  1. Oct 25, 2019 at 10:04 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Atta boy! :thumbsup:
  2. Oct 25, 2019 at 10:11 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Nice! Next month my truck is officially mine.
  3. Oct 25, 2019 at 10:32 AM
    Blain
    Blain I ain't got time to bleed
    Tx
    Awesome!
    Lou Slink[QUOTED] likes this.
  4. Oct 25, 2019 at 11:08 AM
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    Not today but a few things I did prior to the road trip I didn’t post.
    Mounted the max traxx to the Thule tacks I installed a while back
    Ultra gauge in a mesocustoms overhead mount to tack fuel mileage and various other stats while on the road. Not sure how I achieved 30+mpg average :notsure:
    Mapped out the route on the Garmin overlander and mounted for easy access
    Paired with the wireless rear view cam since I’ve blocked my OEM can now
    Installed Plano double gun case on the roof
    added some Rigid rock lights For camp lighting I was scheming on how to get a downward angle for the sides and it’s like Rigid knew and sent these awesome thick Rubber angle bases! #winning
    and just yesterday I finally chopped the exhaust and got rid of that ugly weathered tip I’ve had forever
  5. Oct 25, 2019 at 11:26 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I put a 6 tone double ram bottle jack and safe jack extensions under the rear seat and organized my recovery gear
  6. Oct 25, 2019 at 11:45 AM
    la0d0g
    running for the hills
    For crawling not hauling
    My vote: it's wrong :D
    kgarrett11 and Rick_Taco like this.
  7. Oct 25, 2019 at 12:03 PM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    Did you cut out the OEM bottle jack mount in there? How did you do it?
  8. Oct 25, 2019 at 12:13 PM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    How do you access the back to press the buttons?
  9. Oct 25, 2019 at 1:06 PM
    GonzoQuick
    GonzoQuick Active Member
    2013 Double Cab 4x4 TRD/Tow Package
    Added the VIPMotoz Red OLED License Plate Tag Lights to the 2013 Truck today. Easy install under 20 minutes including cutting off the extra plastic tab that otherwise gets in the way.
    I travel across country to help out in wildfires, floods, blizzards, etc. and I wanted to increase the truck's visibility from the rear without being obnoxious so others can follow me through smoke, avoid debris, see in whiteouts and hopefully help them stay on the roads (or fire roads).
    Thanks to everyone here on TW for the ideas and help. It seems I keep adding more "wishlist" ideas to my build list. Thanks!
  10. Oct 25, 2019 at 1:11 PM
    sapperguy
    sapperguy Well-Known Member
    craig
    09 SR5 DCLB
    New shoes and a couple of coats of Plastidip to clean the wheels up!!!
  11. Oct 25, 2019 at 1:53 PM
    Pacemaker
    Pacemaker Member
    Phil
    Walhalla SC
    2015 Grey Tacoma TRD Sport
    Added 1.25 Spacers to the front to fix the rubbing issue, back wheels will have them Monday A2A3D713-E701-4597-BC02-A8F6CC40946D.jpg
  12. Oct 25, 2019 at 1:59 PM
    Taco-Obsessed
    Looks good.
    Any night shots of the rigid lights?
  13. Oct 25, 2019 at 2:43 PM
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
    7F742788-B5A7-4A5C-BF28-409F53DDB3BE.jpg Used the truck to haul out this years buck..
  14. Oct 25, 2019 at 3:09 PM
    Dalegribble02
    I left it and but the jack is on the other side. Didn't strap it down though. All my recovery stuff is on top of the stock jack mount
  15. Oct 25, 2019 at 3:50 PM
    Roofy
    Roofy Well-Known Member
    Virginia
    '14 Sport 4x4 DCLB
    Bilstein 5100’s, Vision Wheels, slotted StopTech rotors, TRD pads, SPOD, Decked Drawers, N'Fab Steps, Leer Cap, KC Highlites 40” & Cyclones underbody and under the hood, Rigid Scenes mounted to Prinsu Rack, anytime LED Fogs, TacomaBeast headlights, RAGO bed stiffeners, USB-C rocker in cab & 2xUSB in bed w/anytime on option, Alpine Head Unit, Front Camera.
    to update after 24 hours...
    Brakes are significantly better (SoCal highway). Very happy with the improvements, recommend.
    Plugs made a world of difference in the smoothness and acceleration departments for sure. Quiet, no Tacoma tings and pings.
    As for the Morimoto LEDs, I’m not completely sold on the actual pattern of light. Color is great, but the visibility does not seem improved and they are a little high in angle. Will try to adjust down but so far, not super pumped on them.
    Rick_Taco, Dgoode9 and GonzoQuick like this.
  16. Oct 25, 2019 at 4:38 PM
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
  17. Oct 25, 2019 at 4:38 PM
    Dgoode9
    Dgoode9 Well-Known Member
    Columbus, OH
    2009 TRD Sport
    I thought the same thing for the first few weeks with my Morimotos. One morning on my way to work (445am) it was a torrential downpour, limited visibility. We live a ways out in the country so no big streetlights for at least 30 minutes. The fog lights cut thru and gave me incredible visibility. Not super noticeable all the time, but worth the $$ when it counts.
    Roofy[QUOTED] likes this.
  18. Oct 25, 2019 at 5:16 PM
    TA 4
    TA 4 Well-Known Member
    Ontario, Canada
    2015 SSM Taco access 4x4 2.7
    Cruisin offroad bumper, RCI front skid, Bakflip Tonneau Cover, Westin Running Boards, door molding, Blazer Led lights, Bed Lights, DIY Bed/rear cab mats, 3M Clear Bra (Hood and Fenders), Husky front floor mats, re diff relocated, Coverking seat covers
    Upgraded the speakers to the JL audio C690x component set after one of the MTX coaxials blew on me. Large improvement in sound quality again, high end is no longer sharp, harsh and balanced. Looking forward to the many hours to be spent listening to tunes.
    MSN88longbed and Rick_Taco like this.
  19. Oct 25, 2019 at 6:05 PM
    SilverJack
    SilverJack no one
    One of my first and favorite mods. I love having the garage door control in the mirror. No ugly box messing up my visor or battery worries.
    Plus every time some dumbazz brights-loving jerk gets behind me the mirror just dims down to a nice dark green.
  20. Oct 25, 2019 at 7:37 PM
    Badderup
    Badderup Well-Known Member
    Colby
    Utah
    2006 SWB TRD sport DCLB
    No worries. Looking forward to seeing how you did it.
    Austinguy[QUOTED] likes this.
