the same toggle switch, saving me a lot of time. It worked, except that there were horizontal interference lines on the monitor. So I tossed that idea and hooked up separately.
    azshooter40, 13txtaco, Dan H and 7 others like this.
  9. Mar 22, 2019 at 12:55 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Where'd you order that from?
    JKU3000 likes this.
  10. Mar 22, 2019 at 12:59 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Tried to install all 3 of my new @SOS CONCEPTS steel skids but ran out of energy (thanks to 72 night shift hours in the last 8 days). Drilled the pilot holes needed for the last skid (transfer case/exhaust but didn’t have the energy to open up the holes as needed for the carriage bolts. Very happy with the fit and heft of these babies. Will definitely be giving them a lot of love on Monday (wheeling crown king).
  11. Mar 22, 2019 at 1:00 PM
    boostedka
    James
    NM
    Replaced my OEM badges with some dark grey vinyl ones from cboy
  12. Mar 22, 2019 at 1:26 PM
    AboysTacoma
    AboysTacoma Well-Known Member
    Michael
    2014 Magnetic Gray Metallic
    Put some new front rotors and pads on the Taco yesterday!
  13. Mar 22, 2019 at 1:27 PM
    Dawdaw808
    Dawdaw808 Well-Known Member
    Dean
    Oroville, Ca
    06 Silver Tacoma
    3" pro comp
    Probably going to have to do this soon. What brand did you go with? Cost?
    AboysTacoma[QUOTED] likes this.
  14. Mar 22, 2019 at 1:33 PM
    wmg
    bill
    2009 FJ
    ok kinda thought along those lines... i run - 2 Odyssey 35-PC1400's - but went with the OEG kit etc..so didn't need to go that route....tnx bill
  15. Mar 22, 2019 at 1:42 PM
    AboysTacoma
    Michael
    Yea my brakes were done, so i just decided to get new rotors as well. I went to brakeperformance.com and got a good deal. I spent about $180 for a whole new set!
  16. Mar 22, 2019 at 2:02 PM
    wilson704
    wilson704 Well-Known Member
    Wilson
    2013 Tacoma
    link for the brake system? need to do mine soon too!
  17. Mar 22, 2019 at 2:25 PM
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    ive always heard drilled/slotted rotors are not the best for off road applications due to mud/rocks/debris getting in the holes slots. what's your take?
    Stryker420 and wilson704 like this.
  18. Mar 22, 2019 at 2:34 PM
    TigerTacoma
    TigerTacoma Well-Known Member
    Upstate South Carolina
    ‘14 MGM Access Cab 4x4
    Dobinson’s coils and shocks. SOS sliders, ditch light brackets, and front skid. Rigid ditch lights. BFG KO(dos) More minor stuff.
    I had to take it in the week after I bought it for tpms sensor and they were acting like I was crazy for not letting them change them. Funny it’s certified preowned and they didn’t change them a week before when they certified. So far not super impressed with certified. They also let it go with no rear bump stops.
    Sweston likes this.
  19. Mar 22, 2019 at 2:41 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    me too, bought a certified used truck they sent it out with a leaking front strut but their paperwork shown it as ok, had to pay a $50 co payment and went to 3 dealers before it was replaced and they only will replace the leaking one not both as they will tell a customer to do, also no alignment I found out latter,
    Sweston and Zac of all trades like this.
  20. Mar 22, 2019 at 2:55 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Why group 35 batteries?
