  1. Aug 22, 2019 at 12:45 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I installed with power off and put the incandescent bulb back and the circuit is fine with all lights & clock working.
    I think I'll return the bulbs and stick with OEM.
    Plain Jane Taco likes this.
  2. Aug 22, 2019 at 12:51 PM
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    New Tail lights. Headlights will be here tomorrow. Got tired of my Silver Taco looking like 10,000 other silver Tacos where I live.
  3. Aug 22, 2019 at 12:53 PM
    SilverJack
    SilverJack no one
    lechicklet, irayfz6 and Kuntrykid like this.
  4. Aug 22, 2019 at 12:55 PM
    SilverJack
    SilverJack no one
    Brewster52[QUOTED] likes this.
  5. Aug 22, 2019 at 1:00 PM
    SilverJack
    SilverJack no one
    Those are really nice. First aftermarket set that I think are better than OEM. Do you have a link to order those?
    I'm in Florida, so I promise not to match match your truck. Plus my front end doesn't look like any other silver Taco.
    IvanhoeTaco, Kuntrykid and BillsSR5 like this.
  6. Aug 22, 2019 at 1:04 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    I got mine from local autozone & no problems. Idk... that's strange!:notsure:
    Sig45[QUOTED] likes this.
  7. Aug 22, 2019 at 1:06 PM
    SilverJack
    SilverJack no one
    Check the new LED, it must be shorted somehow. It's grounding and causing the circuit to blow a fuse.
  8. Aug 22, 2019 at 1:42 PM
    Austinguy
    Austinguy #FreeManer
    Robert
    Texas
    First on race day!
    Secrets
    Installed new to me Toytec BOSS Rear Shocks.
  9. Aug 22, 2019 at 2:16 PM
    DC-USAF
    DC-USAF Well-Known Member
    Dale
    WNC
    2015 SR5 Access Cab 4x4 V6
    TRD PRO Grill, mobtown offroad recovery bar, SCS Ray 10's
    It's not a bull bar it's a light bar, Westin makes one and they are year specific. This one is for a 2012-15. You can probably find it cheaper than this.
    https://www.leonardaccessories.com/...V4bNChjyeSHRfd8xmbVUbG7aR2agTc7xoC0YsQAvD_BwE
  10. Aug 22, 2019 at 2:42 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    mightym, TomTwo, Kuntrykid and 5 others like this.
  11. Aug 22, 2019 at 3:06 PM
    grlnbear04
    grlnbear04 Well-Known Member
    2015 Tacoma TRD Sport Blue Robbon Metallic
    I'm having a bit of trouble locating the drl power source wire. Any idea which wire that would be?
  12. Aug 22, 2019 at 4:16 PM
    TigerTacoma
    TigerTacoma Well-Known Member
    Upstate South Carolina
    ‘14 MGM Access Cab 4x4
    Dobinson’s coils and shocks. SOS sliders, ditch light brackets, and front skid. Rigid ditch lights. BFG KO(dos) More minor stuff.
    What is this basketball you refer to?
    Rick_Taco likes this.
  13. Aug 22, 2019 at 4:31 PM
    Vic916Taco
    Vic916Taco Well-Known Member
    Vic
    Elk Grove, CA
    2015 White Tacoma Sport TRD Access Cab
    LED Interior Lighting, Gecko LED Bed Light, Tail Gate Pop Lock, TRD Wheels with Cooper AT3 4S 265/65/17, HID Retrofits, DD SS3, Rear seat Delete/Molle Panel Wall
    Try these bulbs from Amazon, they work pretty good. https://smile.amazon.com/gp/product/B00FW1JP9O/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    Kuntrykid, WF_Guy and Sig45[QUOTED] like this.
  14. Aug 22, 2019 at 4:40 PM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Alright, so the Subaru tweeters are a direct swap to third gens, but us second gen guys need to do a little more work to get them to function. Lucky for us, @Black__cat has put together a nicely detailed write-up: https://www.tacomaworld.com/threads...plicing-cutting-or-soldering-required.623038/
    I only removed the two middle wires from the connector and flipped them, rather than removing all four on each side, but the end result is the same. Sounds WAY better than those factory things that resemble (loosely) speakers.
  15. Aug 22, 2019 at 5:13 PM
    Brewster52
    Brewster52 Well-Known Member
    Bree
    2014 DCSB
    Sweet thanks!
  16. Aug 22, 2019 at 5:20 PM
    Trikster
    Trikster Well-Known Member
    Kevin
    2008 Tacoma 4x4 Double Cab
    Using a recommendation from one of the guys here, I bought and installed today a set of the Maxpider Kagu floor mats. Seem very nice, good fit. My only concern with them is how long the rubber will last under my accelerator foot. The Toyota heavy duty all-weather rubber ones lasted two years.
  17. Aug 22, 2019 at 6:40 PM
    Sasquatchtaco
    Sasquatchtaco Sasquatch Taco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    Imma need to confiscate those wheels because reasons.
  18. Aug 22, 2019 at 6:45 PM
    tbr3345
    Tom
    Sacramento, CA
    They are Spyder 05-15 SKU 5085467 Black LED Tail lights, I used The LED backup bulbs from the OEM Light Had a little trouble installing them, tight fit and two notches on the Passenger side upper socket receptacle had to be made 1/8" larger so the tabs on the socket would fit. Other than that no problem. They are not to dark and the LED's are bright. No hyper flash on the turn signal just a little faster than OEM. I got mine form Tacoma Beast, which is in Florida but you can find them cheaper. Check the Spyderauto.com site for more info. I also order som Spyder Black 05-11 Version 2 Projector headlight with LED DRL light bar SKU 5084514 should be here Friday. I found the Tail light to be of good quality first look and just those 1 very small issue that was easy to correct. Only time will tell how they hold up. They are not cheap. But I like the looks of them. Now I think I need to debadge the tailgate.
    SilverJack[QUOTED] likes this.
  19. Aug 22, 2019 at 6:53 PM
    apy_camper
    apy_camper APY CMPR
    Christian
    Fredericksburg, VA
    2015 MGM DCLB SR5
    SR5 package Tow package A.R.E. midrise camper shell with roof rack
    Fresh Plates...will get em on in the AM
  20. Aug 22, 2019 at 7:33 PM
    Truck3r
    Truck3r Member
    Tucker
    2012 TRD Off Road
    Mounted up some 3 inch LED pods
    69041380_835336343529343_650443944677395_667b7513a0fa16ba87f8c6017f68bc8b382a2f1b.jpg
    69260464_371714933764250_221156600746029_58be010b1ab7e960adae5e2c5ec2efa427424bcb.jpg
    69086442_352512639034291_525538477151250_72d29cf443277fc925b1cdd82e7de829f9e63188.jpg
    69255815_934151636922983_692435910367851_bd06df51266a51b2a2122f4ba962c4445e848b4e.jpg
