  1. Feb 19, 2020 at 10:52 AM
    '14RC
    '14RC WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    I'm not quite done yet--I still need to add some vinyl to the back wall and the driver side B-Pillar--but so far I am *not* really impressed with the noise reduction. It definitely did something to attenuate the noise in the cab but not nearly as much as I expected! I didn't take any before/after noise measurements so that would be my suggestion to you so that you can know definitively how much it actually worked. I pretty much used https://www.sounddeadenershowdown.com/ exclusively for instructions..but I don't know how much longer that site is going to be available because he has closed down shop. Anyways hopefully after I finish the back wall, B-pillar, and put my canopy back on it will have more of an effect.:fingerscrossed:
  2. Feb 19, 2020 at 10:57 AM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    Cool, that's the approach I was going to take. Thank you. Do you recommend any particular source for the materials?
    '14RC[QUOTED] likes this.
  3. Feb 19, 2020 at 11:12 AM
    '14RC
    '14RC WA State
    Seattle
  4. Feb 19, 2020 at 11:46 AM
    MSN88longbed
    Goleta, CA
  5. Feb 19, 2020 at 11:47 AM
    '14RC
    '14RC WA State
    Seattle
    too true! good luck man
  6. Feb 19, 2020 at 12:05 PM
    a14
    a14 Active Member
    Finally got some Husky Weatherbeaters. $161 cdn on Amazon
    DavesTaco68, DocD, GonzoQuick and 4 others like this.
  7. Feb 19, 2020 at 12:15 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Yep, disconnect it quickly and throw it in the garbage.
  8. Feb 19, 2020 at 12:40 PM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    i'd be interested in links to both of those. That Amp attenuator is perfect!
  9. Feb 19, 2020 at 12:49 PM
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Thanks! Like wise :thumbsup:
    Rick_Taco[QUOTED] likes this.
  10. Feb 19, 2020 at 12:54 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Went to the local dealer and picked up a cover for my air pump. The 4 cylinders didn't come with one but I found out that one from a V6 fits perfectly.
    Part # 17613-0P010
    DG92071 and Cativelense like this.
  11. Feb 19, 2020 at 1:19 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    The amp attenuator came with my Fosgate amp (it's solely a bass boost attenuator). Easy install into a factory switch blank with a small drilled hole and a little trimming on the backside of the blank cover to fit the guts of the attenuator.
    Here's a the link to the 3.0/2.4 USB dual port (fits 2nd gens with a tiny tiny bit of shaving some plastic inside the socket on the dash):
    https://www.amazon.com/gp/product/B07FCZC933
    These things rock for tapping into your under-dash fuse panel for power (I used the 7.5A IGN fuse for the dual USB port so it turns off/on with ignition. Use a different constant hot 10A circuit if you want charging power when the truck is off):
    https://www.amazon.com/gp/product/B082GFVCQ1
  12. Feb 19, 2020 at 1:35 PM
    kidsmoke
    Flyover Country
    Got it. I went in search of a panel mounted att. Brilliant. I'll see if one of the many out there aftermarket may fit.
    :thumbsup:
  13. Feb 19, 2020 at 1:38 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Did you need to epoxy or jb weld the switch/ring into your dash? If so, how did you remove it?
    Cativelense[QUOTED] likes this.
  14. Feb 19, 2020 at 1:39 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Yup, have to "glue" the ring to the dash pc. I used JB Weld, and when I needed to pop it out, I just used a small screw driver and just pried it little by little, to make it "pop out".
    Musubi3[QUOTED] likes this.
  15. Feb 19, 2020 at 1:42 PM
    Musubi3
    Big Island
    Ahh, got it. It's funny because I did this exact same mod (love it) and forgot how I even did it already. What color LED's do you have? Mine have the blue LED's.
  16. Feb 19, 2020 at 2:34 PM
    Cativelense
    Nuno
    CT
    I went with white, since the lights on the temp control pc are also white.
  17. Feb 19, 2020 at 3:01 PM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    DCSB 12 slightly lifted Tacoma
    Ripped off all four mudflaps. Scratches all down both sides 6112’s up front on 3rd notch 5100’s in back with Toytech 1” block Skids & sliders from SOS Concepts I got rid of the 1” block and put on Wheelers 1 1/2” progressive AAL. SPC UCA. Be sure your standing on the drivers side when reading the instructions! I swapped sides so many times that I can swap UCA’s in 15 minutes. I put in the 3/4” spacer to eliminate the Taco Lean, and just got my 4th alignment. Traded the OEM rims for 17” Sport rims and a bora bora 1” spacer. I got my Firestone 285/70/17 MT2’s. Pelfreybilt gas tank skid and hi-lift jack should be here Friday. Looking at bumpers, but I think they will wait for next year. So far I’m happy with my build. I’ve done it all myself, leading to a lot of cussing and frustration, but it’s all mine.
    If you’ll stand it up in a corner, mine won’t have to stand alone.
  18. Feb 19, 2020 at 3:15 PM
    kfs90
    kfs90 Well-Known Member
    BR, LA
    2013 Prerunner V6
    I got more fancy bed rails to mount and scored this 3-in-1 kayak rack from Academy for $14!! Wow...there had to have been something wrong in their system.
  19. Feb 19, 2020 at 3:53 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    I had a '13 2.7 and it came with one
  20. Feb 19, 2020 at 4:14 PM
    Procaine
    Procaine Well-Known Member
    Metro-East St. Louis
    2021 Army Green Tacoma TRD OR DBCB
    Installed new headlights! Gave her a more aggressive look.
