  1. Nov 2, 2022 at 5:50 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Toolndie7, Bertw192, Relaxo and 9 others like this.
  2. Nov 2, 2022 at 6:04 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Remember that song from Sesame Street?
    One of these things is not like the other', one of these kids is doing his own thang'!
    CPRTaco, Relaxo, OldSaltyDog and 10 others like this.
  3. Nov 2, 2022 at 6:05 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    tclavell and Merling like this.
  4. Nov 2, 2022 at 6:20 PM
    Athena32
    Athena32 Systems Engineer
    Nate
    Colorado
    2021 Tacoma Super White DCSB OR 6MT
    I was browsing Reddit the other day when I came across this post and I figured, "Eh. That's a low-cost, low-effort mod; worth a shot." So, I bought these orange reflective strips and these red reflective strips; red faces the rear of the vehicle and orange faces outward to the side. From a safety standpoint, I don't know if these add any value as I have a white truck and the door frame is already pretty apparent. However, for those that have a dark colored truck this mod might be of some value. I did pull one of the strips off and put it in different locations for testing purposes; I'm happy to report that there wasn't any residue left behind. So, if this mod doesn't appeal to you after a while, it should be easy enough to pull off without having to spend an hour removing the adhesive.
    The idea behind this mod is that hopefully the door is more apparent if it's dark outside and I have it open while sitting in a parking lot or on the side of the street. Hopefully the reflectivity of the strips catch peoples attention as light moves across them.
    :worthless:
  5. Nov 2, 2022 at 6:25 PM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    I did a similar thing but I used white reflective vinyl so they blend in until light hits them. I think it’s worthwhile addition to the truck, you can never be too protective of your investment!
    xCaldazar, Vinny C, Relaxo and 5 others like this.
  6. Nov 2, 2022 at 6:27 PM
    Tacospike
    Two Trucks
    :eek:
    fix it!!
  7. Nov 2, 2022 at 7:10 PM
    hooliganrick
    hooliganrick Well-Known Member
    Rick
    San Diego
    You have alot of light weight strength built into it. It's so easy to go overboard on something like this, and it ends up being too much. An excellent, light weight alternative to a teardrop or RTT trailer setup (which is what I have). Look forward to your next video.
  8. Nov 2, 2022 at 7:42 PM
    5nahalf
    Erik
    Minnesota
    Painted one of my hotwheels today to match my truck. I still need to paint in the headlights and taillights and black out the bed. Going to order spray color match paint and redo it eventually, but for now brushed on touch up paint worked pretty well.
    robin303, Haymaker, JHP and 7 others like this.
  9. Nov 2, 2022 at 7:50 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    No, its a plug n play.. Here's the installation video from AJT
    https://youtu.be/TwE9MgnxqjI
    Monster0Frankenstein likes this.
  10. Nov 2, 2022 at 8:02 PM
    BurlyJim
    BurlyJim Well-Known Member
    Sheridan
    SoCal
    2021 AG TRDOR 4x4 M/T LT
    Made little brackets with a p clamp so my e brake line would stop chaffing on the Deaver bolts
  11. Nov 2, 2022 at 8:18 PM
    disel_V1
    disel_V1 I eat cold pizza rolls
    3rd Gen
    few things here and there.
    Forgot to take a photo… but did the needle bearing to ECGS bushing swap today.
    Best 60$ I’ve ever spent.
    Also, in the event you didn’t know this, you can use promo code “TW” for free shipping. I saw that on another post here, but hey, spreading the good vibes.
    I’m only lifted 2” and got the pulsing vibrations. Luckily, that is a thing of the past!
  12. Nov 2, 2022 at 8:27 PM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    OHHHHH CRAP
    Thanks man
  13. Nov 2, 2022 at 8:52 PM
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    I had a similar problem with my rear lift I ended up moving the oem bracket to the spring clamp(s) closer to the front of the springs drilled a hole then used body bolts at the hardware store. Pix coming.
    thomasburk and BurlyJim[QUOTED] like this.
  14. Nov 2, 2022 at 9:22 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    OhNoItsMe[QUOTED] likes this.
  15. Nov 2, 2022 at 9:25 PM
    RIX TUX
    is your driveway on an angle?
    usmc2msu likes this.
  16. Nov 2, 2022 at 9:30 PM
    SCUfan117
    SCUfan117 Well-Known Member
    2021 DCSB TRD-OR 4x4 Cement
    Nice, I did the same thing earlier this year but wanted to keep mine more subtle.
    TacoJoe480 likes this.
  17. Nov 2, 2022 at 9:34 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I moved my OEM guide from rear to front leaf clamp bracket thing, using existing bolts n nuts. Now theres no interference between brake cable and leaf spring.
  18. Nov 2, 2022 at 9:44 PM
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    I didn’t have any bolts. I’m using the same leaf’s albeit with a 2 inch block. Seeing as I wasn’t gonna go off roading much and I wasn’t gonna load anything in it over 500 lbs. I went the el cheapo way about it.
    BurlyJim and thomasburk[QUOTED] like this.
  19. Nov 3, 2022 at 12:12 AM
    Hotwheels85
    Hotwheels85 Well-Known Member
    2020 Silver Sky TRD ORDCSB
    None
    There is a market for this
    TacoGeeloor[QUOTED] likes this.
  20. Nov 3, 2022 at 3:11 AM
    Forest Moon
    Forest Moon Well-Known Member
    Greater Lowell Area
    '24 OR 6mt Supersonic Red
    Have you noticed a big difference? I'm planning on starting mine this weekend, but whatever doesn't get done will most likely have to wait until spring. Not sure if I should do the doors or start in the rear.
