  1. Apr 5, 2020 at 8:38 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Indeed...no belt.
    My daughter drives a 10 year old Yaris with 150k on the 1NZ. Purrs like a kitten without the slightest hint of oil leakage or burning.
    I run M1 HM 5/30 synthetic in it. And an M1-103 filter.
  2. Apr 5, 2020 at 9:54 PM
    RyanTacoMC
    RyanTacoMC 96 Tacoma LX (RIP)
    Bay Area, CA
    2005 Base Access Cab 5-Lug RWD Manual
    4x4 Springs, QA1 TS703s, Rear Sway Bar, blah blah
    I like chrome, dammit!
  3. Apr 5, 2020 at 10:20 PM
    Bigpat_ca
    Bigpat_ca Well-Known Member
    Sacramento, CA
    2014 Spruce Mica TRD off road DCSB
    Where did you find the material?
  4. Apr 5, 2020 at 10:40 PM
    2ndGenOffRoad
    2ndGenOffRoad Well-Known Member
    Los Angeles, CA
    '14 SBDC OffRoad 4x4 '84 4Runner 22RE
    Schmell Fab Sliders ATH Fab Rear Bumper Icon Stage 3 Suspension Front Runner Outfitters Roof Rack Softopper Bed Cover 285/70/17 KM3's on T4R Pro Wheels
    Bigpat_ca[QUOTED] likes this.
  5. Apr 6, 2020 at 12:01 AM
    Thuguon2.7
    Thuguon2.7 Cheeehuuu
    J
    SoCal.
    ‘15 1GRFESR5AC
    :rofl:Lmfao
  6. Apr 6, 2020 at 1:45 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Konig COUNTERSTEER TYPE X
    17x8
    Offset: -10mm
    Backspacing: 4.1"
  7. Apr 6, 2020 at 2:10 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Long week & weekend - Installed @ 65,025 miles
    2015 Off Road Leafs & with a new Toytec aal & ubolts
    Toytec Rear Boss Shocks
    Wheelers Red Extended Front & Rear Brake Lines
    Wheelers Front & Rear Superbumps
    Toytec Diff Breather, ECGS Bushing - 620 eibach/billys
    SPC UCAs, New LCAs
    Toytec Diff drop/carrier bearing/sway bar relocate
    OEM Offroad tow hook & alignment
    Now rides like a dream cause I replaced all the 7 year old factory shit. LCAs & eccentrics were seized enough that I needed to replaced them too. I've been gathering parts for over a year. It looks fucking sweet & no vibes. Tires are next after my wallet recovers & my wife stops noticing!
  8. Apr 6, 2020 at 2:14 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Have a better picture on the limit straps?
  9. Apr 6, 2020 at 2:23 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I finished the prototype bracket for my fuse/relay boxes. Of course I had to drill a hole in the wrong location.
    I made it out of 1/8" ABS plastic and just need to heat it and put a slight bend in it so the boxes are level.
    Once I get it mocked up I can figure out if I need a support bracket (I think I do). I also ordered more wire, I have 18ga. but as I was wiring the fuse box I had the idea to move to 16ga.
    I think I'll use the 18ga. to switch the relay on. The way I'm wiring it, the switch will send ground to the relay (except for the inverter and compressor relays).
    On a positive not, the crimper I bought crimps the terminals just fine. It's just a shame the the fuse box doesn't come with extra terminals in case you make a mistake, which I have.
    GonzoQuick and Cativelense like this.
  10. Apr 6, 2020 at 2:26 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    A picture of the handle I installed on Saturday. The rubber gasket doesn't fit too well.
    GonzoQuick, irayfz6 and Cativelense like this.
  11. Apr 6, 2020 at 2:28 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  12. Apr 6, 2020 at 5:18 AM
    Plain Jane Taco
    USA
  13. Apr 6, 2020 at 5:21 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    Yeah I wasn’t too pleased how the gasket fit on mine either. Otherwise I’m happy with it.
  14. Apr 6, 2020 at 5:28 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    installed my ARB awning room and slept in it:
  15. Apr 6, 2020 at 5:48 AM
    trdtacojef
    trdtacojef Well-Known Member
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    OME Dakar Medium duty rear leafs Total Choas UCAs Elka 2.5” Extended Travel CO and Rear Shocks w/ RR and DC FN FX Pro 17” Silver Rims Nitto Ridge Grapplers 285/70R17
    That's nice. Where did you get the fog bracket from? Was it one of the rigid fog brackets?
  16. Apr 6, 2020 at 6:02 AM
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
    Im not a fan of water as in under pressure on the engine...just me, many folks do it with no issues..I just look at all the wires, and other electronic crap under the hood and thats my opinion.. and yes I do wheel the rig and it gets dirty...
    so to answer, If its really muddy I use a garden sprayer to wet down....and https://www.amazon.com/Adams-Heavy-Purpose-Cleaner-Degreaser/dp/B07PWHXZQ3 to clean....
    most of my cleaning is with rags, brushes, and a spray bottle of above or https://www.amazon.com/Adams-Detail-Spray-16oz-Competition/dp/B001QVFD4K
    and https://www.amazon.com/303-30313-CSR-Protectant-Plastic-Fiberglass/dp/B00KN0UOEE.....but mostly Im retired and cleaning is a pretty continuous thing, the cleaner you keep the
    engine bay the easier it is to spot leaks etc, and the less work it is to keep it clean...
  17. Apr 6, 2020 at 6:12 AM
    TegoTaco
    Ontario, Canada
  18. Apr 6, 2020 at 6:54 AM
    SilverJack
    SilverJack no one
    I've never tried the Adams products, because they aren't carried in my local store. I use the Gunk brand cleaners and protectants, and those work well. There used to be a spray-on product called STEAM, but that disappeared a while ago (maybe it was Gunk, and they changed the name). I usually let the engine warm up a bit then use the original spray or heavier foam formula. Let the grease slide off for 15 minutes then spray it off with hose pressure. The protectant is key to a better shine, so don't forget to use that.
    The Taco is much better at keeping the engine clean than my previous trucks. The lower engine covers and full fender splash guards keep a lot of mud out. It's mostly road dust mixed with water pulled through the radiator that settles on the engine. Then again, I don't do any serious wheeling, unless you count the shit-condition roads that are prevalent around Florida.
    GonzoQuick likes this.
  19. Apr 6, 2020 at 6:57 AM
    Edgehunter
    Edgehunter Active Member
    Hickory. N.C..
    08 Black Tacoma TRD SR5 OR 4.0 6spm
    Not yet
    I got it off eBay..
  20. Apr 6, 2020 at 7:29 AM
    Xx Ares xX
    Xx Ares xX Well-Known Member
    South Carolina
    2009 Silver Tacoma TRD SPORT, PRERUNNER, SR5, DC
