  1. Jul 14, 2019 at 2:49 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    The hood straps work great.
  2. Jul 14, 2019 at 2:55 PM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    WoW Great Information, I am going to do some research, Thanks again for taking the time to post!!
    Rick_Taco likes this.
  3. Jul 14, 2019 at 3:11 PM
    DoVeR TaCo
    DoVeR TaCo Rather b lost in the woods then found in the city
    Greg
    Dover Pa
    98 sunfire red SR5 extcab 4x4 MT, 99 4runner 4x4 now 09 SR Pyrite Mica 4x4 double cab
    Kuntrykid, lo2hi, theolee and 7 others like this.
  4. Jul 14, 2019 at 3:32 PM
    Pizzasteve5717
    Pizzasteve5717 Well-Known Member
    Steven
    Marietta, GA
    2005 Tacoma TRD prerunner
    Nothing YET, BUT guys I did a thing today..
    Rock sliders and bed rack? Coming right up! (Well not really still need to buy the material also need to figure out how to get a clean weld lol) 20190714_182542.jpg
    Kuntrykid, lo2hi, AugustaTaco and 4 others like this.
  5. Jul 14, 2019 at 3:38 PM
    cedarpangolin
    cedarpangolin So country I bleed cedar sap.
    Christian
    2015 Tacoma Access Cab 4x4 2.7L
    1.5" wheel spacers, 2.5 front and 1" rear leveling kit, AFE Dry drop in filter, Thrush Glasspack Cherry Bomb exhaust, Falken Wildpeak AT3W tires Soon to be: bully aluminum side steps, plastidip emblems
    Painted the skid Plate red. Yeet
    E-Paz 732NJ, Kuntrykid, lo2hi and 9 others like this.
  6. Jul 14, 2019 at 4:14 PM
    HumanityForPresident01
    HumanityForPresident01 Let 'er eat
    Trevor
    2006 Dark Blue Tacoma V6 SR5 EXT Cab TRD Off Road
    2.5" rancho 9000xl lift with UCA's, custom rock sliders, custom rear tube bumper, road armor front bumper, k&n air intake, winch, lights etc.
    I can tell you how to get a clean weld.
    Grind to bright shiney metal. One amp per thousandth of material. Your weld should should sound like bacon frying - a nice sizzle sound.
    Im a welder, trust me ;)
  7. Jul 14, 2019 at 4:18 PM
    Grumpy
    Grumpy My 1st Tacoma
    Maurice
    Oahu, Hawaii
    14/DCLB/V6/4x4/SR5
    17" Method Grid Titanium rims w/ Pro Comp Sport A/T 265/70/17 tires, Mobtown Offroad ribbed Tailgate skin, installed LED lights in painted rear bumper black, faux TRD grill, color match grill surround. LEDs in map, license plate, center console, and dome lights. Anytime driving lite mod, debadged, vent visors, AA Maglite mounted under center console armrest. Antitheft hose clamp on tailgate, LED bed lighting kit. LED spot lights in lower front bumper. Weathertech floor mats. Painted various interior parts black, homemade 7 pin relocation bracket, Valet under door LEDS, CMC, SPC UCA, Bilstein 5100, OME 885, Headstrong AAL. Pop&Lock.
    Willyummk[QUOTED] likes this.
  8. Jul 14, 2019 at 4:21 PM
    Pizzasteve5717
    Steven
    Marietta, GA
    Advice taken! Thank you buddy, I'm looking at where to buy material as I type this I've always wanted to learn to weld im excited!
    Kuntrykid likes this.
  9. Jul 14, 2019 at 4:22 PM
    Pizzasteve5717
    Steven
    Marietta, GA
    Also what ga is best for the sliders?
  10. Jul 14, 2019 at 5:00 PM
    Trevor
    Definitely get some scrap metal and practice your welds before you start welding on your piece. Your welds should have a silver line on the toes [edges]. Thats the fusion line on the edge of your weld puddle. It means your weld was hot enough to substantially melt the metals together.
    You want a balance of penetration and build up, so hot enough where your arc digs in a good 1/16"-1/8" and you have enough wire to fill in the hole you burned.
    It takes messing with.
    Make sure you dont weld over liquid or oils at all. itll give you a weak weld filled with porosity [pin holes where the evaporating liquid got trapped in the metal] porosity not only looks unprofessional, its asking for a crack to form.
    I hope some of this helps!
  11. Jul 14, 2019 at 5:10 PM
    Trevor
    Ive seen a lot of ones you can buy .275 or .250 dom tubing.
    I personally used 1 1/4 sch 40 pipe. They are heavy!20190622_135044.jpg for mounting feet if you want to use a hi lift on sliders, youll need to use angle on atleast two of the posts.
    Mine i thought id be good without and they flex a bit so im going to bolt angle on the inside of the frame. The bolts will go through the slider feet, frame, then angle. As well as a bolt through the bottom of the frame up through the angle - thats where the strength comes from. Toyota frams are only 1/8" thick.
    For mounting bolt holes you should do like i did, one in a top and a bottom corner so the frame can flex.
    Anything else let me know - ive learned a lot of tricks in a fab shop!
  12. Jul 14, 2019 at 5:11 PM
    reidkm
    reidkm Does lifting my truck increase my boto size?
    Reid
    Hilo, Hawaii
    2015 Tacoma, 4.0V6, 4x4 SB
    6" RC Lift Kit, Bilstein 5100 Full length shocks front and rear, OME 883 Coils, SPC UCA's, 285/70/17 Cooper STT Pro's
    Just sold the truck and bought a 6.7 Cummins :/ sad to see her go but here is a list of all the mods.
    6" RCX drop bracket kit
    Bilstein full length adjustable coilovers
    Full length bilsteins on the rear
    SPC LR Upper control arms
    Deaver leaf pack
    Hostile 20x12, Toyo Open Country MT 33x12.5
    East coast clamshell bushings
    NAPA gold CV axles
    Bora 1.25" hubcentric wheel spacers
    That's my full mod list...
    Farewell tacomaworld
    crank808, lo2hi, Corny Taco and 7 others like this.
  13. Jul 14, 2019 at 5:16 PM
    Trevor
    Daaaaaaaaaaaaaannnnnnnnnggggggggg!
  14. Jul 14, 2019 at 5:24 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Had a very productive day. Got both diffs in fully mounted. All I’m waiting on are new crush washers and a new passenger side CV seal, which arrive tomorrow. I’ll finish those up, and then only be waiting on new lca bushings to arrive.
    I also got out the bushings I managed to fuck up. Just need to repaint them because I managed to fuck it the paint a little from getting so goddamn angry at them and not being gentle.
    Pressed in the new king lower bushings, which was a piece of cake and fit perfectly.
  15. Jul 14, 2019 at 5:52 PM
    Trevor
    Right on buddy. What was goin on with the diff?
  16. Jul 14, 2019 at 5:52 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Regeared to 4.88! I seriously can’t wait to drive this thing on new gears. It’s been a long time coming.
    buyobuyo, Rick_Taco, Casper66 and 2 others like this.
  17. Jul 14, 2019 at 5:53 PM
    Trevor
    So whats your new top speed then?
    Grumpy likes this.
  18. Jul 14, 2019 at 5:56 PM
    Cash13
    Cash13 Well-Known Member
    Northern Colorado
    2014 Tundra
    Thanks to @nats for the hook up on the white bumper. No more chrome!
    Kuntrykid, nats, JackCrank and 13 others like this.
  19. Jul 14, 2019 at 5:57 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Hell if I know, definitely slow. I likely won’t be cruising any faster than 70 on the highway.
    Kuntrykid and Casper66 like this.
  20. Jul 14, 2019 at 6:11 PM
    Trevor
    Yeah sounds about right but its not a race truck. I have to keep telling myself that too.
    41,912 messages... Golly boy! :eek::D
