  1. Oct 16, 2019 at 7:00 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    All I did was pick up my ome medium leafs and u bolt flip kit with new bump stops. Gonna be a good weekend
  2. Oct 16, 2019 at 7:19 PM
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
    That should keep you out of trouble.
  3. Oct 16, 2019 at 7:22 PM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    If that is into the plastic beyond the protective clear coat, it is called 'crasing' and it is too deep to sand out. It would probably return anyway.
  4. Oct 16, 2019 at 7:31 PM
    the_bluetaco
    the_bluetaco Well-Known Member
    Artem
    California
    2014 TRD Off Road DCSB
    Method Racing Wheels-Double Standards 16x8 Falken Wildpeak AT3W -285/75R16 FRONT: Bilstein 6112, TOTAL CHAOS FABRICATION UCAs REAR: Bilstein 5160, OME DAKAR leaf spring set
    I had the clear coat on my headlights start to bubble and peal away. I took the truck to a shop that restored headlights and they got them fixed for me and also installed a clear headlight bra to keep the new clear coat protected.
    fökai671 likes this.
  5. Oct 16, 2019 at 7:39 PM
    Roofy
    Roofy Well-Known Member
    Virginia
    '14 Sport 4x4 DCLB
    Bilstein 5100’s, Vision Wheels, slotted StopTech rotors, TRD pads, SPOD, Decked Drawers, N'Fab Steps, Leer Cap, KC Highlites 40” & Cyclones underbody and under the hood, Rigid Scenes mounted to Prinsu Rack, anytime LED Fogs, TacomaBeast headlights, RAGO bed stiffeners, USB-C rocker in cab & 2xUSB in bed w/anytime on option, Alpine Head Unit, Front Camera.
    Photo or it didn’t happen!!
    VMMM likes this.
  6. Oct 17, 2019 at 3:20 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    You can make 'em better. About 15 minutes, some Maguire's liquid rubbing compound, and a 3" foam pad on a drill will do it. I didn't get crazy on these (sanding, etc) because they're cracked and will eventually be replaced. But a little time and elbow grease gave an improvement.
    Go for it! :thumbsup:
  7. Oct 17, 2019 at 3:30 AM
    That one old guy
    Chuck
    Stockish
    Forgot to include this, see above. ^^^^^. :D
    99kx250[QUOTED] likes this.
  8. Oct 17, 2019 at 5:11 AM
    olecoot
    olecoot Well-Known Member
    Dennis
    Northeast Fl.
    2021 TRD OFFROAD 4X4
    3 + 1 Pro Comp 285 Falkin Wildpeaks Bed Cap
    Dilemma Help.
    Hypothetically, if you were gonna upgrade from a 2009 , (A) would you go with the second year of the 3rd Gen ? or (B) try to find a clean 2014 - 2015 of the second Gen.? Forget the cost. Talking durability and dependability. V6 Auto
    Island Cruiser likes this.
  9. Oct 17, 2019 at 5:14 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Pretty much what these guys have said. I'd try wet sanding with some pretty fine grit and then move on to the liquid rubbing compound. I think they even sell one called Plastic-X (or something like that) that is pretty readily available.
    WeatherTech makes a headlight guard that you can install. I think they are about $40 and a PITA to install....but they'll keep your headlights looking like new for a LONG time.
    https://www.autoanything.com/lights/weathertech-lampgard-headlight-protection-film
    ^^^Looks like they have gone up in price. Maybe check with a local vinyl shop to see about putting a clear vinyl over them.
  10. Oct 17, 2019 at 5:17 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    You're going to get wildly varying opinions with that question. Likely a lot of flaming from folks too, as people are passionate about their truck and what they think is the best.
    In the end, you will be just fine with either one. Both great truck that are very reliable. End of story.
  11. Oct 17, 2019 at 6:04 AM
    SummitBound
    SummitBound Well-Known Member
    Greenville, SC
    2019 T4R OR
    I think, at this point, especially if you are getting a 2017.5+, the reliability is most likely very similar to a 2014 or 2015.
    My honest advice is drive both for an hour or so if you can. Highway, stops, hills, etc. Play with the tech inside. I came out of the test drives preferring the interior of the third gen but the drivetrain of the second gen. At the end of the day, I knew I would be happy with the second gen and would probably just get an apple car play head unit later, so I went second gen. Getting the second gen allowed me to get a TRD instead of a third gen SR5 due to cost savings as well.
    Austinguy likes this.
  12. Oct 17, 2019 at 6:34 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Yup, mine's on 0 volume now. Taping over the speaker is a good idea, I might try that instead.
  13. Oct 17, 2019 at 6:59 AM
    Ibocnet
    Ibocnet Well-Known Member
    Rich
    2010 TRD Sport DCLB
    Toytec 3" front lift, OME 3" rear lift, ARE MX Cap, Budbuilt Armor
    Great idea. I also don't feel safe with the regular bottle jack. Safe Jack sells bottle jack extensions that add height to the collapsed height of most sizes of bottle jacks. You can use a smaller jack and get extensions to give the height needed. Not cheap but they do solve the storage problem
    https://safejacks.com/products/safe-jack-bottle-jack-recovery-kit-without-bottle-jack
    KickAss and Dawdaw808 like this.
  14. Oct 17, 2019 at 7:15 AM
    Ibocnet
    Rich
    2010 TRD Sport DCLB
    All of the parts are for sale individually. I didn't see them on the website but I have a paper catalog with all the part #'s and prices.
  15. Oct 17, 2019 at 7:16 AM
    Ibocnet
    Rich
    2010 TRD Sport DCLB
    Front Bumper! You can always get a deal on a rifle.
    JKU3000 likes this.
  16. Oct 17, 2019 at 7:18 AM
    Ibocnet
    Rich
    2010 TRD Sport DCLB
    Congratulations. That's awesome. I want to get lost near you. LOL
  17. Oct 17, 2019 at 7:19 AM
    Ibocnet
    Rich
    2010 TRD Sport DCLB
    Most deer are killed with bumpers I think!
    tdconklin12 likes this.
  18. Oct 17, 2019 at 7:21 AM
    Ibocnet
    Rich
    2010 TRD Sport DCLB
    Cool. Where did you get it?
    Quite stupid our didn't come illuminated.
    JKU3000 and Austinguy like this.
  19. Oct 17, 2019 at 7:31 AM
    Ibocnet
    Rich
    2010 TRD Sport DCLB
    May I suggest you do something else. Get both a rear camera mounted either on the topper or rack and a front camera. Use a monitor (bigger the better) that can switch between the 2. I use the front camera when on trails to drive around obstacles but more importantly to see over hills when all I can see is my hood and sky. Invaluable safety device when wheeling.
  20. Oct 17, 2019 at 7:41 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Haha. I can respond to any county for missions jow so I got ya!
