  1. Mar 29, 2021 at 6:26 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    The sleeve ones seem to fair much better. The D-Ring gets beat to shit because it's the furthest away from the other two. Leverage is a bitch.
  2. Mar 29, 2021 at 6:28 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Leverage and 35's are a bitch lol
  3. Mar 29, 2021 at 6:35 PM
    theesotericone
    Bishop CA
    It's not the 35's fault. Plenty of guys run them and don't break shit. It's Johnson Valley's fault. That place is the real deal. lol
  4. Mar 29, 2021 at 6:58 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    CS144 from a Cadillac. I think they peak at 120, idle around 80.
    https://www.tacomaworld.com/threads/cs144-swap-q-as.268008/
    It’s less about output of your alternator from what I’ve read and more about the ability for AGM and liquid lead acid batteries to accept the charge. Lead acid typically slows down the charge rate once the battery reaches 75% ccharge and then very slowly charged the rest, most likely never getting back to 100%, which explains why I was always fighting to keep my fridge running on long times sitting stationary, because the battery was never full to begin with.
    The only way to really top them off is with a charger optimized for them, most of the issue being alternators don’t put out the voltage to get the batteries to take a charge - I’m not electrically savvy, so this is just from what I understand that the alternator doesn’t put out the voltage of like 14.5 volts, so amps mean very little
    https://redarcelectronics.com/blogs/blog/choosing-the-best-vehicle-battery-charger
    If I switch to lithium iron phosphate (they do make 50ah lithium batts they exact size of a Odyssey PC 1200 so I can keep my mounting points the same) I may get a DC to DC charger like a Redarc which also has a built in mppt charge controller for solar all neatly packaged in an ip68 package that prioritizes solar before the alternator for the most efficient charge and smart charges so it won’t cook your alternator which is an issue when charging lithium batteries because they take a charge so efficiently the alternator overheats.
    https://www.amazon.com/dp/B08G3M697...MI5aejhfHW7wIVYh-tBh2SCghpEAAYASABEgLXnvD_BwE
    I went with the 10x1 (hooks to 1 battery) instead of a 5x2 (hooks to 2 batteries) because you can basically link your batteries with an ml acr and charge them both at the same rate or force them apart and just charge the house battery since the starting battery usually is discharged much less.
    It’s more than double the cost to do a 10x2, which makes sense since you’re charging at 20 amps
  5. Mar 29, 2021 at 7:08 PM
    Laxtoy
    Maltby, WA
    And one other helpful piece of info for the Noco charger I used- it only comes with hardwired battery terminal eyelets so it’s intended to be mounted, whereas a lot of their other chargers come with a plug to use alligator clips or terminal eyelets so you can store it elsewhere.
    The one I got is ip68, I wanted something as resilient as possible
  6. Mar 29, 2021 at 7:54 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I like you. Lol
  7. Mar 29, 2021 at 9:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If I understand this correctly, it still has to be plugged into the AC power to do its job doesn't it?
  8. Mar 29, 2021 at 9:46 PM
    Laxtoy
    Maltby, WA
    Yessir, useless otherwise
  9. Mar 29, 2021 at 10:23 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ok. That makes more sense now. I was trying to figure what the advantage was, and its the convenience of the permanent mounting, at least for one battery.
    It is true that AGM types need a higher voltage (more than 14.3 VDC to get fully topped off, And yeah, even the CS144 alt can fall a little short at times, though mine always starts off at 14.6 but then tappers off. So cruising down the highway, it is always less than that.
    My fix was similar, just not a permanent install. I have a CTEK smart charger I've used for several years. I have not felt the need to permanently mount is as I like to use it to 'condition' both of my Northstar AGMs every so often.
    https://www.amazon.com/gp/product/B006G14FK8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8
    jubei and Laxtoy[QUOTED] like this.
  10. Mar 29, 2021 at 10:44 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Is there a better alternative to the cs144 alternator that does work better for agm batteries?
  11. Mar 29, 2021 at 10:48 PM
    betterbuckleup
    Ian
    Concord, CA
    I did a voltage boosting fuse for mine which increases the charging voltage to a higher, more agm friendly value.
  12. Mar 29, 2021 at 10:53 PM
    Dan8906
    Daniel
    Concord, California
    Oh yeah I remember you sending me that link, it was sold out at the time. Send it again !
  13. Mar 29, 2021 at 10:58 PM
    betterbuckleup
    Ian
    Concord, CA
    Das it mang and Laxtoy like this.
  14. Mar 29, 2021 at 11:02 PM
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    I'm too old for this, crawling under my truck, hard concrete, back cracking BS anymore. My son makes me feel young and dumb again. I sure pay for it later.
    Fernando[QUOTED] likes this.
  15. Mar 29, 2021 at 11:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The CS144 works great with my dual AGM batteries.
  16. Mar 29, 2021 at 11:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    2nd and 3rd gen alts are designed with fuel economy in mind. Basically a voltage on demand type of system. That device you linked to is helpful for them to overcome their voltage producing limitations. The CS144 alt doesn't have the voltage limitations found with 2nd and 3rd gen OEM alternators.
  17. Mar 29, 2021 at 11:14 PM
    Laxtoy
    Maltby, WA
    Yeah, I wish it had a disconnect and didn’t need to be hard mounted, just didn’t look far enough into it and after I was into it I was too cheap to send the thing back. I don’t like the room it takes up, but it has its benefits, even a little like shore power if all I’m doing is running my fridge
    That’s a good solution, if upsizing fusing is a cheap hack to get more out of it that’d be awesome.
  18. Mar 30, 2021 at 12:13 AM
    betterbuckleup
    Ian
    Concord, CA
    Yea the ECU plays a roll in charging with 3rd gens, but I'm pretty sure that the 2nd gen charging system isn't that much different than ours with respect to the voltage output & circuit logic.
    The voltage boosting fuse is still applicable for us though. According to optima (the battery I have), ideal max charging voltage is 15V. So it'll get charged quicker & stay more "topped off" with a voltage closer to that. And the stock alternator output voltage is far from that.
    I have my OEM alternator though, so can't speak too much to the CS144 side of it. I would imagine that the fuse would still help though based on the results you posted in your previous post of peak 14.6V on startup & lower after that.
  19. Mar 30, 2021 at 5:07 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I've never chewed up the D bushing that badly but they don't last a year for me. I tried putting a Tbar clamp on one side to hopefully help minimize the side to side. Not sure if it helped or not. The long bolt sleeve near the differential is cracked the whole way around the welds on my truck. I'm sure that doesn't help things either.
    Been considering solid mounting it but kind of worried the energy will just go into bending tie rods.
  20. Mar 30, 2021 at 6:07 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Same here man. It sucks
    Yetimetchkangmi likes this.
