  1. Oct 31, 2020 at 12:18 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Maybe I’m missing something. Don’t these reflective parts need to be on the doors if you want to them to be of use? Otherwise, the only time they are visible is when the doors are open AND obscuring light from reflecting off of them from an approaching cyclist or vehicle.
    Tiny's Taco likes this.
  2. Oct 31, 2020 at 12:24 PM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    2E6160E1-0E6D-4019-96E3-AFC82B091E60.jpg 00E891FE-748E-41F1-917F-A7D02FC39D72.jpg Hard to tell I’m sure but I’m installing some second skin mass loaded vinyl to the floors on top of the butyl rubber layers for sound deadening
    TnTHicks and davidstacoma like this.
  3. Oct 31, 2020 at 12:30 PM
    Ta2edShady
    Ta2edShady Well-Known Member
    Dan
    Virginia Beach
    2016 Inferno DCLB Sport
    Rancho Leveling Kit Yokohama Geolandar A/T
  4. Oct 31, 2020 at 12:37 PM
    Karminski
    Karminski Well-Known Member
    Virginia
    2016 Tacoma D/C M/T TRD Off-Road
    Like @Tamagotchee mentioned, the chrome trim comes off as a separate piece and no masking is necessary - at least on my 2016 OR. I ended up purchasing an SR Black Trim ring after plasti-dipping my original. I didn't get enough coats on the trim ring, but the piece behind the logo is holding up great. Check out the Dip Your Car YouTube page (DYC) for great advice for dipping. You probably need a light 1st/2nd coat, then maybe 4 more wet coats from what I remember. Below is the original plasti-dip, you can see a small spot on the lower left of the right where the black was coming off eventually.
    Edit: I dipped the grill inserts on my BMW 440 and did more coats - it's holding up great.
    I still have the old ring in the garage, if you want to see a photo of the back to see what the tabs look like; then I might be able to snap another photo.
    TnTHicks, markram and Bourbon[QUOTED] like this.
  5. Oct 31, 2020 at 12:48 PM
    RallySOP
    RallySOP Well-Known Member
    Tom
    2018 Tacoma OR DCSB
    Quick update on the bluing of keys. There just isn’t enough ferris material in the alloy keys for the blue to take hold. I will try again with aluminum black which should work much better. Updates will take a while as I need to order the chemicals.
  6. Oct 31, 2020 at 12:49 PM
    Bourbon
    Bourbon Well-Known Member
    2020 MGM SR5 DCSB
    How do I take just that chrome ring off? I’m assuming there is a tutorial/step by step webpage somewhere?
  7. Oct 31, 2020 at 12:50 PM
    Bourbon
    2020 MGM SR5 DCSB
    Mine is an SR5 also.
  8. Oct 31, 2020 at 12:51 PM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Not allowed to post this goodness without links to the products! please and thank you!
    Tacospike[QUOTED] likes this.
  9. Oct 31, 2020 at 12:55 PM
    ClassyTacos
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    My Squareone Creations Frame caps went in like a charm. So much better than what was there.
    Very well built. Here is a little before and after. They fit perfectly with C4 Fab Low Pro Bumper. I will have the install video up in the next couple of days. It took 2 minutes to install both sides. @RyanDCLB
  10. Oct 31, 2020 at 12:56 PM
    Karminski
    Virginia
    I searched on YouTube but don't remember which video I used - if I find it, I'll post it. The finial pull is not quite as easy as some of the videos, you do have to pull a little harder than some suggest - I think they "practiced" to get a good video :wink:, but it's not very difficult to get things apart.
  11. Oct 31, 2020 at 1:00 PM
    Bourbon
    2020 MGM SR5 DCSB
    I found this thread.
    https://www.tacomaworld.com/threads/removing-grill-bezel-only.561862/
    Karminski[QUOTED] likes this.
  12. Oct 31, 2020 at 1:26 PM
    Karminski
    Virginia
    This video does not come from a very authoritative source and I wouldn't use it as a great HowTo, but it does show a lot of detail on what the tabs look like so you have a good feeling of what's going to hold things together. What they run into is pretty realistic and very similar to my experience as opposed to someone making it look too easy :wink:
  13. Oct 31, 2020 at 1:30 PM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    I just added the N2 smartphone module to the N2 remote starter I had previously installed in my ‘19 TRD OR. Jimmy was so patient and helped me programmed the module. I’m so glad I went the N2 route. Thx again Jimmy!
  14. Oct 31, 2020 at 1:35 PM
    Tacospike
    Two Trucks
    You are completely correct.
    This also goes for the literal exact same purpose for doing this black out mod in the first place. The doors would have to open to even notice.
    But does reflect from map lights in the dark vs having them just black so a minimal upgrade at best.
  15. Oct 31, 2020 at 1:37 PM
    Tacospike
    Two Trucks
    ClassyTacos[QUOTED] likes this.
  16. Oct 31, 2020 at 1:38 PM
    Rodchester
    Rodchester Well-Known Member
    Baton Rouge
    2017 Quicksand SR5 DCSB V6
    Weather tech mats, LED interior lights and reverse lights, tube steps, bed extender, bed mat, folding bed cover, TRD Pro grill, blacked out badges and wheel center caps. Kicker speakers(all 6). Front bed rail header. Under hood LEDs. Tufskinz door and interior foam inserts. Chrome interior door handles. Fumoto drain valve. Aluminum oil filter canister. Rear view mirror with Homelink. Quick charge USB charging ports. TRD badge on grill. MESO fuse box cover. Redline Tuning hood struts. Ceramic coating. Pop & Lock auto tailgate lock. LED bed lights. Lower bumper LED light that bar. MESO coin holder. TRD cat back exhaust. Hikari Ultra LEDs high and low beams. 2020 TRD Sport wheels and TRD center caps. RSC Nano dashcam. DSM from the Taco Garage. Blue Sea dual USB outlet on back of center console. KDMax7.0
    As easy as it is to take apart, I would do that instead of taping off. In fact, if you never want it chrome again, rough it up, use a good etching primer and paint it. The plasti dip is eventually going to come off.
  17. Oct 31, 2020 at 1:49 PM
    HeyWannaTaco
    HeyWannaTaco Well-Known Member
    Dan
    Ontario
    2019 Red DCLB SR5
    OVTuned, OKX Skids, AVS In-Channel, N-fab Predators
    I think there was a youtube video out there, but the chrome ring is basically held in by chrome colored clips on the backside, just squeeze 'em and release. If I recall there are about ten all the way around the ring. I seem to recall a bunch of screws as well, but it was last March when I did it, so memory is a bit hit and miss here. It's easy once you have the grill off, you'll see what needs to come apart.
    Bourbon[QUOTED] likes this.
  18. Oct 31, 2020 at 2:03 PM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    FedEx just delivered the Lower Control Arm Skid Plates from R4T a few minutes ago - will install them tomorrow.
    13txtaco, TnTHicks, markram and 7 others like this.
  19. Oct 31, 2020 at 2:16 PM
    tcoffin
    tcoffin Well-Known Member
    2017 Tacoma
    Wash, clay bar, wax
    markram and RivetNutBob like this.
  20. Oct 31, 2020 at 2:20 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Looks a lot better than the plastic caps! And, much cleaner without the extensions.
    Here is my impulse buy for today. Midland MicroMobile 15W GMRS
    My previous buys include a disconnect plug for the KTJO pop and open, so I can frequently remove my tailgate, and mini ditch/puddle lights! (warm white) @Nimble9 @ARCHIVE
    :thumbsup: I'll post some night shots when I'm done with the @MESO puddle pods.
