  1. Apr 8, 2020 at 9:30 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Those retros are sick! I almost went with that color scheme with mine
  2. Apr 8, 2020 at 9:49 PM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Looks good, what type of tool did you use?
    2012TacomaGuy[QUOTED] likes this.
  3. Apr 8, 2020 at 10:01 PM
    2012TacomaGuy
    2012TacomaGuy Well-Known Member
    Hayden
    Goodyear AZ
    2012 Pyrite Mica DCSB TRD Sport
    Empty wallet
  4. Apr 9, 2020 at 3:57 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    HA, you’re right about that
  5. Apr 9, 2020 at 4:28 AM
    RoNeil
    RoNeil Member
    Rory
    Massachusetts
    2008 Silver DCSB SR5 6spd
    Plasti-Dip'd some crap
    I pulled my vents to plastidip them and found the most expert wiring job I have ever seen.
    Yep those are 2 12v outlet adapters connected to the radio wiring harness with speaker wire. The thing that really burns my bacon is that the +12V was just a loop of wire tightly taped over the pin. Like they didn't even bother to properly halfass it.
    Anywho I like how the plastidip looks. I like the texture of it. If I want to bother later down the line I might come back, strip it all and hit it with matte black spray paint.
  6. Apr 9, 2020 at 4:57 AM
    scott_b
    scott_b Well-Known Member
    The Old North State
    '12 TRD Sport AC MT
    Is this a direct swap? I found a set locally with 5 miles on them for a decent price.
    Thanks.
    RoNeil likes this.
  7. Apr 9, 2020 at 5:40 AM
    SilverJack
    SilverJack no one
    WTF? Reminds me of the aftermarket alarm I had installed in my Eclipse. The morons had attached the control unit to my shift linkage cable. Every shift moved it back and forth, till finally the wires started shorting. I finally pulled everything apart, found their stupidity, and moved everything to a spot under the dash. That was the last time I ever let anyone do my wiring. This was supposed to be a good and respected shop. Ha!
    Actually speaker wire is a really good conductor of any voltage. It costs more, so you usually use the cheaper wire for power and ground. Just make sure the gauge is rated for the higher voltage.
    RoNeil[QUOTED] likes this.
  8. Apr 9, 2020 at 5:43 AM
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2024 Blue Crush TRDOR 4x4
    I got tired of batteries with no carry handle, so I made this!C48A0390-D78F-44C0-BD2E-1C561EC78E09.jpg
    ok, not really, but damn funny!
  9. Apr 9, 2020 at 6:13 AM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    Save your money on PD and save up for a proper wiring job! (unless you can do that yourself) That is a problem waiting to happen.
    Now that's funny!
  10. Apr 9, 2020 at 6:15 AM
    kfs90
    kfs90 Well-Known Member
    BR, LA
    2013 Prerunner V6
    I got new 255/75r17 on mine.
  11. Apr 9, 2020 at 6:26 AM
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
    wonder if you have any research data on this product? I ran the MSDS and noticed the following....it contains Diboron Trioxide...
    Diboron trioxide is the anhydride form of boric acid. Because of its hygroscopic properties diboron trioxide reacts easily with water to form boric acid
    Just my opinion but any good synthetic today really doesnt require any additive..I wud spend the 30 $ on a oil test at some point in the life of the oil to see what shape its in.
    BTW NOT a oil expert but spent many years in utility plants
    WyldeRayne06 and Rick_Taco like this.
  12. Apr 9, 2020 at 6:30 AM
    wmg
    bill
    2009 FJ
    VERY NICE WORK looks like a custom shop install....sweet.:bananadance:
  13. Apr 9, 2020 at 6:58 AM
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
    maybe try and take it in and get it updated, hopefully they will take care of it and not charge you
  14. Apr 9, 2020 at 7:27 AM
    RoNeil
    RoNeil Member
    Rory
    Massachusetts
    Yeah I am not too worried about the wire itself just the fact that they looped it around the connectors, taped it all up and said "Yeah that's perfect" before shoving it back in there. I wonder what other nonsense I will find as I dig deeper.
    All that wiring went to an aftermarket XM radio that wasn't included when I bought the truck and is of no use to me. All that jank has been removed and I will come back with a soldering iron and heat shrink to do it up properly. It's shocking what people will see as a "good" solution to a problem.
    srspicer[QUOTED] likes this.
  15. Apr 9, 2020 at 8:03 AM
    TacomaNate11
    TacomaNate11 Insta: Tacololaa
    Nate
    SATX
    2014 LT +2 TRD Sport 4x4
    I have one and have been very pleased with the increased throttle sensitivity. I drive on Sport mode and it "feels" as if the truck has more hp and helps it downshift quicker when you need it. Also makes driving 75mph+ so much better because you don't have to mash the pedal so far to the floor.
    Grumpy likes this.
  16. Apr 9, 2020 at 8:55 AM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Battery was letting me down so I upgraded!
  17. Apr 9, 2020 at 9:01 AM
    Mike714
    Mike714 Well-Known Member
    Cypress, CA
    2013 DCSB Prerunner Super White
    Yep, the 3rd gen shocks and springs are a direct bolt in replacement for the 2nd gen. :thumbsup:
    scott_b[QUOTED] likes this.
  18. Apr 9, 2020 at 10:11 AM
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    My front shocks are from a 3rd gen Tacoma Sport.
    Can confirm.
  19. Apr 9, 2020 at 10:23 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    I knew you were going to bob the bed. I knew you couldn't resist. LoL
    EatSleepTacos[QUOTED] likes this.
  20. Apr 9, 2020 at 10:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You know me too well lol
    Rick_Taco[QUOTED] likes this.
