  1. Apr 21, 2023 at 6:42 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    New to the Tacos...
    Did the usual start ups this past week
    Headlights, Bumpers, frame repair, exhaust, body mounts.
    Today/tomorrow finishing body mounts, fixin wing windows.
    det107 likes this.
  2. Apr 21, 2023 at 7:10 AM
    BeardedTacoma
    BeardedTacoma Well-Known Member
    Justin
    Hotlando
    2000 Tacoma x-cab 4x4 (SOLD)
    Installed a backup camera for my small trailer.
    6'4" and running wires under the dash = no fun! But, if you remove the seat. It's not that bad.
    erice, Wulf, Tour991 and 2 others like this.
  3. Apr 21, 2023 at 7:44 AM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Installing a third brake light today for the camper shell. Is there an adapter I should use for this or should I just cut that off and splice into the brakes light wires? Not very good at wiring stuff.
  4. Apr 21, 2023 at 7:48 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I just spliced the one on my rack into the drivers side brake light, those LED strips hardly take any power.
    erice and Wulf like this.
  5. Apr 21, 2023 at 7:57 AM
    Trandoshan-Tickler
    Trandoshan-Tickler Well-Known Member
    Gene
    Fontana, CA
    2002 Toyota Tacoma Prerunner
    Yeah, that's where my camper shell brake light is spliced. Seems to be common.
  6. Apr 21, 2023 at 8:00 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Definitely use a connector. If you ever need to remove the shell, you'll just disconnect inside the shell and be done with it. Keep it simple.
    Thread to ID wiring -
    https://www.tacomaworld.com/threads/camper-third-brake-light-wiring-by-a-noob.181629/
    Use these two as an example for connectors - you don't need to use a toyota connector but it should give you enough of an idea to get the job done. The connector in your pic can easily be picked up at any auto parts store.
  7. Apr 21, 2023 at 8:02 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    That's the way mine started. It was mainly in the morning leaving camp. It would squeal something fierce. Then it would shut up for the rest of the day. Then it would do it in the morning when I was leaving the house. I figured it was because there was still dirt and shit in there from the wheeling.
    But then my stereo would shut off and come back on. I noticed when the stereo would shut off my Volts were showing 16-17V+ (stereo was shutting off from an internal surge protector). When I replaced the alt... all my problems disappeared. Well... all THOSE problems did anyway. lol
    cynicalrider[QUOTED] likes this.
  8. Apr 21, 2023 at 10:03 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Such a good day!
    I've been itching to run it again with the truck in it's current form. Just rode my bike there and was eying that right line out of the creek. I think it's 2nd only to Pritchett now that I've run most all the trails out there.
  9. Apr 21, 2023 at 11:09 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Actually haven't experienced any bumpsteer. But the steering is so tight that you really have to pay attention when driving.
    Wulf likes this.
  10. Apr 21, 2023 at 11:15 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    If you are not having voltage or bearing issues getting the correct pulley offset and a fresh belt might do the trick. I am not aware of any of the numerous configurations/applications of the CS144 that come with the correct offset pulley. They are close and "look" like they line up but they don't.
    https://www.tacomaworld.com/threads/cs144-alternator.795316/#post-28494173
    Speedytech7 likes this.
  11. Apr 21, 2023 at 11:31 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I was mostly concerned with the bumpsteer being introduced via the offset of the heim joints. I previously looked into doing it with OEM lbj, but the new TC solution might eliminate those concerns since they claim to improve steering geo and reduce bumpsteer.
    I do have a bit with my Solo arms and stock steering as is.
    Your steering hasn't loosened up at all since install? how many miles have you put on them so far?
    Wulf likes this.
  12. Apr 21, 2023 at 12:31 PM
    Lucky_Gargoyle
    Lucky_Gargoyle Well-Known Member
    96 DLX 2.7 4x4 5spd
    Toytec coil-overs, SPC upper, OME CS019 leafs w/ 5110 bilstein, LCE header
    you could get a piece cut and use some windshield gasket. Cut a few holes and use bolts to hold it all together. Or better yet swing some doors.
  13. Apr 21, 2023 at 1:06 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    The car IF I can launch it right is capable of high 11s. Soooooo
    https://youtube.com/shorts/skKicgAyYbM?feature=share
  14. Apr 21, 2023 at 1:33 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Just installed a new OEM rack last weekend. Does anyone know how many turns the steering wheel has from lock to lock? I'm wondering if the ragjoint got mis installed on the splines cause one side has fewer rotations than the other
  15. Apr 21, 2023 at 1:46 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Yepp it works :D
    I did the same with the reverse lights for led reverse pods
  16. Apr 21, 2023 at 2:05 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
  17. Apr 21, 2023 at 2:31 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    The tightness is from the TC LBJ? Hmmm…I have mine waiting to be installed.
  18. Apr 21, 2023 at 4:05 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    variety of factors Im sure. But the more direct the steering is the more you can't be lazy down the highway. Small movements can send you out of your lane. I found this to be true even when I did the slip joint tac weld mod. You really couldn't be lazy with the steering after that.
    chrslefty likes this.
  19. Apr 21, 2023 at 4:17 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Speaking of steering.
    Dropped by Yota1 today to pick up some replacement (hub) studs for the rear axle build, and some other odds and ends. There were a couple broken hub studs on the Toyota Truck IFS hubs I bought... easy fix.
    But these were hanging there on the shelf and calling out to me.
    Gotta love buying parts for the next project before you're halfway done with this project.
    :rofl:
    And also... Brown Santa brought me more goodies from Front Range Offroad. :thumbsup:
    erice and chrslefty like this.
  20. Apr 21, 2023 at 4:43 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    And for the record... I really can not say enough good things about Yota1. That shop is top notch. The people there are outstanding.
    If you need parts, they have all sorts of OEM. They can get most any OEM. And they build some bad assed Yota motors too.
