  1. Dec 29, 2019 at 7:30 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Ya me too. I'm excited
    Matmo215[QUOTED] likes this.
  2. Dec 29, 2019 at 7:38 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    This is exactly what I was hoping to do & avoid bending. The new bolts & washers were pretty cheap too. I wanted to do this when I install my SPC UCAs
    DG92071[QUOTED] likes this.
  3. Dec 29, 2019 at 7:47 PM
    DG92071
    DG92071 Well-Known Member
    It'll work fine but I don't understand the desire to not slightly bend the sheet metal. It's definitely easy to do and can be bent back if desired. It's an area maybe 3 inches long. I used a 12 inch crescent wrench and bent short crescent wrench wide sections of it at a time. I bent it back with the same wrench. I previously wrote the passenger side was more difficult than the drivers side, but that bolt still only took 5 minutes per side. To each his own, do it however you would like to.
    Kolter45[QUOTED] likes this.
  4. Dec 29, 2019 at 8:16 PM
    SByota
    SByota Active Member
    Gave the rear drums some long overdue attention. Wire brush rotary + caliper paint. Hit the calipers in front too, and used some anti corrosion flat black on other parts in the wheel well.
    Bronsky, dpele, baldridge and 20 others like this.
  5. Dec 29, 2019 at 8:21 PM
    YoTacoToy
    YoTacoToy Member
    2013 Tacoma TRD Off Road Double Cab Magnetic Gray
    Found a way to take off my camper shell in my garage using just 2 ratchet straps. Only the 2nd time the camper shell has been off in about 7 yrs.
  6. Dec 29, 2019 at 8:32 PM
    20somethingwidataco
    Will
    Washington State
    Makes me want to paint my caliper. Did you remove yours?
  7. Dec 29, 2019 at 9:04 PM
    SByota
    Nope, just masked
  8. Dec 29, 2019 at 9:19 PM
    20somethingwidataco
    Will
    Washington State
    Screw it. Going to do my drum brakes again and my calipers. I think just regular paint should be fine for the drums right?
    SByota[QUOTED] and Rick_Taco like this.
  9. Dec 29, 2019 at 9:45 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I would probably use high heat for any brake component paint. Its cheap insurance and a few bucks more gets you a really high quality finish and durability
    GonzoQuick, Rick_Taco and Kolter45 like this.
  10. Dec 29, 2019 at 9:47 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Regular paint will burn off. Use caliper paint. one can of Duplicolor should do it.
    Kolter45 likes this.
  11. Dec 29, 2019 at 10:02 PM
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    When do you get the clunk? What suspension are you running?
    Maybe the springs hitting the sway bars? I had to add a sway bar relocation bracket to avoid hitting the 887 springs on mine for whatever reason. Could also be the shocks topping out, common issue with OME suspensions. Think it’s called “over speed bump goes clank” or something along those lines.
    Another possible clunk is from the bumper hitting your body. Hard to tell from the pic, but you should leave at least .5” gap between the bumper and body to allow for flex. My bumper ended up dropping a little one side, causing it to raise just a little on the other. Kept hearing a clunk when riding FS roads and took a while to figure out what it was.
    Rick_Taco, Kolter45 and DG92071 like this.
  12. Dec 29, 2019 at 10:04 PM
    20somethingwidataco
    Will
    Washington State
    True. I'll give it a try!
    will.i.was[QUOTED] likes this.
  13. Dec 29, 2019 at 10:04 PM
    20somethingwidataco
    Will
    Washington State
    I never thought the drum brakes got very hot
    JKU3000 likes this.
  14. Dec 29, 2019 at 11:46 PM
    scleaf
    scleaf Well-Known Member
    Torrance, California. USA
    2013 Silver Tacoma TRD 4x4
    SaBellCo's Tailgate Lock :), Cable mod
    Are you a porch pirate?:rofl:
    AdamM, Z7Xtreme, Rick_Taco and 2 others like this.
  15. Dec 30, 2019 at 12:01 AM
    scleaf
    Finally got a few things installed, rear bumps, front breaks and rotors, swamped my TC UCA's for SPC as I needed more adjustability, fabricated a 3/8 shock spacer to get rid of the toco lean. Used it to get a water heater. Busy weekend but I feel like I got a few things done.
  16. Dec 30, 2019 at 12:06 AM
    Comet'spop
    Comet'spop Well-Known Member
    SanDiego Ca.
    06trd4x4,4dr.longbed Super White
    Buncha shit
    Curious,what light are you running on your Prinsu ?
    JKU3000 likes this.
  17. Dec 30, 2019 at 5:27 AM
    Kolter45
    Denver, CO
    did u install the bolts backwards even with/after bending? Figured it make it easier on my truck if I ever have to work on my UCAs
    Rick_Taco likes this.
  18. Dec 30, 2019 at 6:19 AM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    You could send me a PM if you want.
  19. Dec 30, 2019 at 7:13 AM
    SpikerEng
    SpikerEng Well-Known Member
    Leon
    Portland, OR
    outxider[QUOTED] and JKU3000 like this.
  20. Dec 30, 2019 at 7:27 AM
    zhekakz
    zhekakz Well-Known Member
    eugene
    seattle wa
    2013 silver tacoma
    Honestly not gonna lie to you but I have no idea what brand it is
    A friend of mine got it for 500+$ and a month later changed it to a curved one and sold me this one for 100$
    It works for now and it’s pretty bright but I’ll ask him what brand it is
    DG92071 and JKU3000 like this.
