  1. Apr 1, 2023 at 9:02 AM
    Odlcjro01
    Odlcjro01 Well-Known Member
    Lee
    Rhode Island
    2021 Tacoma MGM DBC SR5
    LT265/75R16 tire, side steps
    Same (6'-1")
    TRDRed likes this.
  2. Apr 1, 2023 at 9:02 AM
    6mtTRD
    6mtTRD Well-Known Member
    2022 Celestial Silver Metallic TRD Off-Road
    Cilajet ceramic coating
    Finally got around to installing the external antenna for the weboost. I have the overland model with the adjustable/folding mount which is very nice and holds the antenna firmly at 90°/135°/180°. I couldn’t use the t-slot hardware that came with it because it’s too wide for my Caliraised roof rack but I had some threaded t-nuts that I was able to use to mount up the antenna.
    My only real complaint is the included antenna arm holding bracket. It’s not really needed but they could have designed it better. First, it’s plastic and I’m sure it’ll become brittle with constant UV exposure. Second, it grips the antenna too tightly and you have to really put some force to get it loose. Third, it’s one fixed height and designed to be used in the t-slot but again it’s too wide for my rack’s t-slot. I think they could have improved it by making it out of aluminum, adding a spring assist to hold and release the antenna mast, making it a threaded rod where we could adjust the height at which it grips the antenna and finally by just giving it a threaded base for use with our own t-nuts. But just my two cents.
    Overall I like it so far. I just did a driveway test but I do have poor reception there. Went from -106 to -102 with the booster off to -94 to -92 with the booster on. No oscillation issues and I’m happy with the antenna positions so far. I’m going to wait to final mount the internal antenna until I can get a true test out in a very low reception area.
    -empty position patiently awaiting a puddle switch kit restock from MESO
    -wiring running to the amplifier under the driver seat
    5CC2C472-50AD-4BD5-AE5E-1CC20294AD28.jpg 668ADFE6-BEC4-4F02-B531-9F9621020564.jpg CB95D48D-50B6-49E1-B5CD-31392FC62883.jpg
    -just going to leave the internal antenna hanging for now until I decide this is where I want it
  3. Apr 1, 2023 at 9:23 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    https://imgur.com/gallery/7jhR84l
    https://www.dxengineering.com/parts...HBtS2vwT0lTX0wdz2RsLlrrTbbbwvJCRoCuP0QAvD_BwE
    Check out one of these for that antenna, give you the option to raise and lower it from inside the truck.
    6mtTRD[QUOTED] likes this.
  4. Apr 1, 2023 at 9:53 AM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    Have you had a chance to test out the weboost? I’m really considering getting one but haven’t pulled the trigger yet.
  5. Apr 1, 2023 at 9:55 AM
    d0ugh0ck
    d0ugh0ck Well-Known Member
    NJ
    Picked up a tonneau cover off market place.
    Dumb question, I put it on in the rain. Will closing it up with a wet bed cause any mold problems?
    andthen likes this.
  6. Apr 1, 2023 at 10:19 AM
    sphinxbccp
    sphinxbccp Not a Well-Known Member
    Tim
    Kathleen, GA
    '19 TRD PRO
  7. Apr 1, 2023 at 10:24 AM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    I'm not a mold expert but I don't think so. I've had my roll up cover for almost four years without any problems. It's not sealed and it get's wet occasionally with O.E. bet mat. I even used it to haul all kinds of garbage. I just clean it after using the bed. But if you're worried, clean and disinfect with some Lysol aerosol to kill some bacteria.
    d0ugh0ck[QUOTED] likes this.
  8. Apr 1, 2023 at 10:44 AM
    Squeakytaco2019
    Squeakytaco2019 Active Member
    Andrew
    2019 TRD off-road
    Fabtech Dirtlogic 2.5 front and back Icon leaf pack option 1
    installed 33x12.5r18s Geolander M/Ts
    Bagman, skippyscage, BJK1280 and 15 others like this.
  9. Apr 1, 2023 at 11:05 AM
    hanlan75
    hanlan75 Well-Known Member
    NNJ
    2023 White Taco SR, 2022 MSM Tesla Y P
    Installed the Flatirons Overland attic storage net.
  10. Apr 1, 2023 at 11:23 AM
    OhNoItsMe
    OhNoItsMe Well-Known Member
    NM
    2022 TRD OR
    Wired up my Amazon LED fog pods lol.. and I had the little bob job painted in MGM. It’s in the middle of a hardtail conversion currently, in case you’re wondering why it’s missing a lot of frame and the seat :laugh:
    MAS, dangeroso, tvterry and 10 others like this.
  11. Apr 1, 2023 at 11:26 AM
    BobbyTacoTRD
    BobbyTacoTRD Skewps Ahoy!
    2021 TRD Off Road
    It's an Ionman Foamcell Pro.
    And here's another pic for fun.:D
    Bagman, andthen, OldSaltyDog and 3 others like this.
  12. Apr 1, 2023 at 11:41 AM
    Waterloo Wonder
    Waterloo Wonder Waterloo Wonder -
    Forrest
    New Hampshire
    21 Access Cab - Army Green,
    It should not. The bed is not fully sealed unless you have done additional sealing. There are also drain holes in the front floor of the bed. If you are worried just put the tailgate down for an hour or so when the rain stops and park slightly uphill. . There are gaps and the corners.
    TRDRed and d0ugh0ck[QUOTED] like this.
  13. Apr 1, 2023 at 11:47 AM
    6mtTRD
    This is pretty neat, I was thinking about having the option to raise and lower the antenna remotely. But I don’t honestly need it day to day, and when I do need it I plan to just raise it once and leave it that way.
    What this has me thinking about though is installing some sort of motor to open and close the light bar cover on my CaliRaised premium rack. Would be nice if when the bar is activated from my spod, the cover would open and vice versa.. any suggestions?
    TRDRed likes this.
  14. Apr 1, 2023 at 11:50 AM
    6mtTRD
    Just the driveway test where it did perform as advertised. I was able to set my alarm and view my home cameras which I usually can’t in my driveway for some reason. Once I get out and about with it I’ll post my thoughts.
  15. Apr 1, 2023 at 12:00 PM
    5nahalf
    Erik
    Minnesota
    https://www.amazon.com/Erfo-Actuato...80375548&s=industrial&sr=1-14&ts_id=350654011
    Linear actuator would work for that.
  16. Apr 1, 2023 at 12:20 PM
    Chairmanmeow66
    Chairmanmeow66 Well-Known Member
    2020 Tacoma TRD off road
    Breaking in 5.29s today!
    dlb97as, Bagman, Stephen1988 and 34 others like this.
  17. Apr 1, 2023 at 12:32 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    looks like fun!
    i'm really hoping to do mine this year, though other factors outside of my control are at play...
    this is what happened to the last truck, that is going to happen to this truck, plus sound dampening:
    RCrumb, Delta09, TRDRed and 5 others like this.
  18. Apr 1, 2023 at 1:04 PM
    tollster64
    tollster64 Well-Known Member
    Pennsyltucky
    2019 TRD DCSB
    It won’t, but after you drive it in the rain, check the seams along the headboard, where the fender sides tie in, it may weep some water there. I used a spare piece of close cell foam on both sides with silicone to isolate the weeping rain that ran into the box.. wasn’t much, but could be a PITA is you have something in the back ya don’t want to get wet..
  19. Apr 1, 2023 at 1:20 PM
    TSAVO
    TSAVO Well-Known Member
    Tempe, AZ
    2018 TRD OR
    In my never ending quest to make the cover of Mall Crawler Magazine and add to the chapter in my book called "Why Do I Buy Shit Like This? I added some matte carbon mirror caps to cover the crappy peeling Toyota clear coat, and these ever so functional blue rock ring bolts and valve caps on my Methods.
    Relaxo, MAS, Delta09 and 9 others like this.
  20. Apr 1, 2023 at 1:43 PM
    LFTD Overlander
    LFTD Overlander Member
    2016 BLK TRD OR DCSB
    yes
    Finally got around to mounting my case on the prinsu rack. Not excited about drilling holes in my storm case but its been collecting dust under the bed long enough. After I mounted the first front bolts I used blue chalk to mark the rear holes and measured them the same distance apart as the front. Worked really well. Tight fit and sandwiched with a rubber washer and sealant around the bolt. Washer under the case too. All black coated hardware except the top washer to hold all down, thats zinc coated.
    20230401_143406.jpg 20230401_111933.jpg 20230401_121439.jpg 20230401_121442.jpg 20230401_122217.jpg 20230401_122946.jpg 20230401_125252.jpg 20230401_153428.jpg
    Relaxo, Vinny C, MAS and 13 others like this.
