  1. Dec 16, 2019 at 5:33 PM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    You see, it all balanced out in the end!:thumbsup:
  2. Dec 16, 2019 at 5:48 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    afe intake, tundra 76mm tb, ported intake runners, 2 stage methanol injection, custom cams to be installed, longtube headers, custom tuned y-pipe, 3" stainless exhaust, valve body shift upgrade, 4:10 gears with a true trac. pages in mod lists.
  3. Dec 16, 2019 at 6:13 PM
    DG92071
    DG92071 Well-Known Member
    My truck's check engine light for the crankshaft position sensor went out without me doing anything to the truck so I got it smogged after the wheel alignment was done. I can finally drive it. So I hit the freeway, whoops so I hit the parking lot that's called a freeway here in So Cal and the truck handled beautifully while it was sitting still. Oh well, maybe I'll see how it handles tomorrow.
    whatstcp, GonzoQuick and Casper66 like this.
  4. Dec 16, 2019 at 8:10 PM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Decided to properly mount the Maxtrax. Bungees were tight but I was worried about them walking off so I got the mounts only to find they don't fit without blowing giant holes in my crossbars or buying another $ mount.
    So fabricobbling time.
    Step 1, translate from the moon dimensions the aussies use to 'murica numbers because I couldn't find my metric tape measure (I do have one)
    Put 'murica numbers on 1x1 Aluminum angle.
    Feed them to the metal chopping thingie.
    More measuring.
    To the laser powered hole maker
    Mockup
    And now the hardest part (for me). Make another one exactly like it.
    Test fit
    Some paint
    And done.
    RoNeil, ndcmack, baldridge and 22 others like this.
  5. Dec 16, 2019 at 9:24 PM
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    Drove to Tahoe with some shitty road conditions on Friday and then drove back today with no snow on the roads. Took this on the way down since all my other trucks have been shot under it in the past.
  6. Dec 16, 2019 at 9:25 PM
    DG92071
    I got to drive my truck tonight on the freeway and a short trip on a twisty canyon road. It was my first good drive in it since lift/tires. It rides fantastic, by far the best riding lifted truck I've ever driven. I am surprised how much power it has because it's still got the stock 3:73. I can definitely feel some axle wrap going on. The handling without a sway bar is interesting and I love it, it has an initial sway and then it feels rock solid. I took a 25 mph turn at 35 mph and it felt fine. It has zero vibration. Bigger bumps affect the steering wheel more than I'm used to but that's probably caused by the tires (37's) and the rack is a little worn (found out today). The alignment kicked the tires forward a bit so I've got more trimming to do on the front of the front fenders. I'm extremely happy with the outcome of this first rendition of my 2nd gen so far. There are more parts I still need to install in the parts pile.
  7. Dec 16, 2019 at 9:37 PM
    theolee
    theolee www.nickleecreations.com
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Finally got around to it. Swapped out those boring halogen H1's for a set of deep blue OPT7 55w HID's. Picture doesn't do it justice.
  8. Dec 17, 2019 at 3:32 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Gave it a mini detail
  9. Dec 17, 2019 at 7:47 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    Mall crawling like a boss today!
  10. Dec 17, 2019 at 10:02 AM
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    Good looking truck.
    2013XSPX[QUOTED] and Kolter45 like this.
  11. Dec 17, 2019 at 10:11 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    That glass cleaner is the worst automotive cleaning product I have ever (and will never again) purchased.
    Literally the next post.
    It should be called "liquid glass fragrance that leaves streaks"
    Seriously, straight water is more effective.
    Hopefully you are using the ammonia free windex. Otherwise, your tint will turn purple.
    Unless tint manufacturers have made that vast of an improvement. I may be speaking from outdated knowledge, but remember all the cars with purple tint back in the 90s and early 2000s? Yeah, they cleaned their tinted windows with windex (or similar glass cleaner with ammonia).
  12. Dec 17, 2019 at 10:34 AM
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Good to know about the ammonia, my tint hasn't turned purple but no need in taking any chances lol
    kgarrett11 likes this.
  13. Dec 17, 2019 at 10:38 AM
    DG92071
    A drop or two of dish soap, a little vinegar, and water= the best glass cleaner on the planet.
    Trikster, wmg, kgarrett11 and 3 others like this.
  14. Dec 17, 2019 at 10:38 AM
    Nachomama2001
    Nachomama2001 Well-Known Member
    South Carolina
    2013 Tacoma TRD OR prerunner
    Bilstein 6112+5160s Air pump delete-Hewitt Technology Rear view mirror switch Hawk pads G2 BAK flip Roadmaster active suspension Seat lifters HVAC AJT knobs
    Installed rear view camera switch!
  15. Dec 17, 2019 at 10:42 AM
    Turdyota3000
    Round da corner
    Ordered StopTech rotors, TRD pads, brightest reverse lights ever, Engineaire snorkel top hat, SOS recovery point, and purchased some used oem tail lights from a member.
    trdtacojef, msfit, DG92071 and 5 others like this.
  16. Dec 17, 2019 at 10:53 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Let us know how the brake set is afterwards. I’m in the mountains quite a bit & saw someone with smoking brakes just last summer. Def thinking about upgrading.
    Also I did the reverse light mod & it’s been great esp with my tint
    Turdyota3000[QUOTED] and DG92071 like this.
  17. Dec 17, 2019 at 11:14 AM
    AugustaTaco
    Josh
    Augusta, GA
    Which snorkel head are you replacing?
  18. Dec 17, 2019 at 12:15 PM
    GonzoQuick
    GonzoQuick Active Member
    2013 Double Cab 4x4 TRD/Tow Package
    DG92071 and Kolter45 like this.
  19. Dec 17, 2019 at 12:15 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
  20. Dec 17, 2019 at 12:47 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    I only do my windsheild with it. Not my tinted windows
    Kolter45 likes this.
