  1. Aug 9, 2021 at 10:23 AM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    I actually found it in this thread a few pages back, about two weeks ago. It's actually a ford ranger carrier bearing from IEDLS, I called to place my order. I'll back track some and see if i can tag you in the post.
    unstpible likes this.
  2. Aug 9, 2021 at 10:24 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    where are you guys getting this cup holder from. Just it just fit on the lip of the shifter console, or are there screws to hold it on.
  3. Aug 9, 2021 at 10:28 AM
    BeLance89
    Brandon
    Huntsville, AL
    @CrippledOldMan
  4. Aug 9, 2021 at 10:29 AM
    BeLance89
    Brandon
    Huntsville, AL
    It's BH3D printing
    http://www.bh3dprinting.com/
    requires screws
  5. Aug 9, 2021 at 10:43 AM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    @BeLance89 , thank you sir, that's an interesting read.
    BeLance89 likes this.
  6. Aug 9, 2021 at 10:45 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Not a bad suggestion, and actually, probably my next play. I'm going to take it to our mechanic and have him put it on a lift.
  7. Aug 9, 2021 at 10:50 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I have them and haven't noticed much difference in my steering. Not overly anyways.
  8. Aug 9, 2021 at 10:51 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Interesting.
    Might not be that much of a difference, but I definitely did notice decreased turning range.
    Before my tire would be almost right on the frame at full lock, and now there's like a 1+ inch gap to the frame at full lock.
  9. Aug 9, 2021 at 11:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean you have to extend out the tie rods to get the toe right, so it should make up for any loss in motion.
    If you're looking at the back of the frame(rear of the wheel area) when you say that the frame arches inwared(obviously) so is that what you're seeing? the wheel if further forward thus the arch is deeper.
    If you mean at the front, well, idk haha
  10. Aug 9, 2021 at 11:13 AM
    betterbuckleup
    Ian
    Concord, CA
    Yea I got it all aligned just fine, but still experience that.
    And yea I was talking about the rear of the wheel area, behind the coilover toward the rear of the truck.
    that's a good point. I didn't think of that with where the frame starts coming more outboard the further back you go. So makes sense for there to be more room if you put the wheel further forward.
    If I understood what you meant that is...
  11. Aug 9, 2021 at 11:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah I think you understood me! haha
  12. Aug 9, 2021 at 11:21 AM
    betterbuckleup
    Ian
    Concord, CA
    Well I'm not putting my stock arms back on so I'll have to compare steering angle with a buddies truck to see if there is any difference.
    Maybe I'm tripping, but it sure seems like I have less.
  13. Aug 9, 2021 at 11:25 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't think you are. Im sure there is a tiny difference. Could just be the "longer wheel base" too since it is now streched out. Or could just be I don't notice it and you do. :notsure:
  14. Aug 9, 2021 at 11:57 AM
    Phessor
    Phessor Well-Known Member
    Interested in this poly carrier bearing you have installed.
    unstpible and Yetimetchkangmi like this.
  15. Aug 9, 2021 at 12:01 PM
    BeLance89
    Brandon
    Huntsville, AL
    @Phessor see my quoted post above. It has the source info you need. Once I start to daily this thing again i'll report back with results.
    Phessor[QUOTED] likes this.
  16. Aug 9, 2021 at 12:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I had not considered this impact until now. It might be interesting to document just how much the tie rod angle actually changes from a well aligned OEM to Solo. And where the oTREs pivot point is before and after.
    I would imagine that if there were to be any bind during flexing situations that it would be the iTRE that takes the brunt of that but those seem to have plenty of range of motion to accommodate this sort of change.
  17. Aug 9, 2021 at 12:56 PM
    betterbuckleup
    Ian
    Concord, CA
    Yea when I compare them against another rig with OEM lowers, I'll take pictures best I can.
    But when looking at the tie rods with the solo's you can clearly see they are angled more frontward compared to being more or less in-line with the rack with OEM.
    I'm not worried about binding because Solo would have definitely heard about that by now and fixed it.
    I haven't run into issues with binding on the trail so far.
    Digiratus[QUOTED] likes this.
  18. Aug 9, 2021 at 2:21 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    Finished up the add a leaf and re arched the springs a little for a tad more lift out of the rear.
    62F4A762-A762-4C74-8E4B-1475FB55461C.jpg D6E11F06-8839-4D3D-83BE-E39D45791DED.jpg 6B01CF53-2E5A-4780-81F4-C5D61630374B.jpg D0F3835D-90D9-4C04-9F63-876F70E6076A.jpg
    Holds weight pretty good for being spring under
    7 brake drums
    empty
  19. Aug 9, 2021 at 4:04 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    It’s been a productive day. Not sure what I’m going to do for the front grab handles (paint doesn’t seem to want to dry) and the seat belts. But the black is coming along nicely! Just have to order some seat covers for the Subaru seats. Starting the door panels tomorrow
  20. Aug 9, 2021 at 4:25 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Made some progress today. Also got the AC clutch out, of course I ordered the wrong bearing so it’ll be ordered tomorrow. But yeah that bearing is toast
