  1. Jun 3, 2012 at 4:21 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    your just fine here. No need for overkill. They are tie downs, not hanging points.
  2. Jun 3, 2012 at 4:39 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya, if it's rated for 500 you should be okay.
    Just keep an eye on them first few times out. The bikes only weigh 500, but you are compressing the suspension and when hitting speed bumps and railroad tracks, you can put a pretty heavy load on the tie-downs.
  3. Jun 3, 2012 at 4:43 PM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Got my Leer 100XQ installed. (Yesterday)
  4. Jun 3, 2012 at 5:07 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    put my eyelids on
  5. Jun 3, 2012 at 5:10 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
  6. Jun 3, 2012 at 5:24 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Engaged 4wd low and the locker for a few hundred yards. Locker went right in but it took some time to unlock.
  7. Jun 3, 2012 at 8:40 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Mice! I did the same thing to my lower valence.. I didnt like the grayish color, so I plasti-dipped it, and now it matches the grille perfectly. :D
  8. Jun 3, 2012 at 8:45 PM
    ETaco23
    Evan
    PNW
    The Past few days I have plasti-dipped my badges including front emblem and lower Valence and Installed my AFE drop in filter..
    Installed a LED dome light I found, works great!
    Oh! and today I filled her up for the first time.. descided to get Shell.. :)
    And I averaged 19-20 mpg on my first tank!! I freekin love it!
    almost makes me not want to lift it and put my 285 Duratracs on..."Almost" hehe
  9. Jun 3, 2012 at 8:47 PM
    BradyT88
    BradyT88 Well-Known Member
  10. Jun 3, 2012 at 8:56 PM
    seric007
    seric007 Well-Known Member
    are those front wheels blocked? :spy:
  11. Jun 3, 2012 at 9:15 PM
    BradyT88
    Maybe;) haha
    Actually yeah. There is a 2x4 under the front and rear of the drivers tire. In hind sight we should have put it in 4x4 so the tranny would hold it, but we actually jacked up the whole rearend without blocks and it didn't go anywhere so we weren't too worried. Although it might be sitting there for a week or two while i wait for the new diffs to come in.
  12. Jun 3, 2012 at 9:28 PM
    2012TRDSport
    2012TRDSport Well-Known Member
    Geoff
    Anchorage, AK
    2012 TRD Sport DC 4X4
    Plasti-dipped front emblem, debadged, wet okole seat covers, tailgate lock mod, anytime fogs, yellow wire mod, BHLM
    Picked up a set of 33" BFG MT's off craiglist with wheels. Scored a pretty good deal considering not having to pay shipping to Alaska. Going to sand the wheels and paint them black.
  13. Jun 3, 2012 at 9:29 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Listed it for sale
  14. Jun 3, 2012 at 9:30 PM
    BradyT88
    Pics or it didn't happen!!;)
  15. Jun 3, 2012 at 9:32 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
  16. Jun 3, 2012 at 9:36 PM
    BradyT88
  17. Jun 3, 2012 at 9:39 PM
    DJSPEC
    DJSPEC @GuardianAdventures
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone Destination MT/2 295/70R17 Method 702 17” 0 offset Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel King 2.5 adjustable front and rear Dakar HD Leaf Springs Icon tubular UCA Dirt Kings LCA
    Thanks!!!
    Its the borla ProXS 40352 offset in, center out. its not too loud. but at 2500+ rpms you can really hear it. like when going up hills.
  18. Jun 3, 2012 at 9:53 PM
    ETaco23
    Evan
    PNW
    Thanks! Thats exactly how my other Borla Turbo muffler was.. Quite while cruising but a nice tone above 2500rpm, but i dont think it was too loud... I kinda want something alittle quieter this time...
  19. Jun 3, 2012 at 10:02 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    Installed HID reverse lights in my BruteForce Bumper. And Swapped on my BAMF LCA skids.
  20. Jun 3, 2012 at 10:45 PM
    sonocotaco
    sonocotaco Well-Known Member
    ken
    Rohnert Park
    2016 TRD Sport AC 4x4 Super White
    Got some new tire nozzle chrome caps w/ grommets (woo-hoo!). Tired of seeing the pressure sensor light.
