  1. Mar 20, 2018 at 5:35 PM
    blam827
    blam827 Well-Known Member
    Brent
    Peachtree City, Ga
    White 2019 TRD Sport 4x4
    TRD Shift knob TRD gun metal wheels w/ 265/65-17 BFG LED fog lights K&N Cold Air Intake Redline Hood Struts Morimoto XB Headlights MBRP Dual Cat Back Exhaust Toyota Mud Guards LED interior light kit ( blue ) Meso Stage 2 tail lights Meso Puddle lights Meso chrome delete interior Meso Gas Hole Meso Ultimate turn signals Front Anytime Camera Mod Supreme Suspension 3”/2” lift Roll up Tonneau Cover Southern Styje Off-road Slim-line front bumper Warn 10000lb winch with synthetic rope Matt Gecko LED Blue Bed lights / front white hood light De-badge and De-vinyl Tinted front windows. TRD Pro Skid Plate Bed rug Auxiliary fuse block bracket Blue Sea aux 6 circuit fuse block w/50amp circuit breaker JLT oil separator Remote starter mod KTJO bowl lights. ( blue ) Cali raised ditch lights w/brackets Winch shut off switch. Still to do: Rock sliders.
    Started the demo on the kitchen today. Took off bead board and some ugly ass 1980s wall paper underneath. Debating on just taking it down to studs or skim coating it and painting. CF02FC3C-561C-4B66-A434-811D448D1A41.jpgDC798DF3-9F90-4E17-B2AB-9148DB6D55A7.jpg
  2. Mar 20, 2018 at 5:39 PM
    famof5taco
    famof5taco Well-Known Member
    Shelton
    VA
    17 TRDORDCSB
    pro grille, raised vinyl "TACOMA" letters on tailgate, de-badged, tint, ARE truck cap, BFG KO2s waterport, vinyl Tacoma inserts in dash, red "TRD Engine"push button start, MTF!!!
    Did you remove the wheels from the truck to dip, or did you plastic behind the wheel while mounted...or maybe the easier question. What was your process? these came out good.
    AMorash likes this.
  3. Mar 20, 2018 at 5:57 PM
    Jon8251
    Jon8251 Well-Known Member
    Jon
    Southern MD
    2017 Quicksand DCLB Off-Road
    TRD Pro suspension HS Progressive AAL 255/85-16 DC Extreme Country TRD Pro grille Softopper Internal LEDs Other misc crap
    Thanks. I am really happy with the results. Here is what I did:
    1. Taped the lug nuts with blue painters tape
    2. Put paper/plastic behind the wheel
    3. Warm the cans in very hot tap water before/during use. This will make it spray more evenly and give you a smoother finish. I think this is the most important step to ensure you get a smooth finish.
    4. Get a spray can tool, helps control the can and is much more ergonomic
    5. Use lots of coats
    6. Cover the fender areas with something to limit overspray. I can't see it, but I can feel it there. It will clean off easy I'm sure, but it is an extra step
    7. I would tape the tire approximately .5-.75 inches from the rim. The thick overspray close to the rim is very easy to peel off. But as it gets thinner, it is a little more difficult to remove from the rubber.
  4. Mar 20, 2018 at 6:02 PM
    Doc's Rig
    Doc's Rig Your opinion is not statistically significant
    Doc
    The Natural State
    2016 4x4
    Dropped the nerf bars and finally got the sliders installed. Opted for weld-on 4x Innovations. Between measuring and welding the legs and mounting plates, then prepping and painting, then welding to the truck, the process took about a week. Not the best pics, but good enough.
  5. Mar 20, 2018 at 6:03 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    I used a hole saw to cut a 6 inch hole in my front splash shield and used some scrap pieces of thin sheet steel and aluminum strip bent by hand to make an access port for oil filter changes, requiring the removal of only one bolt instead of four bolts and the shield.
    It’s sturdy even without utilizing the one bolt for securing the door.
    I might purchase proper skid plates before the next oil change. If not, this will do for now.AB240EB6-27A6-4503-885A-CC395D9C36E5.jpg CFFBCD05-341C-40BC-A948-375FEE8F6624.jpg E4A7838B-64D2-4DEA-AFD5-BADD3D3A53FE.jpg 5929E344-9CE3-4F8E-8B47-5A4B990E1EBB.jpg
  6. Mar 20, 2018 at 6:06 PM
    famof5taco
    Shelton
    VA
    17 TRDORDCSB
    Thanks! I did the bumper and liked the results but was less worried of the look as it will eventually get replaced. But the rims I like and want to get right on the first go. I also want to paint the center cap tan to match the truck and do something different. But don’t copy me, we’re both in SoMD haha
  7. Mar 20, 2018 at 7:51 PM
    TRDOBSESSED
    TRDOBSESSED Well-Known Member
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    threw on a matte black hood decal
  8. Mar 20, 2018 at 7:53 PM
    GrowUp_Al
    GrowUp_Al Member
    Alex
    Southern California
    2016 Tacoma TRD Sport
    Icon Stage 1 (upgrading to Kings 2.5) JBA UCA Icon Rebound 17" Wheel 275-70-17 BFG K02 tires Demello Rock Crusher Slider K&N Air Filter Pioneer DMH-2660NEX Amplifier Alpine Power Pack KTP-445U Speakers Upgrade. Dash - Kicker H631SFJ101 Tweeter. Front - Kicker 47KSC69304 Rear - Kicker 47KSC6504 Powered Subwoofer Kicker 46HS10 Dashcam Thinkware Q800 Pro
    Icon Stage 1, Icon Rebound 17" wheels, Demello Offroad Rock Crusher Slider (replaced Westin steps), 275-70-17 BFG K02 tires. No rub after alignment.
    ccallen, SilverII, Parker315 and 10 others like this.
  9. Mar 20, 2018 at 7:56 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Ok, let's see, there's not a damn thing in that post over there that you listed I wouldn't eat or drink.
    Love the boots too! :thumbsup:
    DubfromGA[QUOTED] likes this.
  10. Mar 20, 2018 at 8:02 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Was browsing around today and saw that mobil1 has their $17 rebate active again. That reminded me of something else I needed. Ended up ordering the Toyota aluminum oil filter housing and a Bulletproof Fab front recovery hook to replace the wimpy stock Sport recovery. Also picked up a 3 ton 5/8" shackle to use until I trim the Pro skid to clear the 3/4" shackle. Not bad for $108 total after discounts. Now to find out who has that mobil1 oil on sale. Rebate good through May 31 but might as well stock up for the next oil change around Thanksgiving (if I can put on another 6k miles and get to 24k miles by then). That should give me time to pick up a Fumoto.
    Beerpayzdabillz and DubfromGA like this.
  11. Mar 20, 2018 at 8:05 PM
    AtlasPilot
    AtlasPilot Active Member
    Colorado
    MY17 Tacoma SR (TRD Wannabe)
    ICON Stage II RCI Aluminum Skid Plates TRD 16in Wheels Falken 33x10.5 tires ARB rear locker RCI Rock Sliders
    ksanti808, ccallen, SilverII and 9 others like this.
  12. Mar 20, 2018 at 8:20 PM
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    ^^^ @AtlasPilot you have a motocross playground right across the street from your driveway! Why would you feel the need to load up your bike? lol
    Intrepid and DubfromGA like this.
  13. Mar 20, 2018 at 9:26 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    Are you serious!? Volks!!?? Damn you went through 3 sets of wheels already lol
    Or is it more like 4 or 5 sets?
    DubfromGA likes this.
  14. Mar 20, 2018 at 9:30 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    yes I did! You have a great memory. haha.
    I'm done. I even said so in the video.
  15. Mar 20, 2018 at 9:34 PM
    pepto90
    pepto90 Well-Known Member
    Preston
    2017 White Tacoma TRD OR 4x4 AT DCLB
    Too many to count.
    Trick we used to keep the tires clean:
    tonered and DubfromGA like this.
  16. Mar 20, 2018 at 9:41 PM
    9TRDTCO
    I’ve been eyeing the same set of wheels but for some reason these are more affordable they just have a different name o_O
    I know, I know these are the Ray’s knock offs! :(
  17. Mar 20, 2018 at 9:44 PM
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    They're 'tribute' wheels. ;) Check out FN Wheels too. They don't list them on the site but owner seems like a good guy.
  18. Mar 20, 2018 at 10:18 PM
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    cool stickers and a baseball card With clothes pin, sounds awesome ! wicked
    What fuse tray did you use it fits great?
  19. Mar 20, 2018 at 10:42 PM
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
    tollster64 likes this.
  20. Mar 20, 2018 at 10:47 PM
    MidTennTaco
    MidTennTaco Active Member
    Middle Tennessee
    2017 Tacoma TRD Sport 4x4 DCSB
    Dobinsons 2” Lift Kit TRD Pro Grill TRD Pro Wheels Cooper STT Pro 265/70/17 TRD OR Skid Plate Bakflip MX4 Tonneau Cover 3M Tint to match rear 10 Coat Plastidip Badges Removed Air Dam Removed Old Man Step
    Today I got inspired with a free Serpa holster. The Glock has been out of my carry rotation for 2 years now and I’ve been looking for a reason to get rid of it/trade it in so now it’s found new life. I swear these DIY mods are far more gratifying than spending thousands on pre-done stuff.
    Glock 26 G4 9mm
    Blackhawk Serpa Holster
    8-32 x 3/8” screws to mount to galvanized plate
    9 washers to cant the holster
    3M Extreme double-sided tape (no screws, no holes)
    05E2D041-F57F-43E8-BBE4-186AF15CB5B3.jpg 06A9478B-0B09-4D24-B5B7-DF77A4F982BE.jpg 9C68B8AA-346E-4BCD-97FF-ECCBE43006F4.jpg
