  1. Aug 11, 2019 at 11:47 PM
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    Took my little girls to a big parking lot for bike riding lessons. Older girl is starting to get it and my younger one she’s learning to pedal..lol
  2. Aug 11, 2019 at 11:56 PM
    Ross09
    Ross09 Well-Known Member
    Greeneville,TN
    2009 DCLB base 4x4
    Some generic lightbar that was already on the bumper when I traded for it. The amber squares are just covers that clip on.
    Kuntrykid likes this.
  3. Aug 12, 2019 at 12:09 AM
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    I noticed Im kicking up a crap ton more stuff with the durty fives too. And at only $50 bucks was a no brainer for me.
  4. Aug 12, 2019 at 12:26 AM
    2DaMtns
    2DaMtns Well-Known Member
    2011 TRD Sport DCLB in MGM
    Lift, tires, stuff
    Changed this....
    To this...
    Gonna sand it again and hit it with matte. This was satin and it looks terrible.
    irayfz6 likes this.
  5. Aug 12, 2019 at 12:38 AM
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    what is that?
    Gunshot-6A and LamzTaco like this.
  6. Aug 12, 2019 at 6:06 AM
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
    AT or manual? I jusr went to 4.56 to replace the 3.73's..(AT)...about 150 miles left to 1st lube change but what a difference in driving...need to get thru the week and the lube thing then its off road weekend...cant wait to lay on it and see how it does....have you got some time on urs and what do ya think of the 4.10's? I hard a hard time deciding which ones to go to......
  7. Aug 12, 2019 at 6:09 AM
    wmg
    bill
    2009 FJ
    cause it sounds cool and sells....
    fasteddieyj and TegoTaco[QUOTED] like this.
  8. Aug 12, 2019 at 6:23 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    a/t
    i have about 20 miles on it. I've also got 285s. I like how mild of a change it is. didn't want high revs on the freeway.
  9. Aug 12, 2019 at 6:45 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    The best way to learn is have their mom stand at one end of the parking lot that is down hill from your child.
    Let them ride to their mom. They focus on getting to her and not riding the bike. The downhill grade makes
    it easier to coast too. This way they don't have to pedal so hard. Works like a charm all the time. I pretty
    much use this method to teach all the kids in the neighborhood. :bikewheelie2:
    JackCrank, la0d0g, llamasmurf and 4 others like this.
  10. Aug 12, 2019 at 6:45 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    Almost Banished!
  11. Aug 12, 2019 at 8:32 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    2013 sport -- turned off the locking unlocking chirping following the directions in another post below.
    Credit to BeeVee
    TURNING THE TRUCK “BEEP” ON/OFF WHENLOCKING/UNLOCKING DOORS
    Toyota calls the beeping an "answer-back" function. It's new for 2009 on the Tacoma; other Toyota models have had it for a long time.
    Here's how you toggle the answer-back beep off and on for the factory keyless entry (not Toyota's VIP alarm add-ons) on 2009+ Tacomamodels:
    1. Open the driver's door, and leave it open
    2. Insert the key into the ignition.
    3. Remove the key from the ignition, and within 5 seconds, re-insert the key and then turn the ignition to ON.
    4. Wait at least 10 seconds, but less than 20 seconds.
    After waiting, press a button on the remote twice(Press the same button two times - don't press two different buttons. The system will acknowledge with a beep if you did it right).
    Toyota's instructions for this sort of thing are very literal and must be followed EXACTLY. It's helpful to use the flashing ":" symbol in the clock to count the seconds in step 3.
    If you disconnect the battery, the setting will return to the factory default setting of ON.
    TOMB
  12. Aug 12, 2019 at 8:35 AM
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
  13. Aug 12, 2019 at 8:47 AM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    What lights are those for your canopy my battery ones just took a shit
  14. Aug 12, 2019 at 8:49 AM
    azhiaziam
    The reef ca
    Real clean I like how that sits more than my yakima
    Sig45[QUOTED] and Kuntrykid like this.
  15. Aug 12, 2019 at 8:57 AM
    mwnewel
    mwnewel Well-Known Member
    Michael
    Denver, Colorado
    2015 Tacoma DB TRD 4x4
    OME 887x, OME Shocks, Dakar Pack, RCI Skids
    Link to mattress topper?
  16. Aug 12, 2019 at 9:01 AM
    TRlPPlN
    Right on. Thank you for the tip! Now that i think about it, when she was going towards her mom, she was looking down ALOT more less.
  17. Aug 12, 2019 at 9:53 AM
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
    finished wiring the keypad and programming it :thumbsup:
    srspicer, irayfz6, llamasmurf and 2 others like this.
  18. Aug 12, 2019 at 10:09 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Probably the same battery powered ones from Amazon :rofl:
  19. Aug 12, 2019 at 10:20 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Thanks. I previously had the Rhino Rack that clamped onto the door jambs, but I wanted something adjustable. Drilling holes in the roof was daunting, but the butyl pads over each hole as well as marine grade silicone should prevent any leaks.
    azhiaziam[QUOTED] and Kuntrykid like this.
  20. Aug 12, 2019 at 10:40 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Cut this bad boy off because Vermont :facepalm:Now sandblasting the hitch so maybe it will make it another 6 years :fingerscrossed:
