  1. Jun 8, 2019 at 2:07 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I had my truck on a lift today.
    Greased the upper control arm bushings and installed the sway bar relocation brackets.
    No more noise, I think it was the bushings more than anything. I checked the sway bar and springs before installation and didn't see any signs of rubbing.
  2. Jun 8, 2019 at 2:31 PM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    Sometime ago I upgraded my system but kinda halfassed the wiring. So bored today, I revamped the area behind the backseats. I laid dynamat back then but didnt like the look so I carpeted the back wall, cleaned up the wiring and organized some. Not bad for crap I had left over from other projects. 20190608_141544.jpg 20190608_141522.jpg
  3. Jun 8, 2019 at 2:34 PM
    trdlv2015
    trdlv2015 New Member
    North Las Vegas
    2015 Silver Tacoma TRD OR
    I got new shoes put on the truck today... Cooper Discoverer AT3 4S.... I am really happy with how they look on my truck... glad I made the decision to keep the black side out....
  4. Jun 8, 2019 at 3:07 PM
    Fixxxer
    Fixxxer Well-Known Member
    Port Angeles
    '13 TRD Sport DCLB Super White
    ARB Front/Rear Air Lockers, Nitro Gear 4:88's, Hutchinson Rock Monsters, SOS Concepts Front Aluminium Bumper, UpTop Overland Alpha XL Roof Rack, ARB Snorkel, AVS Rainguards, Redline Hood Struts, Weathertech Mats, Flyzeye led's, MESO Molle Rack, Meso LED Dome Light, K&N Air Filter, UNI Filter Mod, Bosch Wiper Blades, Snugtop Sportster Reinforced Canopy, Viper 2-Way Remote Start, ARB Twin Compressor,
    Today was a good day.
    Complete BP-51 suspension system with SPC UCA’s installed a couple weeks ago.
    This was a pretty easy install. Just took my time. Mounting the front reservoir brackets was a pain.
    35F8AE30-60FE-47C8-978D-6C2DA4E3ECCA.jpg BEE492A8-A0E9-45D8-AC02-505426FB2A65.jpg 7589C345-8A6C-44CC-BA64-23091B32C628.jpg 7E3985A8-7E27-4AE6-BC4B-4C8BC7D8C5D5.jpg
    Wheels mounted with balance done. They had to add 9.5-10oz of weight to balance the tires :eek: This was due to possibly the way I mounted the tires and also the wheels apparently are not exactly round.
    I love the way it turned out.
    So far I have only had to do minimal trimming to the lower corner of the fender flares, removed he mud flaps and have done the CMC.
    I will heat gun and remold the wheel well liners to add more clearance and need to adjust the front struts to gain more lift.
    Widows 5% tints all round except the back.
    E4FA4E2F-6BD3-4103-A273-F5E528123147.jpg 20378BCB-40A8-4A3C-A4B6-27F9A59E6B80.jpg
  5. Jun 8, 2019 at 3:15 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Almost forgot. I also did the diff breather mod. But I didn't put it near the gas cap or behind the taillight. I only extended it so it sits higher. I took about a 20" piece of hose and ran it along the brake hose.
    Kuntrykid, Turdyota3000, TOMB and 3 others like this.
  6. Jun 8, 2019 at 4:12 PM
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    Pulled the seats and Rug Doctored the carpet, seats and headliner.
  7. Jun 8, 2019 at 4:18 PM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Go vinyl and just use a garden hose than quicker.
    JimIowa[QUOTED] and Kuntrykid like this.
  8. Jun 8, 2019 at 4:21 PM
    Old Swamper
    Old Swamper Tacoma World Poor
    Will
    Northern WI.
    2012 Black Tacoma TRD OR
    5100 & OME 884 AAL
    23814643-409F-40E9-AD68-3214D1D191CB.jpg DFCB0A41-3B07-4A4E-9148-DE5A7E12CC1E.jpg BC864ED6-5E71-4FAC-8F84-CDBD078A7A27.jpg
    Some afternoon fun. Had to pound some dents out. Some sanding and 4.95 in International Harvester Red paint and I gained 5 horsepower and 3 MPG.
  9. Jun 8, 2019 at 4:31 PM
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    Placed an order for some custom stage III Deaver springs for my 6” lift and added some patches to the new collection
    irayfz6, Beretta4x4 and Kuntrykid like this.
  10. Jun 8, 2019 at 5:02 PM
    07sr5
    07sr5 Well-Known Member
    2007 4x4 Double Cab
    3AEBDECD-FC41-4678-9C4C-B593E170B5EF.jpg Finally got some decent wheels put on.
    icky crane, siundon, 99kx250 and 5 others like this.
  11. Jun 8, 2019 at 5:10 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    What's the story to search & rescue on the door?
  12. Jun 8, 2019 at 5:12 PM
    HumanityForPresident01
    HumanityForPresident01 Let 'er eat
    Trevor
    2006 Dark Blue Tacoma V6 SR5 EXT Cab TRD Off Road
    2.5" rancho 9000xl lift with UCA's, custom rock sliders, custom rear tube bumper, road armor front bumper, k&n air intake, winch, lights etc.
    I finally mounted the rock sliders i built [ask me how i made them if you like] now i just need to paint them black!
    20190608_094844.jpg 20190608_102132.jpg 20190608_103403.jpg 20190608_103417.jpg 20190608_090626.jpg received_2198980663526906.jpg
  13. Jun 8, 2019 at 5:13 PM
    Trevor
    Hey wi buddy! Im by la crosse, cheers!
  14. Jun 8, 2019 at 5:30 PM
    Jonas
    Jonas Boogerrrrrr!
    Springfield, OR
    05TRDSport
    Coffee went down the wrong pipe, instantly spewed all over dash and window....:annoyed:
  15. Jun 8, 2019 at 5:30 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    ATO shackle flip to BAMF hangers conversion:
    5F60ADBA-0E52-41A0-ABDF-55B7DF37C202.jpg 75289C69-3F85-4277-9E2A-45DC3C924642.jpg A2B7044B-3898-4560-858F-61BA49DA5DE8.jpg 0EDCCF15-9F39-4FDC-9F31-D730F1B1E0CB.jpg
    Building a "DIY" crossbrace
  16. Jun 8, 2019 at 5:34 PM
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    Ahh please share how you made them man looks awesome!
    Kuntrykid likes this.
  17. Jun 8, 2019 at 5:41 PM
    pherret
    pherret Member
    2021 White Tacoma DCSB OR
    Too busy for pics, but installed a red/white emergency light on the roof. Drilled a hole in the bottom lip of the 3rd brake light to route the wire and siliconed it up. Ended up basically drilling a channel most of the way back on that bottom edge of the lens so the wire had room to flex for the bend outward. Ran the wiring down the left side of the sliding window, behind the rear seat storage, then under the carpet around to the the drivers door and across the floor to the center console where my siren/switching is hidden. I unbolted the rear bolts of the front seat and used a dowel to fish the wires over to that hole in the carpet, then reached down to snag them under the center console, then coaxed everything further back so it was entering that space from the rear of the console. If I knew I was going to the door side anyhow I probably would've just cut across the headliner and down the B pillar and across under the seat. Might change it latter.
    Also installed some LEDs. Fog light switch bulb was dead so one went there (I ordered both amber and white - trying amber first, will judge the brightness tonight.) Another went into transmission position panel in the center console. Last ones replaced the 3rd brake light and license place bulbs.
    Rick_Taco and Kuntrykid like this.
  18. Jun 8, 2019 at 5:45 PM
    Fixxxer
    Port Angeles
    I am a Clallam County the Search And Rescue member. One of the uses for my truck.
  19. Jun 8, 2019 at 5:53 PM
    Trevor
    Thank you!!
  20. Jun 8, 2019 at 5:55 PM
    Kuntrykid
    Jon
    Sharpsburg, MD
    Kool. Taco rescue development!:taco:
