  1. May 12, 2019 at 6:32 AM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Giving her a look over today to order some cleaning/de-rusting supplies. Wisconsin winters are hell! Any thoughts for aluminum corrosion on my shocks? And this is after a very thorough fluid film application.
  2. May 12, 2019 at 6:34 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Cool when did you leave we have been here for going on n 28 years
    wmg[QUOTED] likes this.
  3. May 12, 2019 at 7:05 AM
    Dmeezy333
    Dmeezy333 Well-Known Member
    2015 White Tacoma TRD Sport
    Hit 40,000 miles! Did an oil change and change the Air filter. Also shined her up. 20190511_160755.jpg 20190511_160755.jpg
  4. May 12, 2019 at 7:07 AM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    So this turned into a big FAIL this morning. I ended up having a bubble that I was trying to push out and the vinyl wrinkled and got damaged. At this point I'm just going to paint it.
    If I was to try it again I would do 2 things differently. 1. I left the vinyl out in the unheated garage last night. While it wasn't necessarily cold, it was cool enough that the vinyl was kind of stiff even though I was using a hairdryer to warm it up to stretch it out and I think if it had been a bit warmer this might not have been the case. 2. I would have reinstalled the grill insert into the surround to stiffen the surround out some. This would have made it a bit easier to stretch the vinyl over the surface.
    llamasmurf, Kuntrykid and Austinguy like this.
  5. May 12, 2019 at 7:16 AM
    SpeedwayBlues
    SpeedwayBlues Well-Known Member
    '07 Speedway Blue Double Cab Long bed
    Sound system (in work)
    Vinyl can be tricky. Never used that brand but I've found that 3M Scotchprint is a lot easier to work with than since off the cheaper stuff off Amazon. I'd use a heat gun instead of a hair dryer because the hair dryer blows too much air. You've got to be careful with the heat either way because you can warp the vinyl if you leave it in one spot too long
  6. May 12, 2019 at 7:29 AM
    vtbunisher
    vtbunisher Member
    Peter
    Vermont
    2014 Spruce Mica Tacoma TRDOR
    Finished installing the TRD Pro lift kit and headstrong AAL this weekend. Alignment scheduled for tomorrow
  7. May 12, 2019 at 7:50 AM
    Badderup
    Badderup Well-Known Member
    Colby
    Utah
    2006 SWB TRD sport DCLB
    I saved it and use it as a computer wallpaper.
    Kuntrykid likes this.
  8. May 12, 2019 at 8:11 AM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    NICE!!!!
    gabbo2112, 13txtaco and BVita[QUOTED] like this.
  9. May 12, 2019 at 10:05 AM
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Nice! Wheel and tire specs?
    Austinguy likes this.
  10. May 12, 2019 at 10:09 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Figured out my wiring for the navigation/camera/Bluetooth/cruise.
    Now I need to start making connections after seeing how long the wires need to be.
    When that's done I can start the wiring for my CH4X4 switches.
  11. May 12, 2019 at 11:04 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Over the past 2 weeks installed OME 95R leafs, new shackles w/Dobinsons greaseable bolts and U-bolt flip w/Timbren bump stops.
    2 out of 3 leaf spring bolts are now Dobinsons. Top (3rd) bolt rubbed on the shackle mount when flexed so they got replaced back to OE.
  12. May 12, 2019 at 11:47 AM
    fasteddieyj
    Ed
    Hanover, PA
    I would have actually used some 3M material but they didn't have any in matte black that was 1.5 feet wide. I was afraid the 1 ft wide pieces were going to come up just a hair short.
    I have a heatgun but I read that for a first timer a hairdryer might be a better idea since it should be a little more forgiving since the air wouldn't be quite as hot.
  13. May 12, 2019 at 11:59 AM
    SpeedwayBlues
    Yeah, just gotta hold it further away and move it around more
  14. May 12, 2019 at 12:27 PM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    Cleaned up the rear and gave a coat of paint on the drums today.
    WPNZ, Musubi3, dpele and 16 others like this.
  15. May 12, 2019 at 12:36 PM
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    Damn man that truck is clean! So jealous mine looked like that for about 5 minutes back in 2010 north east eats our vehicles!
  16. May 12, 2019 at 12:40 PM
    TacoCasa
    TacoCasa Well-Known Member
    Tim
    The 719
    2013 Black Tacoma OR DCSB
    Bilstein 6112/5160, Camburg UCAs, HD Dakars, Uni filter, diff breather relocated.
    Did a spare rim mod (wheeling with no spare tire = highly-inadvisable). Spare tire got stolen not too long ago, so looking to get 5 new tires for a 5-tire rotation soon. See-saw flex to see rear flexibility :D
  17. May 12, 2019 at 1:13 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    "R"?
  18. May 12, 2019 at 1:44 PM
    rnish
    Tacoma 2nd gen
    My first initial, what's left over from the TRD decal.
    Kuntrykid[QUOTED] and whatstcp like this.
  19. May 12, 2019 at 1:57 PM
    Colchester-Taco
    Colchester-Taco Member
    Tacoma TRD
    Had the TRD Beadlocks installed yesterday and I love them! I am running new TPMS sensors all the way around so I just have to do the clone switch and swap to the stock wheels with studded General Grabber AT2s when the seasons change. Grabbed BBQ on the way home for dinner and found this beautiful classic car :D
    These wheels are PTR1835090
    The lug nut kit is PTR27-35100
    The TPMS are PTR42607-06012
    Tire size is 265/70R16
  20. May 12, 2019 at 2:00 PM
    jkuniverse
    Arlington TX
    Thanks @gabbo2112! I need to drive my truck more instead of cleaning it lol.
    gabbo2112[QUOTED] likes this.
