  1. Apr 25, 2020 at 7:56 PM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    :rofl:
    Casper66[QUOTED] likes this.
  2. Apr 25, 2020 at 8:21 PM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Yesterday I went to change my front diff and transfer case oil. Transfer case went fine, both bolts came out easy. Got the fill bolt on the front diff out, no problem, but the lower drain bolt was pretty well seized. Sprayed it with penetrant and got back to it today. My 10mm hex is 3/8” drive and my breaker bar is 1/2”, was too much flex with the adapter to get it moved far enough to budge anything. Couldn’t get it to budge with my 3/8” ratchet and all my might.
    Eventually said screw it and used the floor jack to push on the end of the 3/8” ratchet. Ended up lifting up the front end a few times but it worked hahah. Eventually I heard a big crack and the suspension settled back down. So happy I didn’t break or strip anything.
    GonzoQuick, dpele, ryfox0276 and 11 others like this.
  3. Apr 25, 2020 at 8:27 PM
    Toysareus
    Toysareus Member Passed Away—2021
    USA
    ive tried everything on my 2 front bed bolts. My impact driver didn’t work (24VDC) soaked bolts with everything. Tried a long cheater bar also. Taking it to a mech on Monday to try a pneumatic impact driver which has more power. Ordered 2 bed bolts from dealer just in case. $12 each. Can return if not needed. Just need to loosen mine to install front Victory4x4 rack.
    one of these:
  4. Apr 25, 2020 at 8:34 PM
    freddy2923
    freddy2923 Well-Known Member
    Freddy
    Phoenix, Arizona
    2015 Barcelona red Tacoma trd or
    Pretty much stock, just a light bar and a avid off road bumper guard
    I did the 4runner upgrade but I assume it’s the same as this?
  5. Apr 25, 2020 at 8:37 PM
    Joker56ace
    Joker56ace Well-Known Member
    Florida
    2010 Trd or , dcsb pyrite mica
    This looks sick might have to look into this , I also had a bed bolt that was stuck , I used a dremel with a metal cut off wheel and cut to ends off , used a 24inch adjustable wrench from harbor freight and I came off no biggie , good luck
  6. Apr 25, 2020 at 8:45 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Painted some stuff black.
  7. Apr 25, 2020 at 8:49 PM
    Toysareus
    USA
    Yeah, it’s sitting in the living room. DW is not happy about that.....water on the left, gas on the right (not installed yet)
    Your idea sounds like a winner, but I’m tired of messing with it.
    Joker56ace[QUOTED] likes this.
  8. Apr 25, 2020 at 8:50 PM
    2ndGenOffRoad
    2ndGenOffRoad Well-Known Member
    Los Angeles, CA
    '14 SBDC OffRoad 4x4 '84 4Runner 22RE
    Schmell Fab Sliders ATH Fab Rear Bumper Icon Stage 3 Suspension Front Runner Outfitters Roof Rack Softopper Bed Cover 285/70/17 KM3's on T4R Pro Wheels
    I’ve been wanting to do the big break upgrade, do you a have a good reference thread for buying everything needed?
  9. Apr 25, 2020 at 9:04 PM
    ThePanda
    ThePanda Well-Known Member
    Kaelan
    Colorado
    6-Speed Manual 2010 Magnetic Grey Tacoma SR5
    Procomp 6" Lift ARB Front Bumper Brute Force Fab's High Clearance Swing Arm Rear Bumper Relentless Fabs Bed Rack Gen 2.5 Face-Lifted Exterior and Interior (mostly) -Fleabay Headlights -Heritage Grille -Scooped Hood Alpha Rex 3rd Gen Pro-Series Taillights Joying 10.5" Android head unit URD Short Throw Shifter Advanced Fiberglass Front and 3rd Gen Rear Fenders 3rd Gen Tailgate RSG Metal-Works Sliders ARB Simpson III RTT Panels Lined w/ Closed Cell Foam (In Progess...) QTP Reverse Screamer muffler TRD CAI SPC UCAs S.S. Brake lines front and rear S.O.S. Performance rear Disk Brake conversion w/PowerStop performance calipers, rotors and pads KMC Tank 17" beadlocks wrapped in 35x12.5" KO2s Long Range Offroad Extended Range Fuel Tank ATO Dual Battery tray w/ 34D Optima Yellow tops and Blue Sea ML-ACR ClutchMasters Hydraulic Throwout Bearing
    How'd you manage getting the cup holders out?
  10. Apr 25, 2020 at 9:07 PM
    DG92071
    DG92071 Well-Known Member
    On a second gen Tacoma you really need the bigger Tundra MC and Tundra dual diaphragm booster. Big brakes aren't going to stop much better than stock Tacoma brakes with the Tacoma single diaphragm booster.
    CGoss likes this.
  11. Apr 25, 2020 at 9:13 PM
    2ndGenOffRoad
    Los Angeles, CA
    Some goodies arrived today!
  12. Apr 25, 2020 at 9:33 PM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    Some much needed spring cleaning. Get all of the road grime and extra stuff off. First day with nice warm weather in a while.
    A couple coats of mother's cleaner wax to get her really clean with rain-x glass and raix-x plastic treatment for the headlights,fog,tails light. Let's see how long she will stay clean for.
  13. Apr 25, 2020 at 9:36 PM
    GMAN62465
    GMAN62465 Well-Known Member
    Gary
    Fairfield County, Connecticut
    2015 White DCSB Off-Road Plus
    Installed my Redline Hood Struts...
    Late Night Modding... gotta love it!
  14. Apr 25, 2020 at 9:51 PM
    20somethingwidataco
    Will
    Washington State
    Just pull up on them. They are only held in by clips.
  15. Apr 25, 2020 at 11:05 PM
    Taco-Obsessed
    Wired up my MESO overhead switch panel today. Wired it up so the compressor switch must be on (throwing power out) for the locker switch to get any power. Tested everything out and plan to install tomorrow. One more step forward.
    20200425_225434.jpg 20200425_225450.jpg 20200425_225351.jpg 20200425_225315.jpg
  16. Apr 25, 2020 at 11:09 PM
    Bigpat_ca
    Bigpat_ca Well-Known Member
    Sacramento, CA
    2014 Spruce Mica TRD off road DCSB
    How easy was that URD install?
    Rick_Taco and will.i.was[QUOTED] like this.
  17. Apr 26, 2020 at 1:00 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    There are alot of questions on this so I will post an overall response/setup overview.
    Current setup in regards to affecting mileage..
    Enkei RPT1 16x8 (18lbs + 60lb tires)
    Wildpeak LT285/75R16 38 psi front/36 psi rear
    3* camshaft gears
    URD MAF calibrator
    Volant CAI with ram scoop
    Stock headers and exhaust
    URD calibrator was easy to install. I have the basic kit that you wire in since the plug and play kit is out of stock. I highly recommend you purchase the plug and play variant unless you really like minor electrical work. The install includes 5 wires. 3 will be spliced and 2 wires intercept the MAF sensor wire.
    https://www.urdusa.com/urd-maf-sensor-calibrator/
    The 3* camshaft gears allow for a fuller cycle, emptying residual exhaust gases more efficiently and allowing for more cool to enter during the intake phase thus netting a small power gain and a change in the power and characteristics. Even after these gears I noticed a substantial change in the vehicle's attitude. If you read this far then I would like provide my oem camshaft gear set to you for free provided you pay for shipping. PM me.
    https://www.tacomaworld.com/threads/cam-gears-with-3°-retard-for-v6-1gr.618266/
    I went ahead and I have been adjusting maps through URD's provided software. I have it tuned extremely lean. I was quite surprised that I gained mileage as my driving has gotten a little bit more aggressive with the bolt ons. The base map was very good, gains were very noticeable at mid to top end and even more so after some head to head comparisons with my friend on 35's and 4.88 gearing.
    In regards to smog tests.. besides having an intake, there is no visual inspection that could detect the changes I have made. The ECU will automatically adjust for the camshaft gears and the calibrator (depending on how well you hid it or not) is basically non existent.
    Bottom line:
    I used to get 240 miles with average driving, almost 350 with strictly highway cruising.
    After the modifications I have hit 320 miles with the same driving habits and mixed city/highway.
    I have no doubt 350 miles a tank will be achievable. That will be inclusive of converting my current habits to grandpa status cruising.
  18. Apr 26, 2020 at 1:56 AM
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
  19. Apr 26, 2020 at 2:28 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Pulled the flares off my bed, installed the LO tone horn (still need to order the HI), replaced the WeatherTechs with carpet mats, ordered a fuse/relay bracket from Paranoid fab, sold my tailgate to @vssman
    Still so much to do.
  20. Apr 26, 2020 at 2:47 AM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    theolee[QUOTED] likes this.
