  1. Jan 23, 2020 at 2:54 PM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    Thanks so much for posting this. Good intel.
    Maybe after I finish 100 other things...
  2. Jan 23, 2020 at 3:27 PM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    I was actually thinking something more like this: https://www.amazon.com/Weatherstrip...Collision-Shockproof-Protective/dp/B07PXSHJF6
    One side on the cab, one side on the bed, compressed in the middle with something like thin 3M trim tape between the two to make sure they didn't come loose from one another.
  3. Jan 23, 2020 at 4:18 PM
    Xx Ares xX
    Xx Ares xX Well-Known Member
    South Carolina
    2009 Silver Tacoma TRD SPORT, PRERUNNER, SR5, DC
    That is one option but Rubbers such as EPDM, have much better resistance to heat, light and ozone than unsaturated rubbers such as natural rubber, SBR or polychloroprene (Neoprene). As such, EPDM can be formulated to be resistant to temperatures as high as 150°C, and, properly formulated, can be used outside for many years or decades without degradation. EPDM has good low temperature properties, with elastic properties to temperatures as low as -40°C depending on the grade and the formulation.
    https://www.minorrubber.com/d-strips/407221
    407221 - D-Strips
  4. Jan 23, 2020 at 4:38 PM
    TigerTacoma
    TigerTacoma Well-Known Member
    Upstate South Carolina
    ‘14 MGM Access Cab 4x4
    Dobinson’s coils and shocks. SOS sliders, ditch light brackets, and front skid. Rigid ditch lights. BFG KO(dos) More minor stuff.
    This is true.
  5. Jan 23, 2020 at 5:32 PM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
  6. Jan 23, 2020 at 6:24 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    @Kidwidataco you're working to hard my man. A plastic bottle jammed between your radiator return line & the serpentine belt holds just fine, right up against the drain nipple. No need to drill or zip tie anything! Just don't forget to remove said bottle, mine held on for ~500 miles before I realized what sounded like a bucket of bolts under the hood :anonymous:
  7. Jan 23, 2020 at 6:26 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    That's a good idea too.
    dumontrider[QUOTED] likes this.
  8. Jan 23, 2020 at 6:30 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    This is what I do too. Works like a charm
  9. Jan 23, 2020 at 7:18 PM
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
    That's what I use. Wife hates the smell but they are so inconspicuous she can't find the source!! HEHEHEHE!
    K-DubTaco and boogie3478[QUOTED] like this.
  10. Jan 23, 2020 at 7:23 PM
    dino41
    dino41 Well-Known Member
    San Diego, California
    2015 Sky Silver Crew Cab V6 SR5 Prerunner
    Thank you, I had one of my guys water-jet them out of aluminum. I debadged all around and have one on the driver side of the tailgate. I put a larger one on the raptor grill
    seedy_tea[QUOTED] likes this.
  11. Jan 23, 2020 at 7:38 PM
    APACHETECH
    APACHETECH Well-Known Member
    central pennsylvania
    2013 MGM DCSB OR
    Trd Baja lift Wheelers Aal SCS Ray 10 16x8s Cooper AT3 4S 265/75/16 Trd shift knob Weather tech front and back Heated seats Auto start Immryo mirror mod Mods to install : 4x4 lighted switch Speakers/components/sub and box from Mr. Marv Redline hood struts One piece engine splash gaurds Wish list/looking for : Matching cap Light bar/pods Seat covers Roof rack Step bar Skid plates
    Did a 90k mile service. Changed front, rear diff fluid and transfer case. Changed engine oil. Changed serpintine belt. Changed spark plugs. Fluid filmed frame, first time trying this, hoping this tacoma will last. Also added immryo mirrior bracket, great mod! Saved alot of money thanx to tacoma world.
  12. Jan 23, 2020 at 8:21 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    whats that for?
  13. Jan 23, 2020 at 9:20 PM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    any links on how to paint the dash trim? looks really good
  14. Jan 23, 2020 at 9:24 PM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    Shoot something tells me mine might be in the running
    I should probably check her out soon
  15. Jan 23, 2020 at 10:24 PM
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    :rofl:
  16. Jan 24, 2020 at 12:15 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    2nd that. Thats what i used to do...though i can't say i ever forgot to remove said bottle.....lol
    20somethingwidataco likes this.
  17. Jan 24, 2020 at 12:56 AM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Honestly it’s definitely worth checking out since it takes minimum effort lol
    Hey man I see you lol!
  18. Jan 24, 2020 at 1:07 AM
    theolee
    Theo
    SAN DIEGO
    Nice! I think Google wins lol
  19. Jan 24, 2020 at 1:08 AM
    Island Cruiser
    Kauai
    Baja
    Dude I don’t even want to IMAGINE that smell coming into the cabin even with all the windows down
  20. Jan 24, 2020 at 1:10 AM
    theolee
    Theo
    SAN DIEGO
