  1. Oct 20, 2024 at 4:21 AM
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Tell her not to open the door with her left hand… but then she will be upset with all the rules for the truck. I’m definitely not talking from experience or anything.
  2. Oct 20, 2024 at 6:17 AM
    steve1503
    steve1503 Well-Known Member
    New Hampshire
    2020 SR5
    rkcrawl, PondScum, MTBTACORN and 5 others like this.
  3. Oct 20, 2024 at 8:59 AM
    jeisfoto
    jeisfoto Active Member
    Midwest
    '20 DCSB OR
    Dobinsons MRA, AG + 12” smoothies, Deaver Stg 2, 4.88s, 35s, tuned...
    Been dealing with moisture in my driver side OEM LED headlight. Popped the cover off of the bottom set up the leaf blower underneath. Successfully dried it out. Removed and cleaned the cover gasket and reinstalled. Later I did a rinse less wash on the truck and immediately saw moisture again. So there must be a bad seal around the lens. Anyone have experience resealing?
  4. Oct 20, 2024 at 10:03 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    steve1503[QUOTED] likes this.
  5. Oct 20, 2024 at 11:51 AM
    Taxx
    Taxx Well-Known Member
    ditto
  6. Oct 20, 2024 at 12:00 PM
    D-knoww
    D-knoww D-Know
    Washington state
    2019 Tacoma TRD Sport Longbed
    You sound a bit unhappy with the Taco.
    RIX TUX and SHADOWDRIFTER19 like this.
  7. Oct 20, 2024 at 12:33 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Rotated the tires, have a look at this front going to rear today. Would you guys replace tires at this point, or wait some more miles? How many miles would you wait in this case?
    Road_Warrior likes this.
  8. Oct 20, 2024 at 12:54 PM
    D-knoww
    D-knoww D-Know
    Washington state
    I would replace them. But I live in the PNW and winter is coming. You live in Florida. I would probably give it a few more miles. Just me.
  9. Oct 20, 2024 at 1:28 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    If you can afford I would replace. You always need traction dry or wet. It seems you're in Florida so no snow or black ice, but you get rain. If your budget is tight you might squeeze a few more miles out of them but I would save for replacements. Looks like your alignment is out too.
  10. Oct 20, 2024 at 1:47 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Yeah, these tires would be scary in winter conditions.
    DavesSR5, RIX TUX and Road_Warrior like this.
  11. Oct 20, 2024 at 2:05 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I might be headed for a northern state this fall, I hope to have them replaced before then. Beginning the search for a sale soon.
    Good eye on the alignment, that's a long story. This is the worst alignment issue I've ever been in but it will be addressed before new tread is put on. Dealer effed up the alignment a whileback, then I replaced lca bushings with polyurethane which turned out to be crap and only recently did I recognize the root cause and that was corrected this weekend.
    Thanks.
    skyking3 and Road_Warrior like this.
  12. Oct 20, 2024 at 2:18 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
  13. Oct 20, 2024 at 2:31 PM
    topochico23
    topochico23 Well-Known Member
    2022 DCSB SR5 V6 4x4
    Must be autumn, because I've got the rake
    halfway through installing suspension lift and thought the extra 2 inches in the rear was amusing
    burnttaco7, spin180, andthen and 7 others like this.
  14. Oct 20, 2024 at 2:40 PM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Not today. But this last week I got a GFC topper installed
  15. Oct 20, 2024 at 3:26 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Started rewiring my bed winch. Before it was just hooked to a lead acid battery that was mounted near the front of the bed. Worked great, but froze pretty easy in the winter, and was a pain to make sure it was charged all the time so I could pull my ice gear up the ramps.
    So, I have replaced the ring terminals on the winch power lines with a giant anderson plug, I have a flush mount anderson plug that I want to put in the bed near the front, then wire it up to the main battery with a cut off switch.
    spin180, andthen, Kane50 and 5 others like this.
  16. Oct 20, 2024 at 3:45 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I have these from my days in Ohio. I would use them when shoveling my sloped driveway and rarely feel like my feet were slipping out. I still keep mine in the glove box of my truck in AZ.
    https://www.rei.com/product/760281/yaktrax-pro-traction-system
  17. Oct 20, 2024 at 4:12 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Pretty slick! Well not really just the opposite. Thanks, I may look into those.It's better than the alternative; broken Hip, broken arm, or busted tooth.
    I grew up in ohio columbus, so I know how those winters can be
  18. Oct 20, 2024 at 4:14 PM
    RichochetRabbit
    I used them to run on ice as sell ... cannot run as fast as dry but I never went down when running on ice.
    thomasburk[QUOTED] likes this.
  19. Oct 20, 2024 at 4:47 PM
    MGMDesertTaco
    @no vtec 4me would know how to reseal them.
    https://www.tacomaworld.com/threads/retrofit-and-bhlm-headlights.565466/
    jeisfoto[QUOTED] and musicisevil like this.
  20. Oct 20, 2024 at 4:49 PM
    MGMDesertTaco
    Replace asap and get an alignment done at the same time.
