  1. Dec 19, 2019 at 12:50 PM
    G.T.
    G.T.
    CONUS
    I’ve been in the workshop hours after shutting it down and heard it then as well. Like a little whirring sound, a bit high to mid pitched, lasts one second-ish.
  2. Dec 19, 2019 at 1:01 PM
    DG92071
    DG92071 Well-Known Member
    https://youtu.be/zopKJa_NxII
  3. Dec 19, 2019 at 1:07 PM
    DirtMeister
    DirtMeister Cancel VFR, Going Tactical
    East Tennessee
    2015 SR Stealth DCSB 4x4 V6
    Aries Brush Bumper, ACI Lights, AOB switches, Back Up Camera and Beepers. Black front emblem and rear Tacoma Black. Other badges removed. Leer cap. Dobinsons snorkel.
    DG92071[QUOTED], Kolter45 and JKU3000 like this.
  4. Dec 19, 2019 at 1:26 PM
    Badderup
    Badderup Well-Known Member
    Colby
    Utah
    2006 SWB TRD sport DCLB
    Kolter45 and skochat[QUOTED] like this.
  5. Dec 19, 2019 at 1:50 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Bought a ‘15 a couple of weeks ago. I’ve had an ‘04 for 8 years and have started building it up, so the 2nd gen was the only realistic daily driver for me. I’m guessing that the guy who had it prior to me sprayed a can of rubber undercoating over everything visible from a quick look underneath right before he traded it in. Didn’t prep anything, sprayed right over the rust, dirt, road grime, etc... I’ve spent the last weekish scraping that stuff off. Looks like it spent some time in the salt, but is pretty straight. The alignment was also off and the tires were shot when I bought it. I decided to replace all of the bushings in the front end with poly bushings from energy suspension before I get it aligned. I am going to throw my old tires from my 1st gen on it since I just put 33’s on my 1st gen. I’ve got the driver side all ready for paint, bushings in the steering rack, etc. I bought a quart of chassis saver to check it out. I’m going to probably end up painting the control arms tomorrow. Has anyone used this stuff? I was sold on it over por15 when I bought it, but want to make sure I’m not going to put on a junk product.
  6. Dec 19, 2019 at 3:15 PM
    chutson99
    chutson99 hoosier starred chef
    Peoria IL USA
    2008 Tacoma 2.7 l4, 2wd
    got it spring 2016, so far installed: oem cruise control Access literider tonneau cover bilstein 4600s weather tech window rain guards misc painting aFe pro dry air filter Opt7 LED bed lights fog lights
    got tired of sandbags for winter traction weight sliding around and being in the way of loading things in the bed, so I made a flat box full of sand with "legs" that straddle the wheel wells so the weight stays put right over the axle
  7. Dec 19, 2019 at 3:34 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Went for pizza
    TOMB
    Rick_Taco, Cativelense and jon_elc like this.
  8. Dec 19, 2019 at 3:46 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Great Idea! job well done
  9. Dec 19, 2019 at 4:07 PM
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    i'm copying you
    chutson99[QUOTED] likes this.
  10. Dec 19, 2019 at 4:38 PM
    grant318is
    grant318is Well-Known Member
    Connor
    Lovettsville, VA
    07 Tundra RCSB
    Got my ADS suspension, Icon UCAs, Icon 3 pc AAL, new ball joints and new LCA bushings installed last weekend.
    8ADADFEC-5EBB-445D-88CD-51AE6272A3E4.jpg 12BE67C5-58F6-432B-A84B-C9C7E04D8AEE.jpg B9477C1A-A134-44ED-857B-711E10AB80AC.jpg
    Also got my 2014 wheel installed
  11. Dec 19, 2019 at 4:56 PM
    trdtacojef
    trdtacojef Well-Known Member
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    OME Dakar Medium duty rear leafs Total Choas UCAs Elka 2.5” Extended Travel CO and Rear Shocks w/ RR and DC FN FX Pro 17” Silver Rims Nitto Ridge Grapplers 285/70R17
    My 2007 is finally coming together. Feels like a brand new truck. Started with the Elka suspension from Headstrong Off-road (thank you Marie) that I snagged during a group buy. I went with the FN FX Pro wheels mounted up on Nitto Ridge Grapplers. Dustin was super helpful and I am really pleased with the rims. I did a ton of research on tires and went back and forth between 255/80R17 and the 285/70R17. Went 285 and so far I’m pretty happy.
  12. Dec 19, 2019 at 5:12 PM
    DirtMeister
    East Tennessee
    Patent Pending ? Cool idea.
    chutson99[QUOTED] and lynyrd3 like this.
  13. Dec 19, 2019 at 5:27 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Installed this...
    Then dropped a screw and found this...
  14. Dec 19, 2019 at 6:01 PM
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
  15. Dec 19, 2019 at 6:36 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Wow, that color on those wheels is perfect!
    Rick_Taco and scouterjan like this.
  16. Dec 19, 2019 at 6:43 PM
    trdtacojef
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    I really questioned myself for not going with the bronze/copper. I’m pretty happy with my choice!
  17. Dec 19, 2019 at 7:23 PM
    Toysareus
    Toysareus Member Passed Away—2021
    USA
    Got this: https://www.ebay.com/itm/123016061899
    and this: installed this week.
    Both Items were on sale Black Friday. Both items could be installed in your sleep. I highly recommend Bob’s Mirrors. Temp is real accurate. When truck is first turned on, temp flashes ICE then temp for about 1st minute. I think this is for 37*F and below. Temp sensor is mounted on front center vertical bracket in front of condenser using a SS bolt in existing hole next to horn wiring connector.
    Do I still have the Taco lean? Yeah, but not as bad. Can’t find level location right now and gas tank is full.
    Rick_Taco and lynyrd3 like this.
  18. Dec 19, 2019 at 7:30 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Where at in Va?
  19. Dec 19, 2019 at 8:10 PM
    jon_elc
    NorCal
    i trimmed 1.5" off of all of my mudflaps. i already trimmer 3" off the front, but felt i would need additional clearance for any piles of snow i plan to be driving over this winter.
    Rick_Taco likes this.
  20. Dec 19, 2019 at 9:14 PM
    TacoTuesday1
    SD CA
    how'd you make your fogs yellow?
    scouterjan likes this.
