  1. Mar 23, 2020 at 5:49 PM
    TigerTacoma
    TigerTacoma Well-Known Member
    Upstate South Carolina
    ‘14 MGM Access Cab 4x4
    Dobinson’s coils and shocks. SOS sliders, ditch light brackets, and front skid. Rigid ditch lights. BFG KO(dos) More minor stuff.
    Usually true.
  2. Mar 23, 2020 at 7:22 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Finally bath time
  3. Mar 23, 2020 at 7:31 PM
    Xx Ares xX
    Xx Ares xX Well-Known Member
    South Carolina
    2009 Silver Tacoma TRD SPORT, PRERUNNER, SR5, DC
    :popcorn:
  4. Mar 23, 2020 at 7:44 PM
    PasswordIsTaco123
    PasswordIsTaco123 Well-Known Member
    Scott
    Greenville SC
    2015 DCSB TRDOR
    2015 Silver Bullet Taco Installed: 5100's W OME887's +1/4leanspacer Toytec Boss Rear shocks Headstrong AAL + 1/2in block Ubolt Flip W superbumps Front Superbumps CB drop kit 4runner Trail Edition 17in Wheels Tires: Falken Wildpeak At3 C-load 275/70/17 Hooke Road Roof Rack Have but may/may not install Ex rear brake lines diff drop
    Got the security bolts on though not sure how effective they’ll be
  5. Mar 23, 2020 at 8:35 PM
    Xx Ares xX
    South Carolina
    Well if that doesn't work. There's always the alternative... o_O
  6. Mar 23, 2020 at 9:00 PM
    Wiener
    Wiener Cunning Linguist
    Wayne
    Eldora, Iowa
    Regular Cab 4x4 2.7
    bull bar, tonneau cover, aftermarket headlight bulbs, AVG vent visors, DeeZee bed mat
    I`ve read that a lot of you are installing Fumoto valves. My question is how tight (torque?) do you use when you install them. Don`t want to do the tighten until it strips then back off a quarter turn.
  7. Mar 23, 2020 at 9:02 PM
    PasswordIsTaco123
    Scott
    Greenville SC
    2015 DCSB TRDOR
    I’m also curious, thinkin bout doin this mod soon
    FreshPots likes this.
  8. Mar 23, 2020 at 9:03 PM
    PasswordIsTaco123
    Scott
    Greenville SC
    2015 DCSB TRDOR
    Maybe both :bananadead:
  9. Mar 23, 2020 at 9:24 PM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    how do you like that dashcam? does it have a rear cam too?
  10. Mar 23, 2020 at 9:32 PM
    romafern
    Rob
    80918 Let's meet!
  11. Mar 23, 2020 at 9:40 PM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    I can't recall if there is a torque spec. I tightened it by hand and just used a socket to snug it down, just like the bolt it is replacing. Love it. Oil changes were easy enough, with the valve, its even easier!!
    kfs90 and PasswordIsTaco123 like this.
  12. Mar 23, 2020 at 10:00 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
  13. Mar 23, 2020 at 10:18 PM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    +1 it's great! Just snug it down, you'll know when its good enough.
  14. Mar 23, 2020 at 10:23 PM
    romafern
    Rob
    80918 Let's meet!
    where did you get the bracket???
  15. Mar 23, 2020 at 11:41 PM
    romafern
    Rob
    80918 Let's meet!
    sorry to hear that. I have to modify one of my bed stiffeners since I got the HiLift Extreme 60 inches. I have a DBC=short bed. Hopefully, you will find a solution...
  16. Mar 24, 2020 at 2:34 AM
    la0d0g
    running for the hills
    For crawling not hauling
    If the fumoto valve doesn't come with a torque spec number I would use the same torque spec as the drain plug. I think Haynes has it at 32 ft-lbs. Searching TW, most responses say 30 ft-lbs so somewhere in that range will work.
  17. Mar 24, 2020 at 4:49 AM
    Gnarbuckle85
    Gnarbuckle85 Well-Known Member
    Sean
    H-Town, TX
    2011 TRD Sport DCLB Silver
    DON'T JOIN TACOMA WORLD!! JUST DON'T!
    Quick pic this morning of last nights hardwork. BAMF front bumper installed. Just need to get alignment done today now that I got the ride height situated with the new 700# springs and new Dirt King UCAs.
  18. Mar 24, 2020 at 5:33 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    I hope I don't start a fight, but 245s or 265s, what does everyone prefer? (75R16)
  19. Mar 24, 2020 at 5:36 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    285s
  20. Mar 24, 2020 at 5:50 AM
    elricfate
    Neat. Not helpful. But neat. :rofl:
    Provrev and PasswordIsTaco123 like this.
