  1. Mar 22, 2021 at 3:49 AM
    mrchristopher2
    mrchristopher2 Well-Known Member
    2020 TRD Pro 6spd
    I have one with a Bakflip cover installed. You have to do a bit of modification for it to fit “right” after you install the cover due to the fact that the rails it mounts to are moved down below where they were previously. If you search my post history you can find pics of mine. Also I found a bed divider locally that had not been used for $100.
  2. Mar 22, 2021 at 5:17 AM
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    I used a hair dryer to heat the OEM mirror back by blowing warm air around the edge s of the mirror. The I pushed the mirror so it was tilted up as far as possible. Grabbed the bottom edge of the mirror with both hands and just pried it up and out. The clips will release - and you'll see a metal clip of the driver's side. Don't think you screwed up when you don't see one on the passenger - you don't need that clip for the Spotter Mirrors.
    To put the new ones in, I again used the hair dryer to heat the plastic on both the new mirror and the holder. I started on the upper corners to pop the new ones in - they do take a bit of force.
    AbnMP13[QUOTED], markram and Devious6 like this.
  3. Mar 22, 2021 at 5:47 AM
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
    I've had mine in for about as long as I've had my truck with no issues.
    rgljr831 likes this.
  4. Mar 22, 2021 at 6:26 AM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    I really like the look of the recessed winch plate but I wonder, being so does it limit you from using it at a high angle like if you're on a hill? Just curious, never used a winch before.
  5. Mar 22, 2021 at 6:38 AM
    johnnyroid
    I'm an acronym kind of guy, but as a Maiden fan also, I have no idea what you just said.
  6. Mar 22, 2021 at 6:41 AM
    johnnyroid
    Lots of crayon storage ;-)
  7. Mar 22, 2021 at 6:52 AM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    If you go thru water above the door sill, water will get into thr trans. Found out myself lol
    rgljr831 and JDSmith like this.
  8. Mar 22, 2021 at 7:01 AM
    Kev301
    Kev301 Well-Known Member
    Kevin
    2020 Trd Off-road DCSB
    I got it from Saints Off-road
    PNWAG2021MT[QUOTED] likes this.
  9. Mar 22, 2021 at 7:02 AM
    Kev301
    Kevin
    It’s recessed but when you are at that angle the rope wouldn’t come in contact with the bumper.
  10. Mar 22, 2021 at 7:02 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    If I did that I might as well forget about going home, my spouse would disown me. She likes the Taco more than I do.
    markram, gabbo2112, dlb97as and 2 others like this.
  11. Mar 22, 2021 at 7:03 AM
    Kev301
    Kevin
    The are Baja design squadron for stock location
    playdixie[QUOTED] likes this.
  12. Mar 22, 2021 at 7:06 AM
    reymataco
    reymataco Well-Known Member
    Denver, CO
    2020 DCLB Off Road Premium in Slowsand
    The 3rd gen Tacoma panel is rated at 85 watts.
    https://www.cascadia4x4.com/collections/vss-system
    It is paired with a second battery from Offgrid Engineering (managed by a RedArc BCDC1225D)
    https://www.**************/collecti...harging-technology-for-toyota-trucks-and-suvs
    A DROK voltmeter in the back measures the voltage on the second battery. All roof rack lights and the rear power bus are wired to the second battery.
  13. Mar 22, 2021 at 7:10 AM
    reymataco
    Denver, CO
    CBI
  14. Mar 22, 2021 at 7:10 AM
    TacoMaps
    TacoMaps Well-Known Member
    Nick
    Oklahoma
    2020 TRD OffRoad DCSB AT
    REDARC_Ryan likes this.
  15. Mar 22, 2021 at 7:11 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Walked by mine and looked at the box of clazzios in the bed and wondered when the hell I am going to install them
    Shayne, markram, 907rx7 and 2 others like this.
  16. Mar 22, 2021 at 7:17 AM
    Adk46er
    Adk46er Well-Known Member
    Upstate NY
    2021 DCLB MGM
    OEM bed mat Redarc Liberty brake controller Softopper US Truck Cap Rack Predator steps Tailgate inserts Bumpershellz Rear SumoSprings
    Good to know. Thanks for the info!
    Goatfrog[QUOTED] likes this.
  17. Mar 22, 2021 at 7:21 AM
    jhartfelder
    jhartfelder Member
    Jack
    FL
    2017 MGM Tacoma SR5 4x4
    I grabbed the dimensions from another TW thread from user RCRcer (LINK), but the dimensions match the OEM part exactly which doesn't work for a flat piece of aluminum. The OEM part has a lip that bends down where it meets the tailgate. The aluminum will bind up on the bed when you shut the tailgate, so I took about a 1/4" off the top of the panel closest to the bed. In the drawing that is the bottom edge.
    rgljr831 and oostroma[QUOTED] like this.
  18. Mar 22, 2021 at 7:22 AM
    ld25ca
    ld25ca Active Member
    Canadian thing - bill c21, OIC & FRT = legislation in progress to ban firearms, airsoft and paintball etc by those who might be triggered by that Iron Maiden sticker.
    rgljr831 and johnnyroid[QUOTED] like this.
  19. Mar 22, 2021 at 7:26 AM
    TacoMaps
    Nick
    Oklahoma
    Speaking of the Redarc brake controller, tested it out on Saturday using an 18ft shop trailer. Worked like a champ and I love how it looks like it came with the truck.
  20. Mar 22, 2021 at 7:35 AM
    Pilvr83
    Pilvr83 Well-Known Member
    Panhandle, Florida
    2020 Tacoma Limited
    Spiker struts, tailgate step, MESO...$$
    I have one I use with either the Diamondback or he original Toyota cover without issues.
    It rests about 1” off floor of bed.
    knob is 1/4” from top of bed rail.
    Hope this is what you seek.
    TnTHicks, RCrumb, markram and 4 others like this.
