  1. Jan 23, 2024 at 12:28 PM
    Trackcomer
    Trackcomer Active Member
    That is one MEAN front bumper you got going there!!! :D
  2. Jan 23, 2024 at 12:37 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    The link says "unavailable".
    Fumotos only drain when you turn a valve and you can get a hose at a store if you need for like a buck a foot and you choose the length.
    OBXPaul and rgljr831 like this.
  3. Jan 23, 2024 at 1:02 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    rgljr831 likes this.
  4. Jan 23, 2024 at 1:05 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
  5. Jan 23, 2024 at 1:06 PM
    Danner488
    Danner488 Well-Known Member
    2016 TRD Sport
    FF is not going to do anything detrimental, but for a few times a year, and if the temp gets above freezing in-between salting, washing your truck especially the undercarriage, would probably suffice.
    I use FF, but if it's the first ever coating I'd look at Krown or Cosmoline. Supposedly the Krown and Cosmoline don't attract as much dirt. Also, if you wanted to switch later on, I believe FF can be put on top of Krown or Cosmoline. However, they cannot be put over FF.
    FF application is pretty easy and can be DIY for about $100 using aerosol cans. Don't know about the others.
  6. Jan 23, 2024 at 1:52 PM
    PondScum
    PondScum OG 303
    Colorado
    2023 Trail Edition
    6112/5160, Deaver J66, Wildpeaks, OTT, Sliders, Armor
    Looks like yesterday’s thread about Tacoma Lifestyle was disappeared. I understand why (I think) but it could be a useful PSA for anyone looking for a vendor. Glad I was able to read how others have been treated.
  7. Jan 23, 2024 at 2:08 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I spent 16 quarters...8 per 3 min/45 seconds.
    First round was quick rinse/bubbles around the wheels/tires (I pre-sprayed them) and also hit the side steps and fender flares.
    Second round was clean-up remaining bubbles/debris...decent job just to get salts off.
    Next, I took her on a 5 mile drive...part of it highway speed...to air her out...and to also get some brake usage.
    Parked my truck and did not set the parking brake.
    All is well.
  8. Jan 23, 2024 at 2:25 PM
    ljerr2
    ljerr2 Well-Known Member
    Iowa
    2020 Tacoma TRD Pro
    I like this idea and wonder if there is a dedicated thread to things we wish we hadn't done.............
    Regarding the valve caps, there are some metal ones with plastic inserts. Allows you to run caps with a little style, but also as you noted the harsh winter conditions (brine, etc) usually do a number on the finish.
    I wish I'd never tried the driver side door grab handle....................some are happy, but I never liked the fit and finish. Great idea, less than great execution. Maybe it has been revised and is better now...........
    OBXPaul, Taco22trdor and wcoffman like this.
  9. Jan 23, 2024 at 2:30 PM
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    Just FYI your 2022 Taco has both the exterior AND interior of the frame painted. This was a mitigation action after the frame fiasco in the 2nd gen Taco. That should help quite a bit.
  10. Jan 23, 2024 at 2:36 PM
    KS1371
    KS1371 Well-Known Member
    Rowlett, TX
    '23 MGM TRD Sport 4X4
    Check out Guild Outfitters
    They have several options as well as blanks to cover openings not needed.
    OBXPaul, Nomad26[QUOTED] and rgljr831 like this.
  11. Jan 23, 2024 at 2:54 PM
    Nadjr
    Nadjr Well-Known Member
    2021 Army Green TRD Offroad
    2D3E832C-928A-443E-B295-8A167F39EB0B_1_201_a.jpg B58F660B-E7E3-4BAC-A9E3-C0947F6AFCD2.jpg Found out my Dad went to The Dark Side. Before and After
    RCrumb, Jbbarrette and markram like this.
  12. Jan 23, 2024 at 2:57 PM
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    I use Woolwax in the rattle cans.
  13. Jan 23, 2024 at 3:07 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Installed TRD Pro skid, with a twist. Had previously installed Talons Garage cat protector which uses the same mounting holes as the 'secondary' splash guard rear 12mm bolts. The cat protector uses a thick spacer to keep it from rubbing the underside of truck. I used the Talons proprietary security h/w at these mounting points which are longer than the OEM due to the added plate/spacer thickness. This also required removing provided skid hardware from these mounting holes (rear most) as they are not long enough to accommodate added thickness of cat protector.
    Note 1 - This applies to '20 TRD OffRoad trim level
    Note 2 - I was using my Race Ramps to give me some room to work under vehicle. My garage concrete apron is on a slope so when it is on ramps the vehicle is almost perfectly level. I do this because while I had splash guard removed I also changed the oil/filter (10K) and did the front diff lube service. Front diff was definitely overkill but not wanting to remove Pro skid later I went ahead and did the service. Also replaced the front diff drain plug with the 90341-24016 Lexus plug. That bitch was tight. While up on the ramps, vehicle was in gear (6M) parking brake was on, and both rear tires were chocked front and back.
    So procedure goes like this:
    1. Remove primary and secondary (front/rear) splash guards. Throw splash guards in recycling bin. Retain rear proprietary h/w at cat protector mount position.
    2. Remove appropriate 17mm hardware at Pro skid mount locations. There are a ton of YT vids that show where these bolts are.
    3. I used my Craftsman motorcycle jack to hold Pro skid in position to start rear 12mm cat protector/Pro skid proprietary security bolts. Stack goes like this: vehicle surface, Pro skid, cat spacer, cat protector, large flat washer, security bolts.
    4. Position Pro skid (still on jack) and start remaining 17mm hardware (4) provided with Pro skid.
    5. Torque 17mm to 33ftlb. 12mm to 21ftlb (using security bolt bit).
    Clean and put away tools. Back down from ramps and wash driveway. Done.
    I did not use thread locker on any of the mounting bolts so I will check periodically.
    BTW In a previous post I sort of slammed Talons for a design issue with the 1st Gen 'wings' they provided with the cat protector. But as far as the protector itself goes that thing is a beast as it is not only a cat protector but also a skid plate. I had sort of forgotten how robust that thing is.
    HandOfGod, rgljr831, OBXPaul and 2 others like this.
  14. Jan 23, 2024 at 3:22 PM
    oostroma
    oostroma (Boomer)
    Ontario
    I have accounts on .ca and .com
    Sometimes pricing or availability is better on .com
  15. Jan 23, 2024 at 3:28 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
  16. Jan 23, 2024 at 3:58 PM
    Plaintaco
    Plaintaco Well-Known Member
    Houston, TX
    2023 Access Cab TRD Off Road
    I have had a valvomax on my wife’s Subaru Crosstrek for several years. It has worked great! It makes oil changes quick and clean. I put the front wheels on ramps and have plenty of room to drain the oil directly into my used oil jug.
  17. Jan 23, 2024 at 4:08 PM
    jericho777
    jericho777 Well-Known Member
    2023 TRD Off Road
    I've read FF is a lanolin base also PB Blaster Surface Shield. Probably the same as Woolwax?
    There are YouTube videos comparing them.
  18. Jan 23, 2024 at 4:23 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Hello, Ben. Welcome. It’s a safe place for you here.
    Your bank account? Not so much.
    TCB2020, D-knoww, thomasburk and 5 others like this.
  19. Jan 23, 2024 at 4:31 PM
    wcoffman
    Wish I’d never done the gas tank fill mod. Can’t seem to get it right. Within a day or so I find the needle has moved off F. I’ve even tried different filling stations. Leave it at the airport for a few days and that seems to delay things but not for long.
  20. Jan 23, 2024 at 4:37 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    you all are just enabling/encouraging me….
