  1. Apr 14, 2025 at 12:15 AM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    When I was shopping the OEM version online at my local dealer was actually cheaper than the pop n lock. Actually a lot of things are strangly a lot cheaper OEM. 1in rear lift blocks(the ones in the TRD lift kit) for example were only $8 each.
  2. Apr 14, 2025 at 4:42 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    the oem version is 10x what an actuator kit and wire would cost. Thats alot of savings
  3. Apr 14, 2025 at 5:49 AM
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    It just works and continues to work. Not sure if a non-functional, non-OEM unit is worth the effort. They're louder and I've only ever heard of them failing to function, not the OEM version. I mean we bought a Toyota partly because of their reputation for reliability, didn't we? Why would you not use the OEM gear when given a choice? Again, to each their own but that's my irrational logic.
  4. Apr 14, 2025 at 6:00 AM
    auskip07
    Skip
    Atlanta, Ga
    if you're non DIY and couldnt fix it yourself i could understand. For me i just had to buy the actuator and they came in a pack of 2 for 15 dollars. Wiring, self tapping screws etc were already in my parts bin.
  5. Apr 14, 2025 at 6:02 AM
    OldSaltyDog
    Hampton Roads VA.
    Mine didn't come on my truck either, I bought it through my dealer and installed it myself, (FYI that's DIY) so I fail to see the difference other than the OEM version doesn't fail...
  6. Apr 14, 2025 at 6:04 AM
    auskip07
    Skip
    Atlanta, Ga
    about $100 dollars difference? If it fails you just use your key
  7. Apr 14, 2025 at 6:07 AM
    OldSaltyDog
    Hampton Roads VA.
    To each his own but the ENTIRE reason I got mine was to not have to use my key every time I need into my bed. Fortunately the OEM version doesn't fail!
    raptor2018 likes this.
  8. Apr 14, 2025 at 6:08 AM
    alphaomega420
    alphaomega420 Well-Known Member
    2019 SR SX V6 RWD
    I actually feel so much better about it than I did when I posted about it late last night lol. I figured that the sale probably wasn’t all that it was cracked up to be, I feel like most places nowadays inflate their sales a little bit to make things sound like a better deal than they are. I actually just found the same unit for $350 at Crutchfield. :smash:
  9. Apr 14, 2025 at 6:08 AM
    auskip07
    Skip
    Atlanta, Ga
    how often do you think it fails? every 3-5 years?
  10. Apr 14, 2025 at 6:17 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
  11. Apr 14, 2025 at 6:19 AM
    OldSaltyDog
    Hampton Roads VA.
    I would like to think the OEM one I installed in my Taco will last the life of my truck and never fail, that is how Toyota does things. I'm not sure how much the Pop and Lock version is but the complete OEM kit is 169.00 which isn't too bad in my opinion. Hey, it's totally up to the individual, if you prefer the non-OEM version then go for it, I was simply suggesting that if you want to avoid failures you're probably better off getting their OEM kit which is very comprehensive and comes with OEM installation instructions that are easy to understand. Has the heat shield for near the exhaust, the new grommet and everything you need.
  12. Apr 14, 2025 at 7:27 AM
    Junetaco03
    Junetaco03 Well-Known Member
    Bay Area, California
    2019 TRD OFF ROAD 4x4 DCSB
    Removed my son’s toy gun from my truck bed. Had me freaking out on my way to work, thinking something was wrong with my suspension!
    907 Taco, Tcoma16, Beep and 9 others like this.
  13. Apr 14, 2025 at 7:45 AM
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    Installed some King 2.5s over the weekend and I must say I had different expectations as all I can say is they ride rough. Trying to describe the feeling… they ride stiff, you feel everything on the road almost like you’re constantly driving on rocky dirt roads.
    Road Bull likes this.
  14. Apr 14, 2025 at 8:04 AM
    Junetaco03
    I was disappointment too when i installed them on my 2nd gen. For my 3rd gen I went with Bilstein 6112 and oh boy they are nice! Maybe try switching coils, that might help.
    xp0nex[QUOTED] likes this.
  15. Apr 14, 2025 at 8:11 AM
    xp0nex
    xp0nex Taco Noob
    I am running the standard 600lb springs and I barely have any preload. 5 threads on the driver side and 3 or 4 threads on the passenger side just for a mild 1.5” lift.
  16. Apr 14, 2025 at 8:21 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    :duel:
    cgraham30240 and 3GTCMLMTD like this.
  17. Apr 14, 2025 at 8:40 AM
    Junetaco03
  18. Apr 14, 2025 at 8:59 AM
    Camilletaco
    Camilletaco New Member
    Camille
    2017 Tacoma TRD off road
    Installed the Hooke road roof rack over the weekend and this thing is SWEET. Paired with the bed rack, you can’t deny… looks GOOD!
    greg8765, 99kx250, RCrumb and 10 others like this.
  19. Apr 14, 2025 at 9:34 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Give them a couple of weeks to settle in before you judge. They will be stiff at first. If you can get out somewhere and flex the suspension some it will help. I find that not running my sway bar has helped my ride quality with my Dobinsons...it also helps the capability offroad.
    215Yota likes this.
  20. Apr 14, 2025 at 10:00 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    The reason to use trail grid pro is that they open whatever unit you buy and solder/shrinkwrap/tesa tape the wiring harness to make everything truly plug and play with your vehicle. The price also includes whatever aftermarket unit is required to maintain steering wheel controls, a dash kit (bezel) and usually any other adapters necessary to maintain stock functionality. Although sometimes you still need accessories for extra fluff like XM or GPS, but that depends on the manufacturer and the capabilities of whatever HU.
    Check the “whats in the box” tab, price out the add ons, then weigh how much the convenience of the entire thing showing up at your door already set up and ready to install is worth to you. The unit I want has the maestro RR ($175 on crutchfield) included in the price for example.
    Not trying to talk you into buying a new stereo from them, just sharing what the service that TGP offers is and pointing out that their “sales” are usually the same as their everyday pricing
    Burns likes this.
