  1. Jan 17, 2020 at 7:04 AM
    mCat
    mCat Well known member.....lol member
    Bay Area
    2014 Tacoma TRD DCSB
    Added a tow controller. Decided to go here instead of the coin holder tray spot like most others since I throw my phone in that slot sometimes
    don’t mind the mess. Truck does lots of camping trips
    E-Paz 732NJ, GonzoQuick and irayfz6 like this.
  2. Jan 17, 2020 at 7:04 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    You need subs.
  3. Jan 17, 2020 at 7:15 AM
    trdtacojef
    trdtacojef Well-Known Member
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    OME Dakar Medium duty rear leafs Total Choas UCAs Elka 2.5” Extended Travel CO and Rear Shocks w/ RR and DC FN FX Pro 17” Silver Rims Nitto Ridge Grapplers 285/70R17
    What ditch light brackets are those?
  4. Jan 17, 2020 at 7:17 AM
    Toysareus
    Toysareus Member Passed Away—2021
    USA
    I put mine here...many moons ago.
    GonzoQuick and mCat[QUOTED] like this.
  5. Jan 17, 2020 at 7:18 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Agreed, but my backseat is full of carseats. I can barely fit a duffle bag back there...
    ...though I can't exactly access the space behind the back wall easily. Perhaps a 10" sub will go back there :D
    My first priority though, quiet that dang Metra faceplate and radio from shaking so much. I've already gone as far as putting electrical tape everywhere that you couldn't see it to try to make things rest together. It helped, but not much. SInce you say that yours doesn't rattle, I might look to see if I can order some OEM clips. The Metra ones SUCK.
  6. Jan 17, 2020 at 7:29 AM
    elricfate
    Worst case, you can order the brackets on ebay for the OEM radio and see if that helps with your vibration. I think the Metra clips are undersized for their application, which makes them less hearty, which in turn allows the faceplate to move in place. I think if I had reused the OEM brackets it would just be that much stronger and honestly, I wish I had to avoid future issues, but for now they're quiet and solid.
    I also put a radio in that's about half the depth of a normal double DIN (Kenwood DMX7706S). That might be a mitigating circumstance, it's less heavy than others.
    Also, at least you have space for shallow mounts because of your double cab. I am looking at some of the little tiny active box subs to put under a seat, at this point. :D
  7. Jan 17, 2020 at 8:03 AM
    mattmaxon
    mattmaxon Active Member
    Engine Coolant low alarm system
    After the plastic coolant bypass pipe catastrophically failed on the freeway cooking my engine, how the hell would you know this had happened?
    The only indication I could think of is a rapid loss of coolant temperature on the gauge... Humm who the hell pays that much attention to that?
    I located a sensor made for detecting this condition from Gems Sensors & Controls
    CAP-300 Series Capacitance Level Sensor
    I used a inline temp sensor adaptor and opened it up to 1/4 npt, tapping it so the tip of the sensor is fully immersed in the coolant
    Using an inexpensive solid state relay I am driving it directly from the switched output of the sensor negating the need for a controller or some other hardware / software
    I have a red led/buzzer indicator on the panel
    The sensor I selected turns on the output when there is no coolant, when starting the engine the led/buzzer lights/chirps briefly indicating to me the system is functional
  8. Jan 17, 2020 at 8:05 AM
    DG92071
    DG92071 Well-Known Member
    Bullseye hit.
    CowboyTaco[QUOTED] likes this.
  9. Jan 17, 2020 at 8:19 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Yeah i reused the factory brackets and that made everything better. I know your pain....i remember everytime i drove offroad my stereo rattled like it was having seizures
  10. Jan 17, 2020 at 8:22 AM
    DG92071
    People can play semantics (word play) all day long and if a person can't use a product that's designed to be used by itself without needing another products parts to get a quality job done then it's a sh!t design, IMO of course.
    People that have the stereo stolen typically do not have the luxury of having their old (stolen) parts. Metra kits are designed to be used as the sole part and if no additional parts are used the end result will be disappointing.
    The way I'm reading this is like someone is offended but I am absolutely positive that particular someone didn't design the Metra kit so it seems odd they'd be offended. To each their own I guess.
    I am 100% disabled, I have good days and I have bad days. On my bad days everything is affected, including my reading comprehension/concentration ability, I'm not offended in the slightest and I'm not trying to provide excuses or trying to pass the buck - I'm providing legit reasons. It'd be nice if people thought about having no clue what another person is going through prior to replying but that'll never happen online.
    I hope ALL OF YOU have a fantastic day, it's FRIDAY BABY!
  11. Jan 17, 2020 at 8:26 AM
    elricfate
    Please note, I am not offended. In my posts I explicitly have stated that I am only sharing my own experience and that experience might change.
    I don't care what people do, I was just confused based on my own limited experience thus far. Why this has become a thing is beyond me. If you feel the need to refute my own experience, that's fine, go for it.
    DG92071[QUOTED] likes this.
  12. Jan 17, 2020 at 8:33 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    I have considered those as well, as storage space is at a premium in these trucks. But most of them are 8" and I've rarely been impressed with an 8" sub.
    I have the Kenwood DDX3XXXXBT (don't remember all the numbers).
    elricfate[QUOTED] likes this.
  13. Jan 17, 2020 at 9:37 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Just like someone else said. Costal Georgia Winter Storm made my exterior all flower jizzy so I detailed the interior.
  14. Jan 17, 2020 at 9:59 AM
    trdtacojef
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    What seats are those? Very nice.
  15. Jan 17, 2020 at 10:11 AM
    2013XSPX
    GA/FL Border
    2013 XSP-X
    Thank you! They came as a Dealer Add On for the XSP-X Edition. Available in the Southeast it came with Bushwaker fenders, LED's, all-weather seats, different wheels and bunch of other cosmetic stuff.
    Rick_Taco and trdtacojef[QUOTED] like this.
  16. Jan 17, 2020 at 11:13 AM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    I used the Metra single DIN kit only thing I had to do was open up the 4 way flasher area so the button wouldn't stick. It fits tight and no rattles but then its only a street truck
    elricfate[QUOTED] and DG92071 like this.
  17. Jan 17, 2020 at 11:17 AM
    DG92071
    Great! No refuting here. I absolutely believe it worked well for you because I've done the same thing many times. The company that I worked for almost exclusively used Metra. The only times I've used Scosche is on my own vehicles and maybe 5 different customers vehicles that had purchased their own kit. I've only used a Scosche kit once on a 2nd gen Tacoma. The company that I worked for used a Metra kit, new Metra harness, new Toyota clips, new Toyota brackets, new Toyota wiring repair kits, and new Toyota screws because they could charge their customers cost + 30% + labor at $76.50 an hour for each part. I think the kit labor was around $26, it's been a while. Plus labor for each screw, I think it was $3 and change for labor. Each wire harness got labor billed as well. Etc...
  18. Jan 17, 2020 at 1:01 PM
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    Blinged my truck out with some ice.
    dpele, Rick_Taco, Kolter45 and 27 others like this.
  19. Jan 17, 2020 at 1:23 PM
    Tac0love
    Tac0love Better than I deserve
    Scott
    Arkansas
    2014 TRD Off Road DCSB
    TRD Pro suspension with General Springs leafs, 265/75r16 Wild Peaks, anytime Fog light mod, ram mount A-piller mod, WeatherTechs, K&N (drop-in), Tint/Brow, custom grill, shaved emblems, shortened tailpipe. 30" Rigid Horse single LED Bar, sound deadened doors, infinity speakers, Tacoma bed mat Future mods: ultimate headlight upgrade, ultimate fog light upgrade, 33's? who knows?
    Installed a 30" RigidHorse light bar with upgraded wiring harness and $22 Amazon mounts. I hid the oversized switch in the cubby since all my spots are full.
  20. Jan 17, 2020 at 1:33 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    Where'd you get that weird looking beard for the front bumper? Looks "cool" if ya know what I mean :D
    Rick_Taco, Z7Xtreme and DG92071 like this.
