  1. Mar 28, 2022 at 10:31 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Does anyone know where to source new window trim?
    chrslefty likes this.
  2. Mar 29, 2022 at 12:13 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    you can always run an auto tranny. Its a bit taller but I'm pretty sure your skids cover it all the same. So not like you're loosing anything like clearance. It would hang below the frame is all.
  3. Mar 29, 2022 at 3:59 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Preformed and side specific.
    unstpible likes this.
  4. Mar 29, 2022 at 5:09 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Badknees, unstpible and BeLance89 like this.
  5. Mar 29, 2022 at 8:18 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    For both A/T and M/T? I can confirm that the A/T radiator is listed as "Product not available"
    Hoping that since you were looking for an auto, we're looking for different things. I placed the order, we'll see what happens.
    Good point. I'll have to check that if the one I ordered doesn't exist. Can ask Eric to confirm that he only ever had one set of skids for 1st gens, regardless of trans.
  6. Mar 29, 2022 at 8:45 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    unstpible and turbodb like this.
  7. Mar 29, 2022 at 8:46 AM
    foothill96tacoma
    foothill96tacoma Well-Known Member
  8. Mar 29, 2022 at 9:11 AM
    turbodb
    Dan
    PNW
    AdventureTaco
  9. Mar 29, 2022 at 9:17 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I was planning on using the same one in my 5 speed taco - did you find a replacement MT?
  10. Mar 29, 2022 at 9:44 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Im lik 99% certain Eric's skids don't do anything different for the MT vs AT.
    I only know of 1 maybe 2 much smaller shops that ever did that. Most didn't since it didn't make sense cost wise.
    unstpible and Digiratus like this.
  11. Mar 29, 2022 at 10:08 AM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    unstpible, turbodb and Laxtoy like this.
  12. Mar 29, 2022 at 10:13 AM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    I would steer away from the 18" core height option if you have a V6. I tried it out after a rebuild because i wanted it tucked out of the way but the truck ran hotter than i would like during cruising speeds, 205+. I switched to the 3 core Champion and now the engine stays at 175 and will peak just above 180. I love it.
  13. Mar 29, 2022 at 10:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    right up until it busts a weld and leaves you stranded on the highway...
    I'd get rid of that POS rad ASAP
    El Taco Diablo likes this.
  14. Mar 29, 2022 at 11:02 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    You'll run those temps until you don't, and it fails... and it will fail.
  15. Mar 29, 2022 at 11:12 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Mine Champion hasn't failed yet but I didn't do too much hardcore wheeling with it installed. But since doing the TB/WP last year I swapped back to a Rockauto special since I was already taking it out.
    Edit: not sure on the miles but I had it installed for a good 3 years
  16. Mar 29, 2022 at 11:22 AM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Mine too, thought I was one of the lucky ones who didnt leak. 3yr /30k ish miles is a good estimate on when these Champions will fail if using Red/Pink coolant.
    Went back to a Denso 221-3136 to fit and clear my SAS crossmember.
  17. Mar 29, 2022 at 11:59 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    You using the portion for the transmission too though? I think I heard I can get away with the 18" with a M/T. At least according to @slander
    unstpible and slander like this.
  18. Mar 29, 2022 at 12:38 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Last I checked I couldn’t get one for my 98 manual. But it may of been a legit backordered thing
  19. Mar 29, 2022 at 1:14 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I have a Champion sitting around - if I had the time & a MIG inverter machine I'd buy a spool gun and run more weld material anywhere it seemed weak. Then you'd only have to worry about non-structural places failing.
  20. Mar 29, 2022 at 1:18 PM
    techfinsoup
    techfinsoup Well-Known Member
    Sacramento
    1996 Tacoma 4x4
    You can have my oem if you want. I changed it out thinking it would resolve my overheating issue and it didn’t. So now I have the oem sitting in the shed.
    unstpible and turbodb[QUOTED] like this.
