  1. Mar 26, 2025 at 8:13 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    long island
    2022 TRD SPORT DCSB
    Rotated the tires yesterday AND used a torque wrench on the lugs
  2. Mar 26, 2025 at 8:54 AM
    jasonvt
    jasonvt Well-Known Member
    Vermont
    2021 Tacoma DCSB TRD Off Road Manual
    Exactly what I’ve been looking for. Ordered. :spending:
    Nito[QUOTED] likes this.
  3. Mar 26, 2025 at 10:26 AM
    dallasmavs92
    dallasmavs92 Well-Known Member
    DFW
    2020 OR 6MT
    Ok I guess you're never done modding
    99kx250, MrMustacho, andthen and 13 others like this.
  4. Mar 26, 2025 at 12:05 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I am sorry ... you implying that "modding" is not a constant state, for life ... ? :notsure:
  5. Mar 26, 2025 at 4:06 PM
    Taco4Fishing
    Taco4Fishing Well-Known Member
    2023 MGM TRD Sport DCSB 4x4 AT
    Experience from long distance trip across 11 states.
    + small unobtrusive form factor fits nicely behind the rear view mirror
    + easily installed and connected to app. Original connected with Dongar.
    + voice commands work well to save video
    + clarity in daylight. Easy to read signs and license plates (after export). As expected, not as good after dark. Some license plates get washed out if there’s bright lights nearby.
    - app is slow to connect sometimes
    - videos grainy when viewing on app (but message while watching tells you to expect that unless exported)
    - constant power cable relatively expensive
    After a parking lot incident (luckily it was witnessed and plate number shared) I added a rear camera and switched to the Constant Power Cable so that I could use Parking Guard (not Parking Mode). Works as described in the instructions (had to re-read a few times until it made sense). I set the timer to 10 minutes and then the cameras “wake up” if the vehicle is tapped or you reenter it. Second camera was only $120 on Amazon.
    No problem with battery drain (at least with a relatively new battery). Easily routed power cables, front and rear with a trim tool. Hid the plug behind the front kick panel.
    thomasburk and RCrumb like this.
  6. Mar 26, 2025 at 4:23 PM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    Greatly appreciated! I was looking at the mini 3, has better picture quality, and also the ability to add a rear camera. My only concern was routing the power from the rear camera? Thanks again
  7. Mar 26, 2025 at 4:52 PM
    K9tacoma
    K9tacoma Well-Known Member
    Austin
    Central Ohio
    2023 Tacoma TRD Off Road - Lunar Rock
    Alright so as welcomed as the BigBanger bar is and how cool the amber backlight is, it ain't so cool when it's pitch black out and I've got a bright orange hood. Small little adjustment/toggle switch I added to be able to cycle the backlight on and off whenever I want while still remaining automatic from my DRL signal. Basically here's how it's wired in case anyone else wants to copy or has any other use for a double relay setup like this. I've got it to an ignition powered fuse (wiper) so it's not holding the relay open when the truck is off (DRL signal is already off so it's not needed).
    Truck is running for both of these pictures, technically pushing in the DRL switch turns off the amber backlighting to the BigBangers, but whatever, it all works now and is able to be toggled on the fly.
  8. Mar 26, 2025 at 5:59 PM
    Ty'sTaco
    Ty'sTaco Active Member
    Tyler
    Anchorage, AK
    2019 Cavalry Blue Tacoma TRD OR DCLB
    TRDPro grill Southern Off Road roof rack Copper Rugged Trek tires Tyger side steps Ute Tray
    rgljr831, andthen, robin303 and 16 others like this.
  9. Mar 26, 2025 at 6:15 PM
    Vince H.
    Vince H. New Member
    Vincent
    Chicopee MA.
    2022 TRD Off Road
    roof rack. decked midsize. softopper
    installed new Led bulbs for the fog lights from Autoone, and the hitch mount light from diode dynamics...just waiting on the low and high beam led bulbs along with the reverse ones.
    20250326_205948[1].jpg 20250326_210009[1].jpg 20250326_210046[1].jpg 20250326_210035[1].jpg
    andthen, MTBTACORN, dand and 8 others like this.
  10. Mar 26, 2025 at 6:37 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    In preparation for my Underland rear seat molle panel, that hopefully arrives tomorrow, I got the first layer of 80mil sound deadening mostly done.
    It is already way quieter than when I had it completely bare and the rear wall vents still get plenty of air flow.
    Tomorrow I will put on a layer of 150mil foam sound deadening, then the molle panel on top of that.
    There is so much extra storage space with the plastic cubbies removed.
    andthen, RCrumb, MTBTACORN and 5 others like this.
  11. Mar 26, 2025 at 6:58 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Agreed. I couldn’t believe how much extra room there was when I removed that plastic piece in preparation for my goose gear seat delete. It’s like 25% more space back there now.
    thomasburk and ssd2k2[QUOTED] like this.
  12. Mar 27, 2025 at 6:01 AM
    MNGTaco
    MNGTaco Well-Known Member
    2020 BRM Tacoma SR5
    Not today, more like a couple of weeks ago, but I'm just getting around to posting. So maybe 6 weeks ago or so I went to get gas and noticed the fuel door on my '20 was off-center and I had to basically pry it open, only to realize the steel close to the top of the hinge was bent and I had to force the door close. Consulted TW and YouTube to find that bent fuel door hinges are a common'ish taco problem. I still have no idea how it got bent because you'd think I would have noticed doing it. I assessed options from just buying the OEM part and leaving it black, or painting it myself. Then I found Painted OEM Parts, did a little research, and decided to take a chance.
    It's a pain to drill out the rivets and remove the old door to attach the new one. I used rivet nuts with stainless screws to attach it, which isn't ideal since I assume the rivet nuts will rust at some point. That said, the part came within about 10 days, the color match is pretty good, I've got a working fuel door, and at least for me, the cost was worth it (YMMV).
    MAS, spin180, akimmel and 13 others like this.
  13. Mar 27, 2025 at 6:15 AM
    sphinxbccp
    sphinxbccp Not a Well-Known Member
    Tim
    Kathleen, GA
    '19 TRD PRO
    musicisevil likes this.
  14. Mar 27, 2025 at 6:57 AM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
  15. Mar 27, 2025 at 7:14 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    The dissenting opinionated spirit of rix lives on! I think you missed a comment about gas holes a couple pages back though… Slackin
  16. Mar 27, 2025 at 7:25 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    I had gotten the glare blockers before installing the LED tag lights, but I don't have any glare not using them, so for now anyway, I am not using them...
    My thought on this, it might be the color of the plate and it reflecting the light off it as TN runs a dark blue plate now...
    andthen and musicisevil[QUOTED] like this.
  17. Mar 27, 2025 at 7:31 AM
    musicisevil
    Alaska
    2019 TRD Sport
    Since you’ve got the blockers in hand and led tags, post pics of the screen while in reverse both with and without blockers (temp install or whatever). For science!
    I’m always down to eat some crow
    DavesSR5[QUOTED] likes this.
  18. Mar 27, 2025 at 7:32 AM
    BoomerGVNG
    long island
    2022 TRD SPORT DCSB
    LED bulbs in non-LED housings = JAIL
  19. Mar 27, 2025 at 8:02 AM
    TacoDell60
    TacoDell60 Well-Known Member
    don't put led bulbs in halogen housing. this is a major downgrade
    BC Hunter and BoomerGVNG like this.
  20. Mar 27, 2025 at 8:04 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    LEDs in fogs are nowhere near the problem that LEDs in projectors create.
    TacoDell60 and musicisevil like this.
