What Have You Done To Your 4th Gen Today?
Discussion in '4th Gen. Tacomas (2024+)' started by Gmak621, Jun 1, 2024.
  1. Jul 14, 2025 at 5:21 AM
    #3101
    Iqudayo
    Iqudayo Well-Known Member
    Antonio
    Toyota Tacoma
    Corrected the shaking hood they should have done this from factory.
    Found on Amazon
    Automotive Door Weather Stripping 10Ft Car Door Rubber Edge Trim Seal Strip Gasket with Top Bulb Easy to Install for Car Bus Camper Boat RV Truck Doors and Home Applications
    CJBiggs, richietaco and vprgts like this.
  2. Jul 14, 2025 at 5:31 AM
    #3102
    GrrrMaker
    GrrrMaker 2024 Tacoma SR5 4x4
    Woodstock, GA
    2024 Celestial Silver SR5 4x4
    DV8 OE Plus Side Steps MCX Skid Plate Bonobo Front Recovery Points Bonobo Hitch Recovery Point (2" Soft Shackle) Redline Hood Struts Volume Knob for 8" Infotainment Screen (TacoMods on Etsy)
    FYI, I chose to place the camera on the driver's side edge of the rear glass as I have the sliding back glass window that slides to cover the passenger side of the glass and I didn't want the camera in the center rear view area when looking in the rear view mirror. Also, be REALLY careful routing the cable down the A pillar. There's an airbag there so you have to disconnect the battery, remove the bolt at the top of the pillar trim and carefully pull the upper part of the trim off. At that point you'll see that you can route the cable on top of a couple of metal brackets that sit above the airbag. That keeps the cable from interfering with the airbag should it be deployed in an accident. From there you just carefully route the cable past the bottom of the trim panel to the left edge of the dash and then down to the rocker panel. The rest is easy.
  3. Jul 14, 2025 at 12:15 PM
    #3103
    tonymac
    tonymac Well-Known Member
    Waco, TX
    2024 TRD Sport
    What exactly was added and where? I cannot tell from pic…
    bbartol likes this.
  4. Jul 14, 2025 at 4:20 PM
    #3104
    1stDueL22
    1stDueL22 Well-Known Member
    Va. Beach, Virginia.
    2025 Bronze Oxide Off Road LB Premium
    Won a give-a-way from Muslogy Auto that sells aftermarket stuff for the Tacoma. They offered someone all items bought during Amazon prime day sales money back so I got their center console cup holder inserts and the organizer. I am very happy with their stuff even before I won the give-a-way. Looking at getting some more items from them.
    K-DubTaco likes this.
  5. Jul 14, 2025 at 6:21 PM
    #3105
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    voz[QUOTED] likes this.
  6. Jul 14, 2025 at 8:36 PM
    #3106
    shotgunshooter3
    shotgunshooter3 Well-Known Member
    Somewhere in the Southwest
    2025 DCLB TRD OR, Blue Crush Metallic
    Mud flaps
    It ended up being a two beer job, and I think I overtorqued the clamps a bit, but I managed to get my Diamondback Switchback "factory second" installed. Damned if I can tell what the blem is that made it a second. So far so good, and it will definitely keep sticky fingers away from my snowboards and backpacking gear...
    PDKTaco, TacoYankee, Burns and 2 others like this.
  7. Jul 14, 2025 at 11:54 PM
    #3107
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
    Changed my oil for 2nd time, 6000 mi. I made less mess this time than last. The filter is on front of the engine and the drain plug is in the rear so it can get messy with just one oil drain pan that can't be in two places at once that are both dripping.
    Hardy likes this.
  8. Jul 15, 2025 at 3:02 AM
    #3108
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
  9. Jul 15, 2025 at 4:52 AM
    #3109
    Iqudayo
    Antonio
    Toyota Tacoma
    I added the weather stripping to the section in the yellow circle.
    Any help you need just ask
    tonymac[QUOTED] likes this.
  10. Jul 15, 2025 at 10:02 AM
    #3110
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    what are the big cup holders in the back? i need some
  11. Jul 15, 2025 at 10:06 AM
    #3111
    CalgaryQuicksand
    CalgaryQuicksand Well-Known Member
    Calgary, Alberta
    2025 White Tacoma TRD Offroad Double Cab
    Skid plate. Running boards.
    DYLEN car cup holder expander it’s called. I got them from Amazon.
  12. Jul 15, 2025 at 12:18 PM
    #3112
    Rogue_12
    Rogue_12 Well-Known Member
    Plastidipped the front emblem and added some low profile wind deflectors (truck needs a wash)PXL_20250715_180603760.MP.jpg PXL_20250715_180623449.MP.jpg
    Iqudayo likes this.
  13. Jul 15, 2025 at 12:18 PM
    #3113
    K-DubTaco
    K-DubTaco Well-Known Member
    Ken
    VB
    ‘25 TRD Off Road
    What running boards did you go with?
  14. Jul 15, 2025 at 3:52 PM
    #3114
    CJBiggs
    CJBiggs Well-Known Member
    2024 4th Gen Tacoma OF Hybrid
    The project nears completion of Phase I.
    Ditch Lights
    Trailhunter Rock Rails (installed today)
    Nomad Convoys
    Toyo AT3's
    Cab Roof Rack
    A few misc items (wiring, a couple lights and mud guards) is all that remains.....for now.
  15. Jul 15, 2025 at 4:42 PM
    #3115
    fostuhh
    fostuhh Well-Known Member
    Foster
    2024 Ice Cap Tacoma TRD Pro
    New boot goofin’ on the Pro.
    RRW RR7-h
    17x8.5 +25
    BFG 315/70/17
    Only change needed was removing the crash bar in the front wheel well.
    Delta09, PDKTaco, afkcmt and 8 others like this.
  16. Jul 15, 2025 at 8:56 PM
    #3116
    Gmak621
    Gmak621 [OP] Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    How do the Load Range F tires feel?
  17. Jul 15, 2025 at 11:15 PM
    #3117
    fostuhh
    Foster
    can obviously notice the weight difference. But as far as ride quality, it's not bad at all. I was concerned a bit I'll be honest but pleased so far.
    Gmak621[QUOTED][OP] likes this.
  18. Jul 16, 2025 at 6:40 AM
    #3118
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2024 Blue Crush TRDOR 4x4
    BOUGHT ONE LAST NIGHT!!! I'm back, baby! I got rid of my 2009 TRD PreRunner about 4/5 years ago, but now I'm back with a new 2024 Blue Crush TRDOR 4x4! I lucked out and this was the only one in that color that the dealership couldn't sell for a bit due to the brake line recall. My wife and I were literally grabbing something to eat on the way to go pick up a new 2024 Ford Bronco Black Diamond edition. But I couldn't be happier to be back in a Taco! As stupid as it sounds, TW is one of the things I missed the most!
    Delta09, PDKTaco, swordfish and 16 others like this.
  19. Jul 16, 2025 at 12:16 PM
    #3119
    1stDueL22
    Finally got new shoes. SCS Ray10 on 285/75/17 Open Country AT3's.20250716_120112(1)(1).jpg
    Delta09, PDKTaco, infantry317 and 8 others like this.
  20. Jul 16, 2025 at 4:25 PM
    #3120
    stmpjmpr
    Jimmy
    why not the Bronco? you made right choice of course
