  1. Apr 23, 2020 at 7:07 PM
    BrashBrusier
    BrashBrusier Well-Known Member
    David
    Seattle, Wa
    '10 AC TRD OR
    Lots
    New wheels and tires! :dancingbacon:
  2. Apr 23, 2020 at 7:07 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Wooo that's that's some fancy shit. Welcome to TW
    JKU3000 and BrashBrusier[QUOTED] like this.
  3. Apr 23, 2020 at 7:08 PM
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    I snapped some pics of the inside panel for you. You can kinda see how much I grinded off to line up the bolts. I would have took some pictures of the front but I didn’t have time to redo my rtv job. After I wash my truck this weekend I’ll get you those pics. I marked where the bolts go by lining up the 3rd gen plate to the door with a sharpie and then I drilled a hole there ,same size as the bolts. Then I used my dremel to grind the metal to connect the original holes to the newly drilled holes. You have to hammer in where the bolts are to make the mirror sit flush. It’s a messy job. I painted over it to prevent rust if moisture got in there somehow. My 2015 TRD offroad was also premiered for turn signals so I was able to depin both mirror connectors and reuse the 2nd gen plug. 176AC01B-B093-48BA-97E4-7AA56490B00A.jpgEA057797-69E2-4590-B8E2-ECF279B99F7C.jpgC2BB5030-77FD-445B-B0A2-23F5D21FF492.jpg984C3B87-6AD2-45DE-B6C8-0A74CF8F07CB.jpg52D605AC-3394-4697-AB21-75EF8DA19FBE.jpg
  4. Apr 23, 2020 at 7:09 PM
    TheBlueBeast15
    Kevin
    H-Town
    That looks slick!
    BrashBrusier[QUOTED] likes this.
  5. Apr 23, 2020 at 7:17 PM
    BrashBrusier
    David
    Seattle, Wa
    '10 AC TRD OR
    Lots
    Thanks guys! I just ordered a BAMF plate bumper and sliders last night. Hunkering down for the 3 month wait now. Thinking about some trimmed RDJ fenders to negate this...
    I'm excited to work everything out though and get her trail ready for fall. :D
  6. Apr 23, 2020 at 7:41 PM
    20somethingwidataco
    Will
    Washington State
    Haha I knew you were local! Hope to see you around dude! I was about to ask if that was Seattle but then you updated your location. Check out the NW region section of this forum. We do meets sometimes
    JKU3000 likes this.
  7. Apr 23, 2020 at 7:46 PM
    BrashBrusier
    David
    Seattle, Wa
    '10 AC TRD OR
    Lots
    Awesome, i'll definitely check it out. Thanks
  8. Apr 23, 2020 at 9:14 PM
    DG92071
    DG92071 Well-Known Member
    A couple months back I heavily modified a factory Toyota hitch receiver. It was still bolt on. I towed a heavy boat a month or so ago and all the brackets turned like levers, lol. So I put everything back where I wanted it, retightened the bolts, and tack welded everything. Yesterday I broke half the tack welds and turned the brackets like levers again by towing another heavy boat, lmao. Today I'm lowering the butt end of my truck by adding pounds of steel and a gazillion miles of mig wire to that hitch. Cheers to a softer ride.
    Hahahaha!
  9. Apr 23, 2020 at 10:17 PM
    ssd_dan
    ssd_dan Well-Known Member
    Daniel
    2012 RC 4x4 5spd
    shell, skids, sliders, suspension, bumper, winch, lockers
    I just pulled the trigger on a stage 5 'Fox for Tacoma' from Accutune with the Archive Garage stuff!
    2.5x12 coilovers and 2.5 smoothies, remote reservoirs all around.
    I made it a customized package with Deaver 402s and SPC instead of the Icon stuff cuz, well I just gotta be me I guess.
    Is there a twinge i didn't holdout for DCS? Ain't gonna lie, but with bumpers, winch, lights, etc., etc. yet to come, I get over it.
    Those guys are great at Accutune, although they probably think I am a great something with my myriad questions/comments (and outside the box component changes!). They never flinched!
    Cred to Archive Garage for too immediate feedback on yet more questions!
    Obviously no pics yet, but that should change hopefully soon.
    Err'body stay safe y'all.
  10. Apr 23, 2020 at 11:18 PM
    2ndGenOffRoad
    2ndGenOffRoad Well-Known Member
    Los Angeles, CA
    '14 SBDC OffRoad 4x4 '84 4Runner 22RE
    Schmell Fab Sliders ATH Fab Rear Bumper Icon Stage 3 Suspension Front Runner Outfitters Roof Rack Softopper Bed Cover 285/70/17 KM3's on T4R Pro Wheels
    Such a horrible app...
    Prices are cheaper then what’s listed in the first post.
    1. Used GNTX-177 version, $139 – these are available with a display that shows either compass OR temperature, or one that shows both at the same time.
    2. New GNTX-455 version $209 – these are only available with a display that shows compass and temperature at the same time.
    3. Used GNTX-455 version $159 – these are only available with a display that shows compass and temperature at the same time.
    https://www.tacomaworld.com/threads...s-for-2009-2015-tacomas-other-toyotas.367150/
    stmpjmpr[QUOTED] likes this.
  11. Apr 24, 2020 at 3:43 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    For the bottom brackets there is a dimple spot that is covered with body sealer and has to be scraped flat with a razor blade so that the bracket sits flush. That's where I put the brackets. Some guys have been putting them a little more forward of the sealer but the rivet doesnt hold as well. Once the bottom bracket is mounted on both sides, install the strut with body (black side)facing up and install the upper bracket onto the strut. Bring the strut up until it makes contact with the hood and the upper bracket is at an angle but flat on the hood support. Mark then drill one hole, rivet bracket in place then drill the second hole using the bracket as a template.
  12. Apr 24, 2020 at 4:21 AM
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2024 Blue Crush TRDOR 4x4
    Is that a rechargeable flashlight in the cig lighter?
  13. Apr 24, 2020 at 5:44 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Yessir, KENO Rechargeable LED Flashlight on Amazon. Only complaint is I wish is was about an inch shorter, but at 300 lumens its brighter than anything else I found around that size for this rechargeable type.
  14. Apr 24, 2020 at 5:45 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Hey hey now, stars die too ... humans will be extinct long before that though. :D
    JKU3000 likes this.
  15. Apr 24, 2020 at 6:03 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    You'd think so, most science fiction points to that. Personally I take the Doctor Who approach and know that humans will be around long after the expansion of our ancestral home's sun. :D
  16. Apr 24, 2020 at 6:10 AM
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
    Actually electricity is all about keeping the smoke inside the wires.....once you let it out things dont work so well...:rofl:
  17. Apr 24, 2020 at 7:44 AM
    Hyland33
    Hyland33 Well-Known Member
    Andrew
    Leicester, MA
    2015 Tacoma TRD Offroad
    I did a 190W solar setup last year. Its been so nice not having to worry about having enough power to run the fridge, lights, and keep all my electronics charged up.
  18. Apr 24, 2020 at 8:15 AM
    rescuetaco526
    rescuetaco526 Well-Known Member
    W. Kentucky
    09 TRD Off Road pkg
    Diff Breather, Topper, airbag
    Just dropped it off at the dealership. I need to replace U-joints and carrier bearing. Toyota parts are $570. Are factory parts the best or should I go aftermarket for a stock rig? Is this something I can handle in my garage with hand tools?
    trdtacojef likes this.
  19. Apr 24, 2020 at 9:04 AM
    lenoxluda
    lenoxluda Well-Known Member
    09 Sport
    Found this little gem in my dad's old tool box. TRD wheel&tire tape measure. I think it was a promo item he got back when he was a parts manager for a Toyota dealer here in MN20200423_190816.jpg
  20. Apr 24, 2020 at 9:08 AM
    EricOutside
    EricOutside Well-Known Member
    Eric
    NW Washington
    2014 DCLB Sport 4x4
    Home-built roof rack for spotting platform and/or kayaks & bikes & stuff. Home built bed drawers Firestone Ride-Rite airbags on the rear for level camp trailer towing
    Painted the lower center console to match the blacked-out dash I'd done a couple of weeks ago. It's the little chrome trim that drove me nuts, so I just removed it. Need to do the steering wheel trim and gauge outlines next.
